Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Digital Video
Reply
Thread Tools Display Modes
Old 23rd of March 2011 (Wed)   #1
JewHefner
Default UPLOAD AND EXPORT VIDEO IN HD PREMIERE PRO
I been having some problems with my final output of quality in my hd videos.
I am using a canon 60d shooting in 1920x 1080p 30
before anything, i compress the video in red giant's "grinder" using apple pr res standard
then open up premiere with settings: "HD DSLR"-"1080p HD"
then the exporting i have no clue about....
any help would be great
thanks.
JewHefner is offline   Reply With Quote
Old 23rd of March 2011 (Wed)   #2
Kento
Kento's Avatar
Default Re: UPLOAD AND EXPORT VIDEO IN HD PREMIERE PRO
Depends on what you plan to do with it... just for upload to the internet? Then all you need is 720p. So Just select the output preset for Vimeo 720p. If I was you I would just look up "export premiere pro tutorial" or something like that on Youtube to get educated.
My Tools
-Jesse
Kento is offline   Reply With Quote
Old 23rd of March 2011 (Wed)   #3
Chippy569
Chippy569's Avatar
you're wasting your time (and hard drive space) converting to prores.
Chippy569 is offline   Reply With Quote
Old 23rd of March 2011 (Wed)   #4
JewHefner
what should i be doing?, just edit raw?
i used a tutorial on how to export correctly, but when i play video its just a black screen, could this be due to compressing before i upload onto premiere?
Old 23rd of March 2011 (Wed)   #5
Chippy569
Chippy569's Avatar
The .mov is already compressed using H.264 compression. Think of that like having a jpg. Converting the .mov to prores is somewhat like converting jpeg to a raw- it's not going to get better plus take up way more hdd space. premiere can handle the h.264 footage just fine. You're going to want to export to the same format as well; H.264 compression in a .mov file if you want to get it on YouTube/vimeo in HD. See the link in my sig.
Old 24th of March 2011 (Thu)   #6
JewHefner
U ARE THEE MASTER............ GRACIAS
Old 24th of March 2011 (Thu)   #7
JewHefner
weird...... i followed vimeos export setting and for some reason my video wont upload, not even on youtube
Old 26th of March 2011 (Sat)   #8
benesotor
benesotor's Avatar
Are you using CS5?
If so, you could avoid the whole transcoding to prores fuss. CS5 will edit the h.264 files natively if you want to. If you want to edit in a 422 colour-space (which would be the only reason to convert to prores) then that's fine, not sure if prores is the best option for premiere (cineform might be better).
But remember you're not gaining much more control by using prores 422, the 60D still uses 8-bit compression so nothing is captured at 4:2:2 or 4:4:4.
Unless you're into serious colour-correction then I'd just edit natively in CS5.
For export, render at 720p @ about 6mbps (but use VBR) with the quicktime format, or h.264 MP4. They are probably best for the web.
Pick the dimensions and pixel aspect ratio to match your video (check by looking at the 'output' tab on the preview screen before you export)
EOS 5D | Zeiss 50mm f/1.7 Planar T* | Arsat 80mm f/2.8
Panasonic GH2
Flickr
benesotor is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
question about 7D video and adobe premiere mosteller Digital Video 2 19th of March 2011 (Sat) 01:57
Adobe Premiere Elements 9 for 7D Video? Jim K Canon EOS Digital Cameras 2 7th of January 2011 (Fri) 08:22
Exporting video for AE or editing in Premiere CS5 rgrebby Digital Video 6 30th of October 2010 (Sat) 17:19
5D2 video export settings from iMovie for web? stevo8 Digital Video 1 5th of November 2009 (Thu) 11:23
