Thread started 27 Sep 2005 (Tuesday) 05:19
Canon service at Elstree, UK
wibbly
Joined Aug 2003
Sep 27, 2005 05:19 |  #1
I think I may have to send all my lenses and 20D body to them for calibration - but the issue I have is marginal (variable levels of front focusing).
Anyone had bad experiences with Canon service in the UK specifically on this kind of issue? Not that I have much choice. I tried Fixation, and they said they can't deal with the kind of problem I have...
W
http://www.thebaldphot​ographer.com/ (external link)
http://www.facebook.co​m/jstbp (external link)
hammerman660
Sep 27, 2005 05:31 |  #2
I'm a member of CPS, so on the odd occasion I have had to put my kit in for repair it's been turned around in days. However, they have never got to the bottom of the problem I have with my 1d and it over exposing occasionally in 8fps. They did supply a loan 1d while they worked on it, but that is a CPS benefit and not one they guarantee.
They did however fix my 10d, and calibrate the lens I sent in, a friend also just got has 10d back after a mirror issue, and says it now works better than when he first used it. I guess it all depends on how bad the issue is and how heavily you use your kit.
All my kit currently needs servicing, but I have been holding back sending it in, as I have not been able to - A) find the time and B) fully identify which part of my set up is to blame for the occasional image that is way off focus (back focus)
www.ultimate-images.co.uk (external link) Leaders in Equestrian Event Photography
Radioham
Joined Jan 2005
Sep 27, 2005 12:19 as a reply to  @ hammerman660's post |  #3
Have a look http://photography-on-the.net/forum/showthre​ad.php?t=101456
Canon
EOS 20D
EF50 F1.4
EF17-40 F4 L
EF 200mm 2.8 L II USM
EF 2 x MkII
Speedlite 550EX
TOKINA 28-200 F3.5-5.6
Kenko Extension Tubes
PHOTOSHOP CS 2
KennyG
Joined Aug 2003
Sep 27, 2005 20:17 |  #4
Go to Lehmanns in Stoke. Best Canon service centre. Carry out warranty repairs and also CPS priority. Fast turn-round too.
If you have variable levels of front focus I would not suspect a hardware issue to be honest. If you run a proper test it should be consistent.
Ken
Professional Motorsport Photographer
2 x 1D MK-II, 7D, 17-40L, 24-70L, 70-200 2.8L IS, 100-400L,
300 2.8L IS, 500 4.0L IS, 85 1.8, 50 1.4, 1.4 & 2.0 MK-II TC.
wibbly
Joined Aug 2003
Sep 28, 2005 01:59 |  #5
Thanks Kenny G. I actually spoke to Fixation in London already (they have an excellent reputation), but they already said they can't do this kind of (calibration) work. I wonder if Lehmanns do...
W
PaulB
Joined Apr 2003
Sep 28, 2005 04:58 as a reply to  @ wibbly's post |  #6
As far as I am aware the only places to do calibration of DSLRs in the UK are Canon themselves, Lehmann's, and Colchester Camera Repair Services - if you are in Scotland I'm sure there is a Canon authorised repairer in Glasgow (but I can't remeber their name).
wibbly
Joined Aug 2003
Sep 28, 2005 10:19 |  #7
Lehmann's have a good/better reputation (comapared say with Canon and, say, Fixation)?
W
John57
Joined Jun 2003
Sep 28, 2005 11:10 as a reply to  @ wibbly's post |  #8
Fixation have been good to me .... but, as you say they don't sort the focus.
I had a 10D that was well out on focus - Canon UK didn't believe me until they saw identical pictures taken with the same lens on our other 10D ! To be fair though, when they looked at the camera they said it was definitely wrong and adjusted it. After that it was like a new camera .... or to be exact, the same as my other 10D had been out of the box.
So, for camera focus issues I can give Canon UK 10/10 ...... however, lenses are, in my experience, a different matter -
Canon UK had 3 goes at sorting the focus on a 24-70L I had ..... they failed and the lens got replaced, effectively by them. They only accepted it was a duff one after I took images with our other 24-70L which was fine and, like the 10D senario, sent them in as a comparison.
I sent a 70-300 DO back twice for softness / out of focus images compared to other 70-300 DO lenses I had seen and they kept saying it was 'within tolerances' when it was clearly rubbish. I ended up selling the lens.
I hope this helps - for adjusting camera focus Canon UK were fine but for lenses they were not.
3,116 views & 0 likes for this thread
Latest registered member is abrahamf
1012 guests, 428 members online
