Reply
Thread Tools Display Modes
Old 29th of September 2005 (Thu)   #1
Livingston
Default Resolution vs. compression
I just bought a G6. What a toy!!!
I am somewhat familiar with digital photography and image processing, but mostly the basics. The G6 has settings (still) for both resolution and compression. I think I understand resolution but the compression stuff confuses me a little.
I think I understand the resolution settings. My assumption is that this setting adjusts the pixel density on the image being stored on the card. I hesitate to use terms like "pixels per inch" but that's as close an analogy I can come up with. My assumption is that the processor in the camera is doing something like taking areas of the image and resolving them to a greater or small number of pixels based on the resolution setting. In a sense there is some compression being done based on this setting.
Now, looking at the compression settings (3 of them) I'm assuming that further compression is being done to the resultant data but that's where I lose it. Since all images are stored as JPEG (unless I use RAW) does the compression setting coorespond to different JPEG compression algorithms? Or is there something else going on here?
Also, does the processor first deal with resolution and then with compression?
Livingston is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
What resolution/compression? ColDaveG Small Compact Digitals by Canon 5 31st of July 2006 (Mon) 10:38
Resolution, compression, and PPi Stefan A Small Compact Digitals by Canon 3 7th of January 2006 (Sat) 21:05
Resolution vs. compression Livingston Canon G-series Digital Cameras 41 24th of October 2005 (Mon) 16:57
Compression and resolution pvdiamon Canon G-series Digital Cameras 1 20th of January 2002 (Sun) 17:39
Compression and resolution pvdiamon Canon G-series Digital Cameras 0 4th of January 2002 (Fri) 14:21
