Thread started 20 Feb 2011 (Sunday) 18:01
How to properly crop in photoshop without loosing aspect ratio?
boerewors
Joined Sep 2009
Feb 20, 2011 18:01 |  #1
Im going crazy here. I want to maintain the 4:3 aspect ratio when cropping but my brain cant figure it out.
The only way i can do it is by typing 4 & 3 in the boxes to which photoshop then resamples my image to 4 x 3 cm and then i have to resize it. Can someone please tell me how to do this before i go all nuclear on myself. Im using photoshop CS5
The most important piece of gear you own, resides in your head and its called your brain.
krb
Feb 20, 2011 18:05 |  #2
I normally just enter 4 and 3 in the boxes like you say. What you need to rememeber is that it does NOT resample the image unless you enter a value in the 3rd box for resolution.
-- Ken
Gear list
Marcus ­ X
Feb 20, 2011 18:51 |  #3
boerewors wrote in post #11880803 (external link)
I only know of one way. Select the crop tool, leave all the boxes for dimensions and resolutions empty, and then select the entire image. Now, with the entire image selected, hold the shift key, grab one of the corners and drag it to crop. If you don't select the entire image first, holding shift will lock you into a square crop.
ChasP505
"brain damaged old guy"
Feb 20, 2011 18:54 as a reply to  @ krb's post |  #4
Select the entire image, then while holding down the Shift key, resize the crop area.
Chas P
"It doesn't matter how you get there if you don't know where you're going!"http://photography-on-the.net …p?p=10864029#po​st10864029
Damo77
Feb 20, 2011 20:07 |  #5
Why are you cropping to the 4:3 ratio?
Damien
Website (external link) | Facebook (external link)
tonylong
...winded
Gallery: 60 photos
Feb 20, 2011 20:24 |  #6
Damo77 wrote in post #11881567 (external link)
Yeah, if you are doing this to a DSLR image the original aspect ratio is 2:3 not 4:3. This could confuse you if you enter 4 and 3 in the dimensions box and see your image being cropped off at the wider end!
Like was said, don't enter a resolution number or you can end up resampling the image. Or, like was said, hold down Shift as you drag the crop rectangle and it should keep the originsl aspect ratio or whichever one you choose to enter.
Tony
boerewors
Joined Sep 2009
Feb 20, 2011 20:39 |  #7
Cool you guys are great, it works now and i even learnt in the process that i was using the wrong ratio. This forum rocks!!
Damo77
Feb 20, 2011 20:43 |  #8
No, you're missing the point. Why are you cropping to any ratio at all?
You should only crop when you have specific reason to do so - eg printing. And only a handful of standard print sizes are 2:3, and even less 3:4.
Damien
boerewors
Joined Sep 2009
Feb 21, 2011 00:30 |  #9
I just want to keep the original aspect of the camera thats all.
elogical
Feb 21, 2011 01:06 |  #10
boerewors wrote in post #11882784 (external link)
I tried doing that for a while but then I figured it's kind of over-rated if I'm not going to be printing the vast majority of the images anyway, now I just crop to the strongest composition if all I'm gonna be doing is viewing it digitally.
Glad you figured it out though, it's very good to know and good to be aware of, whichever you choose to stick to.
Gear
Damo77
Feb 21, 2011 01:06 |  #11
Yes, but why?
I'm asking because I want you to thoroughly analyse your own workflow. Is cropping really the best thing to do? Have you considered the 8x10 problem (external link) which occurs from careless cropping?
Damien
boerewors
Joined Sep 2009
Feb 21, 2011 01:19 |  #12
I have noted what you guys have said and will take it to mind when processing in future. I am a beginner photographer. Just got my camera today so i still need to run in with all these issues. Im just so over the moon that i have learnt one thing for today that has been bugging me for months.
BrandonSi
Nevermind.. I'm silly.
Gallery: 62 photos
Joined Sep 2004
Feb 21, 2011 12:48 |  #13
boerewors wrote in post #11882990 (external link)
It's not too complicated, some people just make it that way.
Unless you're going to print, crop to whatever size / ratio you'd prefer.
If you plan on the image being printed, then crop to the appropriate ratio for the print size. 8x10 is obviously 4:5 ratio. 20x30 is 2:3. Clearly you can't provide the same image in every ratio without using borders, or re-cropping, so either provide prints only in sizes you're satisfied with or just accept the fact that in order to make every common print size, you're going to have to produce some strangely / poorly composed images.
Some online services (SmugMug, for example) will allow clients to perform the crop themselves, which I find very nice, since I'll get a sale, and the client can see what the crop is going to cause their final print to look like.
[ www (external link)· flickr (external link)]
Methodical
Gallery: 158 photos
Sep 25, 2011 20:43 |  #14
Good info
My Treasure Chest
MethodicalImages (external link)
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
cagenuts
Joined Mar 2011
Sep 25, 2011 23:58 |  #15
Methodical wrote in post #13162117 (external link)
Good info
+1 Indeed so!
...Ask me anything, I'm an ultracrepidarian.
Hilton
C A N O N | 6D | Σ f/1.4 | 24-70 f/4 | 70-200 f/2.8 II | Kenko Pro300 DGX 1.4 TC |
11,846 views & 0 likes for this thread
version 2.0 /
Latest registered member is ppahv
778 guests, 317 members online
