Reply
Thread Tools Display Modes
Old 3rd of October 2005 (Mon)   #1
elipkin
Default 85 1.8 vs 100 2.8 Macro ... sharpness?
I am drooling over the images people take with the 85 but would not be able to efford both it the 100 macro and I would like some macro capability. How does 100 compare to the 85 in terms of sharpnes?
Eugene
Gallery
Model Mayhem
elipkin is offline   Reply With Quote
Old 3rd of October 2005 (Mon)   #2
grego
grego's Avatar
Default Re: 85 1.8 vs 100 2.8 Macro ... sharpness?
Does it matter if you want a lens that has macro capabilities? What's your priority?
The 85 is a much better low light lens and has great bokeh with fast AF. Both make good portrait lens, so you couldn't go wrong with either, but only one will give you a macro.
Go UCLA!! |Gear|SportsShooter|Flickr|
grego is offline   Reply With Quote
Old 3rd of October 2005 (Mon)   #3
ddelallata
ddelallata's Avatar
They are both great for portraits, but as Grego stated above..... the 100 will double-up as an excellent macro lens.
Dr. David de la Llata
_____________
Canon 20D
BG-E2 Battery Grip
Canon SpeedLite 430 EX
Canon EF 1.4X II
Canon EF-S 10-22mm F/3.5-4.5 USM
Canon EF 50mm F/1.4 USM
Canon EF 100mm F/2.8 MACRO USM
Canon EF 24-70mm F/2.8 L USM
Canon EF 70-200mm F/2.8 L USM
Olympus C-2020 (for infrared work)
ddelallata is offline   Reply With Quote
Old 3rd of October 2005 (Mon)   #4
blinking8s
blinking8s's Avatar
the 85 is the best bang for your buck i think, its not too expensive, quality and build rock
blinking8s is offline   Reply With Quote
Old 3rd of October 2005 (Mon)   #5
grego
grego's Avatar
Not, if he wants macro capabilities.
Old 3rd of October 2005 (Mon)   #6
tim
Light Bringer
tim's Avatar
If you want or need macro, get the macro lens. I use it for portraits sometimes, it does a great job, so long as you have enough space to use it. The 85mm will be better for low light or narrower DOF. I used the 100mm macro to do this shot, one of my all time favorites. It's an incredibly sharp lens.
tim is offline   Reply With Quote
Old 4th of October 2005 (Tue)   #7
Reminisce
Reminisce's Avatar
The 100 is amazingly sharp, fast, and built like a tank. I use it a lot when Im doing portraits outdoors or anything of the sort. I've also used it at the beach tracking seagulls over my other lenses as it seems to be my fastest and most accurate lens at the moment (L on the way baby!).
If you're even slightly interested in macro, then you should definitely pick it up, it gets really close (1:1 lifesize magnification), focuses really fast, and of course you can get even more magnification with the right tools.
Anthony
Anthony W. Photography | My ModelMayhem Portfolio
5D2 | 5DC | 20D | 24-70L | 135L | 70-200 f4L | 50 f1.4 | 580 EX x2 | 430 EX | Alien Bees | Pocket Wizards
Reminisce is offline   Reply With Quote
Old 4th of October 2005 (Tue)   #8
thw
I had both at one point. Both are equally sharp, but the sharpness of the 100 f/2.8 macro is better than the 85 f/1.8 wide-open. Also, the 100 f/2.8 focuses more reliably on my XT than the 85. When the 85 focuses accurately, it is very impressive. I am keeping the 100 f/2.8 for versatility and focus accuracy reasons.
thw is offline   Reply With Quote
Old 4th of October 2005 (Tue)   #9
genewch
The 100mm macro is a very sharp lens. In dim light, I have the experience that it sometimes hunts. The pictures produced are not as sharp as expected, but it performs excellent in daylight. No idea on 85mm f1.8, but I believe it beats the 100mm macro in dim light due to wider aperture and shorter rotation of the focusing ring.
genewch is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
New 100-400 IS... Sharpness Opinions? rixhobbies Canon EF and EF-S Lenses 25 31st of March 2007 (Sat) 01:37
Sharpness 100/2.8 macro vs 35/1.4 L rwong2k Canon EF and EF-S Lenses 5 28th of May 2006 (Sun) 00:55
ef 100 f/2.8 macro sharpness? Moody Blues Canon EF and EF-S Lenses 7 21st of December 2005 (Wed) 10:45
100-400 L: sharpness, tripod and IS lordjim Canon EF and EF-S Lenses 9 6th of June 2005 (Mon) 21:59
70-200 2.8L @100 sharpness ifurlong Canon EOS Digital Cameras 2 11th of September 2003 (Thu) 22:46
