Reply
Thread Tools Display Modes
Old 24th of September 2005 (Sat)   #1
Henrik Ploug
Default Sigma 30mm f1,4 vs. Canon 28mm f2,8
Here are some test shots from the Sigma 30mm f1,4 and the Canon 28mm f2,8. None of the shots have been sharpened in camera or in Photoshop.
The Sigma is sharper in the center and the Canon is sharper in the corner, when compared at equal apartures.
The center sharpness of the Sigma at f1,4 can be compared with the center sharpness of the Canon at f4. The corner sharpness of the Canon at f4 can be compared to the Sigma at 5,6.
Henrik Ploug is offline   Reply With Quote
Old 24th of September 2005 (Sat)   #2
Henrik Ploug
Default Sigma 30mm f1,4 vs. Canon f2,8
Old 24th of September 2005 (Sat)   #3
Lenny_D
Default Re: Sigma 30mm f1,4 vs. Canon f2,8
Really interesting.... What do you think, is the large change in sharpness across the diameter of the Sigma lens disturbing in real life photography? Is the 1.5 stop worth the unbalance in sharpness?
Obviously the Canon gives a more balanced picture (regarding sharpness).
Any other differences, e.g. contrast, clarity?
I'm still looking for the best "standard"' prime on a 20D.
Lenny
Lenny_D is offline   Reply With Quote
Old 24th of September 2005 (Sat)   #4
Henrik Ploug
I have just done the test today, and I haven't noticed the soft edges before now. After I noticed, I have now expanded the test, so that it also includes edge crops:
Old 24th of September 2005 (Sat)   #5
Henrik Ploug
At the edge both lenses seem quite sharp, and I think I will keep the Sigma and sell the Canon. Just have to avoid getting the motif stuck in the corner.
Old 24th of September 2005 (Sat)   #6
Hellashot
User is banned from forums
Default Re: Sigma 30mm f1,4 vs. Canon 28mm f2,8
The Sigma 30mm f1.4 DC is known to be a very sharp lens at f1.4, a lot sharper than Canon's f1.4 50mm.
Hellashot is offline   Reply With Quote
Old 24th of September 2005 (Sat)   #7
grego
grego's Avatar
That's the 28 f/2.8, not 50.
Go UCLA!! |Gear|SportsShooter|Flickr|
grego is offline   Reply With Quote
Old 24th of September 2005 (Sat)   #8
Hellashot
Yes, what I stated is what I wanted to say.
Old 24th of September 2005 (Sat)   #9
grego
grego's Avatar
I gotcha. I do have to say the 50 1.4 is one of the sharpest lens out there. And it not being an L, makes it even better of a deal. Although I haven't seen a side by side comparision of the 50 vrs 30 1.4's.
Old 25th of September 2005 (Sun)   #10
Henrik Ploug
Just added some extra shots from the edges and the top left corner. My conclusion:
The Sigma 30mm f1,4 is sharpest in the center.
The Canon 28mm f2,8 is sharpest in the corner.
The two lenses are just about equal at the edges.
Old 25th of September 2005 (Sun)   #11
pfogle
pfogle's Avatar
Nice example - the Sigma looks good compared to the 28/2.8 - though to be honest, I'm selling the EF28/2.8 because it's just not a great lens.
Has anyone compared the Sigma to the EF 28/1.8 - also not known as a great lens, but much more interesting to me than the f2.8 version.
thanks
Phil
___________________________________________
Phil Fogle
5D; 17-40/4L, 24/3.5L TSE, 28-70/2.8L, 50/1.4, Sigma 50/2.8 macro, 100/2.0, 135/2L.
pfogle is offline   Reply With Quote
Old 25th of September 2005 (Sun)   #12
drisley
"What a Tool I am"
drisley's Avatar
If you get a good copy of the 28/1.8, it's an amazing lens.
The build and autofocus (speed and silence) are both fantastic.
I had a great copy that I sold to RichardTheSane, and he will vouch for it's optical quality.
drisley is offline   Reply With Quote
Old 25th of September 2005 (Sun)   #13
Andy_T
That might have something to do with the Sigma being a DG lens (for reduced image circle) versus the Canon being a lens for full frame ... so you don't really see the edges of the Canon lens on an image from a 1.6 crop camera.
f/1.4 vs. f/4.0 is a difference of 3 full stops, btw. (that means 8 times the light gets in at the same time)
Full stops are 1.0 - 1.4 - 2.0 - 2.8 - 4.0 - 5.6 - 8.0 ...
Maybe not so important for landscapes, where you'd stop down anyway, but quite important if you want to isolate your subject.
Best regards,
Andy
Andy_T is offline   Reply With Quote
Old 25th of September 2005 (Sun)   #14
pfogle
pfogle's Avatar
thanks, dr - by the way, do you know what the odds are on a 'good copy'? I'd put Sigma's at about 1 in 4 being good for the wides, but Canon I have no idea about. I haven't had a 'bad' Canon yet, but you do hear about them, especially with the 28/1.8 and the 20/2.8 for some reason.
Phil
Phil Fogle
Old 25th of September 2005 (Sun)   #15
Wavy C
Tnx for posting these test results Henrik. Very well laid out and makes it easy to compare.
Wavy C is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon EF 28mm f/1.8 vs Sigma 30mm f1.4 narlus Canon EF and EF-S Lenses 10 30th of June 2009 (Tue) 14:37
sigma 30mm 1.4 vs Canon 28mm 1.8 Nightscape Canon EF and EF-S Lenses 32 24th of July 2007 (Tue) 02:06
Canon 28mm or Sigma 30mm RuggerJoe Canon EF and EF-S Lenses 11 17th of May 2006 (Wed) 20:07
Canon 28mm 1.8 vs Sigma 30mm 1.4 AND on 1.6x and FF andrewaaa5 Canon EF and EF-S Lenses 23 28th of March 2006 (Tue) 16:03
