Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 15th of February 2011 (Tue)   #1
psychodweep
Default Flash bounce card of 580ex (II) came loose, how to re-insert ?
My bounce card of my 580exII just came loose during use, there's nothing damaged to the bouncecard.
Anybody who knows how to get it back in without opening the flashhead (because you need to remove glued rubber etc) ??
psychodweep is offline   Reply With Quote
Old 15th of February 2011 (Tue)   #2
M.Quick
M.Quick's Avatar
Default Re: Flash bounce card of 580ex (II) came loose, how to re-insert ?
Just try to snap it back into place if you don't wanna hurt the warranty to open it up.
Take one of the tabs and put them in the hole and the other tab pointed halfway down and then simply push the bounce card up on that side.
If it came loose without being opened it should get back in one way...
Note: I will not be held responsible if you make any misstakes during the procedure.
My "cheap" pro-setup;
Canon EOS 450D | Canon 50mm f1.8 II | Canon EF 70-200L f2.8 IS USM | YN-468 v2
8GB SDHC Class10 | BG-E5 + 4xLP-E5 | RC-4 | Canon E1 | Lowepro Exchange Messenger bag
M.Quick is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
DIY Bounce card w/flash... MT Stringer Small Flash and Studio Lighting 16 5th of September 2009 (Sat) 00:04
Bounce flash and bounce card basics tkbslc Small Flash and Studio Lighting 1 2nd of December 2008 (Tue) 00:29
What do you use your 580ex and (insert slave flash) for? grphx Small Flash and Studio Lighting 5 14th of March 2008 (Fri) 12:29
Omni Bounce loose on flash.. constrict Small Flash and Studio Lighting 1 12th of February 2007 (Mon) 10:49
580ex / 430ex Bounce Card v.s. Homebrew StealthLude Small Flash and Studio Lighting 5 9th of November 2006 (Thu) 15:42
