Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Sports
Reply
Thread Tools Display Modes
Old 5th of April 2011 (Tue)   #1
Brian_R
Default night soccer lens advice
so i am in the process of organizing to be the athletic photographer at my school in the fall and the director told me to make a gear list of what i need to take photos as well as produce video spots each week. all my current gear is in my sig.
my question is that i am about to buy a 135L for myself and cant justify athletics buying it for me but they are definitely willing to get me a 70-200 as well as video gear. i told him that more than likely i can get away with shooting night soccer with the 70-200 f4 since it is only $700. am i right in my thinking that i can shoot this with my 7D?
i also plan on upgrading to a 50 1.4 which would be used for basketball. i dont have an extreme budget at my disposal for gear and it will all become property of the school so i have to give it all back once i graduate unless they hire me full time which i know he would like to do.
thanks for any advice.
Gear List Flickr Facebook
Brian_R is offline   Reply With Quote
Old 5th of April 2011 (Tue)   #2
Nmura
Default Re: night soccer lens advice
Stadium lights vary. I would suggest using your existing lens or renting and test to see if you can get 1/800 - 1/1000 SS under those lights. You will need to crank up the ISO in your 7D. Take some test shots of people running under those light conditions. The results will tell you what you need or can or cannot do. I assume the school is getting a dedicated video camera. The 7D is great for video, but not for soccer.
Gear
Nmura is offline   Reply With Quote
Old 5th of April 2011 (Tue)   #3
namasste
namasste's Avatar
f4 with flash will work under some pretty bleak HS stadium lights BUT...with 200mm as your longest focal length, I'd caution you to focus on shooting action close to you as even the 7D's ISO performance will show significant noise if you are cropping big and even the slightest bit underexposed under those conditions. for close action with flash 1/250s 800ISO and F4 should come pretty close to getting things done (at 1/2 flash pwr). Have fun.
namasste is offline   Reply With Quote
Old 5th of April 2011 (Tue)   #4
Brian_R
so if i did manage to get maybe the 70-200 2.8 non IS i would be looking much much better. our stadium lights are sub par
Old 5th of April 2011 (Tue)   #5
8612images
8612images's Avatar
Get a 70-200 2.8 non IS.
Steve
www.8612images.com
www.adplicity.com
8612images is offline   Reply With Quote
Old 5th of April 2011 (Tue)   #6
yourdoinitwrong
yourdoinitwrong's Avatar
That being the case I would say the 70-200 f/2.8 non-IS as well. For basketball you might want to consider the 85 f/1.8, it is a very popular indoor sports lens and focuses very quickly.
7D w/ BG-E7, EF-S 10-22mm f/3.5-4.5, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8
Full List
yourdoinitwrong is offline   Reply With Quote
Old 5th of April 2011 (Tue)   #7
namasste
namasste's Avatar
I shot the non IS 70-200 for years and will give a +1 to that suggestion. great lens that takes a 1.4x tc well too!
Old 5th of April 2011 (Tue)   #8
frederiksenp
frederiksenp's Avatar
I shoot with a 70-200mm f/2.8 NON-IS at MLS matches with the 7D.
Baltimore, MD Photographer | Canon 7D | Canon 5D2
BLOG :: Website :: Facebook
frederiksenp is offline   Reply With Quote
Old 5th of April 2011 (Tue)   #9
sfinkernagel
If budget is an issue, I would also consider the 200 2.8. 200 is about as short as I'd want to go for soccer, even on a crop body- my guess is that you will be zoomed in to 200mm on the 70-200 anyway. I have shot a lot of high school night games very successfully with the 40D and 200 2.8.
sfinkernagel is offline   Reply With Quote
Old 5th of April 2011 (Tue)   #10
Zivnuska
Zivnuska's Avatar
Night high school soccer with a 70-200 f/4.0 lens sounds difficult.
Phil Zivnuska
www.zivnuska.zenfolio.com
"It's not tight until you see the color of the irides."
Zivnuska is offline   Reply With Quote
Old 5th of April 2011 (Tue)   #11
Red Dog
Red Dog's Avatar
Never use flash on soccer unless you want chased out of the stadium. As pointed out a 70-200 f2.8 is more than sufficient with a 7D with the ISO expansion and the 1.6 crop factor effectively giving you 320mm. You don't need IS either for sports so scrap that one too.
Don't go any lower than 1/500 of a sec for soccer under lights if you can help it otherwise it gets messy. You may have to play around with your ISO settings until you get the right balance of light and shutter speed in AV. If the light is patchy, try and find an area where its brightest to shoot before the game starts. Sometimes directly under the floodlight stantion is a good place to start.
www.portadownfc.co.uk
Canon 1D MKIII +7D + 40D - Canon 300 IS F2.8 + Sigma 70-200 F2.8 & 120-300 f2.8
My Gallery: http://www.flickr.com/photos/actionpix/
Red Dog is offline   Reply With Quote
Old 5th of April 2011 (Tue)   #12
toadhunter911
toadhunter911's Avatar
Curious as to why?
Craig
toadhunter911 is offline   Reply With Quote
Old 5th of April 2011 (Tue)   #13
frederiksenp
Originally Posted by toadhunter911 View Post
Curious as to why?
It is distracting to the players, the spectators, and you are potentially messing with any other photog's light.
Old 5th of April 2011 (Tue)   #14
toadhunter911
Flash is used for night HS football all the time...
Craig
Old 5th of April 2011 (Tue)   #15
yourdoinitwrong
Curious as to why?
Firing a flash directly into the eyes of an athlete playing a fast-paced sport is generally not acceptable. If you were running down the field with the ball it would be distracting at the very least and possibly dangerous as well.
Full List
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
70-200 4 IS L lens good for night soccer games? c12281 Canon EF and EF-S Lenses 21 23rd of September 2009 (Wed) 15:13
Soccer Lens Advice Stuart Leslie Canon EF and EF-S Lenses 15 26th of November 2008 (Wed) 12:28
Need Lens Advice for a Beginner shooting soccer Terri G. Canon EF and EF-S Lenses 32 24th of November 2007 (Sat) 22:34
need advice for senior night/soccer field portrait slyone General Photography Talk 1 16th of October 2007 (Tue) 23:40
Night football (soccer) advice needed please LMP Sports 14 8th of October 2006 (Sun) 18:51
