What can I do? Can I repair this without sending it in... I am so lost... has this happened to anyone?
Vickie17 Hatchling 8 posts Joined Mar 2011 More info       | Mar 12, 2011 15:00 | #1 What can I do? Can I repair this without sending it in... I am so lost... has this happened to anyone?
      | Mar 12, 2011 15:00 | #2 oh by the way.. the flash pops open.. but does not flash... the camera clicks but no flash is used.
Bang Bang Boy Goldmember ![]() 1,347 posts Joined Nov 2010 Location: South Africa More info       | Mar 12, 2011 17:12 | #3 Flash turned off in the menus? Lots of old stuff but hey I am a student
sandpiper Cream of the Crop ![]() More info       | Check there is no dirt in the hotshoe mount, sometimes a small piece of debris / grit can hold the pin down that tells it a flash is mounted. When that happens the pop up flash won't fire as the camera thinks there is a speedlight present.
      | Mar 12, 2011 21:25 | #5 is the hot shoe what is on top?
      | Mar 12, 2011 21:30 | #6 how much is a flash I can attach?
Higgs Boson Goldmember 1,953 posts Likes: 4 Joined Jan 2011 Location: Texas Hill Country More info       | Mar 12, 2011 21:58 | #7 hot shoe is the little metal connector looking things on top. A9 | A7R3 | 25 | 55 | 85
joeseph "smells like turd" ![]() More info       | Mar 13, 2011 01:20 | #8 Bang Bang Boy wrote in post #12008230 ![]() Flash turned off in the menus? check this first... sandpiper wrote in post #12008337 ![]() Check there is no dirt in the hotshoe mount, sometimes a small piece of debris / grit can hold the pin down that tells it a flash is mounted. When that happens the pop up flash won't fire as the camera thinks there is a speedlight present. if the pin's stuck, the flash won't pop up. Sadly I think it's broken - on the plus side you can buy a good flash for what it would cost to repair... some fairly old canon camera stuff, canon lenses, Manfrotto "thingy", 1D MK II converted for IR, and now an M5
joeseph "smells like turd" ![]() More info       | Mar 13, 2011 01:25 | #9 Vickie17 wrote in post #12009339 ![]() how much is a flash I can attach?
lannes Goldmember ![]() 4,370 posts Likes: 5 Joined Dec 2009 Location: Perth, Australia More info       | Mar 13, 2011 07:39 | #10 With the flash up and the camera set to the "green box" mode, if you try and take a photo while pointing to a darker part of the room, does the flash strobe and the camera lens focus ? 1Dx, 1DM4, 5DM2, 7D, EOS-M, 8-15L, 17-40L, 24 TSE II, 24-105L, 50L, 85L II, 100L, 135L, 200L f/2.8, 300L f/4, 70-200L II, 70-300L, 400Lf/5.6
      | thanks guys.. yes it does focus and the flash pops up but the pic is taken and the pic comes out rather dark b/c the flash does not go off even when the flash pops up.. does this make since..
Cokeman Member 168 posts Joined Aug 2010 More info       | Mar 13, 2011 10:10 | #12 joeseph wrote in post #12010151 ![]() if the pin's stuck, the flash won't pop up. Sadly I think it's broken - on the plus side you can buy a good flash for what it would cost to repair... +1 - My camera has the issue where the pin gets stuck after I use an external flash. When the pin gets stuck, the flash does not even pop up. The flash menus then seem all confused - if I look at the menu for the popup flash, it tells me an external flash is connected; if I look at the menu for the external flash, it tells me an unrecognized flash is connected. T2i, 70-200/4, 28/1.8, 85/1.8, 28-135, 18-55, 55-250, 430EXII
      | Mar 13, 2011 23:06 | #13 well.. I took it to Wolf Camera and they said it was the flash had burned out and it will cost over $200 to fix and would be gone for 8 weeks.. CRAZY... I can't live w/o my camera that long.. he suggested I buy a flash for $99 that fits Cannon they sell... what do you think of the Quantaray flash that sells for $99 and it takes batteries.. I could see me going thru a lot of batteries..
tonylong ...winded ![]() More info       | Mar 13, 2011 23:14 | #14 Vickie17 wrote in post #12014778 ![]() well.. I took it to Wolf Camera and they said it was the flash had burned out and it will cost over $200 to fix and would be gone for 8 weeks.. CRAZY... I can't live w/o my camera that long.. he suggested I buy a flash for $99 that fits Cannon they sell... what do you think of the Quantaray flash that sells for $99 and it takes batteries.. I could see me going thru a lot of batteries.. Yeah, external flashes take batteries or an external power supply. That's no big deal, but you should make sure you have a good supply. I keep both rechargables and "emergency" non-rechargables (because over time the rechargables can leak out their charge). Tony
Cokeman Member 168 posts Joined Aug 2010 More info       | Mar 14, 2011 08:16 | #15 Eneloops are great... they hold their charge very well. T2i, 70-200/4, 28/1.8, 85/1.8, 28-135, 18-55, 55-250, 430EXII
y 1600 |
Log in |
Latest registered member is Roberto Betta 617 guests, 286 members online Simultaneous users record so far is 6430, that happened on Dec 03, 2017 |
