Thread started 20 Feb 2011 (Sunday) 09:24
Memory for T3i?
dsrupert
1 post
Feb 20, 2011 09:24 |  #1
I'm pre-ordering my first DSLR the T3i (external link), what kind of memory card should I get? I can get the Sandisk or Transcend (external link), which is sufficient enough?
rxjohn
Feb 20, 2011 09:37 |  #2
If you plan to shoot video, you'll want to get the minimum recommended class memory card. I believe 550D recommends at least class 6.
This is important because of the speed at which it can write on the card. If the card can't process at adequate speed, the processing buffer will get loaded and automatically shut off the recording.
That being said, I use 16GB class 10 Transcend with no issues. It provides about 40 minutes of HD video recording.
kenshap
Feb 20, 2011 09:55 |  #3
rxjohn wrote in post #11878300 (external link)
I have found Transcend Class 10 cars to be cost effective and reliable. I have 4 8 gig cards and have not had an issue with them. SANDISK is also recommended but is more expensive, so in my opinion unless you are doing critical work the Transcends work fine.
Canon T6s (battery grip) | Canon T4i (aftermarket battery grip) | Canon T2i | Canon EF-S 18-55 IS | Canon EF-S 55 - 250 | Canon EF 50mm f/1.4 | Canon EF-S 10-22mm | Canon EF 100mm f2.8L Macro | Canon 40mm
stevemacko
Feb 20, 2011 10:09 |  #4
I'm not the OP, but a 60D may be in my near future... So I'll be making the switch from CF to SD. Thanks for the info, Guys!
A whole box of point and shoots, EOS 30D, EF 20-35 f/3.5-4.5, 50mm f/1.8, Super Tak 135, 70-200 f/4 L
Gregg.Siam
Joined Jun 2010
Feb 20, 2011 12:02 as a reply to  @ stevemacko's post |  #5
I've used both the SandDisk and Transcend, both are sufficient, especially at class 10. Flash can go bad no matter who makes it.
I would also consider getting a backup card too.
5D MKIII | 24-105mm f/4 L| 50mm f/1.8 | 600EX-RT [FONT=Tahoma][COLOR=bl​ue][FONT="]|
∞ 500px (external link)
coffee_mon
Feb 20, 2011 16:37 |  #6
I just got my T2i and 2 4 gig class 10 and 1 16 gig class 10 transcend and I've had nothing but great results. I don't think I will be using anything else at this moment.
18,750 views & 0 likes for this thread
Memory for T3i?
version 2.0 /
Latest registered member is Gibby391
724 guests, 389 members online
