Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Digital Video
Reply
Thread Tools Display Modes
Old 2nd of April 2011 (Sat)   #1
Default My DIY Stabilizer
hi tried the DIY stablilizer and works pretty good. I've seen several videos on youtube on how to make one with galvanized pipe so I thought I'd give it a try. I'll post a video clip soon.
Thank you
Photo99 is offline   Reply With Quote
Old 2nd of April 2011 (Sat)   #2
gibsonla
gibsonla's Avatar
Default Re: My DIY Stabilizer
interested in your results. looking forward to your posting
mind including where you bought the materials, specific parts, cost, etc. so it can be duplicated?
Michael L. Solomon
DP/AC/Colorist
www.SolomonM.com
gibsonla is offline   Reply With Quote
Old 3rd of April 2011 (Sun)   #3
Mikelangelo
Mikelangelo's Avatar
considering the size of your camera, I'm wondering if doing the exact same thing with 3/4" PVC pipe would not only be easier and cheaper, but the overall rig would be lighter as well? This rig looks very heavy... not a big deal, but I guess it depends on how much video you're going to shoot.
Then again... PVC might have too much vibration within the material itself. Looks like a nice rig. Heavy-duty enough to handle a DSLR with relatively heavy lens as well.
Nice job. Maybe I'll try it with 1/2 pipe? Too small?
My Photo Blog
Mikelangelo is offline   Reply With Quote
Old 3rd of April 2011 (Sun)   #4
Parts I needed was, 2-10 inch, 1-24 inch, 1 tee, 3-caps, all 3/4 galvanized,1-1/4 screw 1-washer, 1-bolt, black flat spray paint and 2-2.5 weights. I purchased the hardware at Home Depot and the weights at Wal Mart all totaled $33.00. You'll need to drill a 1/4 hole through one of the caps to fit the screw in and place a washer and bolt to hold in place for mounting your camera. Hope this helps.
Thank you
Old 3rd of April 2011 (Sun)   #5
Hi, your correct about the weight it does get heavy after a few minutes of use. I have 2-2.5lb weight discs on the bottom I plan on removing 1 of them to see if I get the same result.
I've learned whats makes a stabilizer is the weights.
Thank you
Old 3rd of April 2011 (Sun)   #6
Chippy569
Chippy569's Avatar
the point is that it is heavy. the problem with light cameras is that they're light, which means your hands' looser muscles' natural twitches translate to camera shake. More weight means your muscles have to stay tighter with reduces the twitching.
Chippy569 is offline   Reply With Quote
Old 4th of April 2011 (Mon)   #7
Mo.licious
stabilizer & self-defense weapon...all in one!
From the outside looking in, you can’t understand it. From the inside looking out, you can’t explain it.
Mo.licious is offline   Reply With Quote
Old 4th of April 2011 (Mon)   #8
gibsonla
gibsonla's Avatar
post some samples before I drop $500 on a blackbird or glidecam! =p
Michael L. Solomon
DP/AC/Colorist
www.SolomonM.com
Old 4th of April 2011 (Mon)   #9
No kidding...lol
Old 4th of April 2011 (Mon)   #10
I'll get out and walk around with it later and find some stairs to walk.
Thank you
Old 4th of April 2011 (Mon)   #11
Namerifrats
Namerifrats's Avatar
Looks interesting, and not too expensive. I'd like to see some results also
"There's an Evil Monkey in my closet!"
FLICKR
Namerifrats is offline   Reply With Quote
Old 4th of April 2011 (Mon)   #12
Hi all, just shot this short test I can get some day footage if everyone has difficulty seeing since this was shot at night.
http://vimeo.com/21957646
Thank you
Old 5th of April 2011 (Tue)   #13
LONDON808
LONDON808's Avatar
Had to whatch that twice , 1st time I was distract by subject to look for camera shake
For a small camera that is impressive
LONDON808 is offline   Reply With Quote
Old 5th of April 2011 (Tue)   #14
LOL...that was a friend of mind who doesn't mind being in front of the camera.
I'm happy with the results thanks for looking.
Old 5th of April 2011 (Tue)   #15
Namerifrats
Me too!!
That's a very "nice" friend by the way!!
Nice video too!! Looks like the rig you built works well!
FLICKR
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
70-200 2.8 is..stabilizer 1 and 2 mswobo Canon EF and EF-S Lenses 3 7th of June 2010 (Mon) 07:41
What is suitable stabilizer for 7D? shakyhand Digital Video 1 6th of January 2010 (Wed) 18:08
Stabilizer Question Bullhauler101 Canon EF and EF-S Lenses 1 17th of November 2009 (Tue) 23:07
HOW MUCH for the stabilizer 1kerry Canon EF and EF-S Lenses 12 22nd of February 2009 (Sun) 16:46
image stabilizer gam99 Canon EOS Digital Cameras 1 27th of February 2006 (Mon) 08:02
