Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 28th of April 2003 (Mon)   #1
Yongy
Default s230 focus!
i've been using my s230 for quite a while now, althoguh when i use the flash the color is really bright in the front and dark in the back...should i shoot auto, or manual. When shooting manual i turn of the flash for more realistic color but the picture goes blurry. Should i be shooting with ISO set to auto or 50? i'm just so confused. all my people pictures turn out blurry...please help!
Yongy is offline   Reply With Quote
Old 29th of April 2003 (Tue)   #2
khs8
Default Re: s230 focus!
I use the manual mode to turn off AiAF. Everything else is on, including flash. To shoot a sharp focus, your subject has to be inside the centre box on the screen. If you want to shoot where the subject is off centre, you need to pre-focus by holding the shoot button half way down to allow the camera to focus on the subject that you want, and then move your camera (still holding half way down the shoot button) to the scene you desire and then press the button to complete the shot. Another way of doing it is to lock the focus after you pre-focus and then move the camera and shoot as normal. The AiAf is good for most situation if you do not want to go through the pre-focus routine, also, AiAF is ok if your subject is centred or close to centre. You can actually see from the AiAF screen to see if your subject is within the boxes, if it is then it is in focus. I prefer to use manual pre-focus, as the file size is much smaller than AiAF, but I do not understand why the AiAF file size is so much larger.
khs8 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
S230 will not Focus at all rickf1957 Small Compact Digitals by Canon 2 19th of September 2005 (Mon) 07:42
S230 Focus Assist rhibbert Small Compact Digitals by Canon 0 3rd of January 2004 (Sat) 12:49
s230 Manual focus mode? caddis_fly1 Small Compact Digitals by Canon 3 4th of February 2003 (Tue) 00:57
Focus problems with s230 qboom76 Small Compact Digitals by Canon 14 3rd of February 2003 (Mon) 00:02
s230 has better auto-focus?? Beyond4G Small Compact Digitals by Canon 0 10th of December 2002 (Tue) 23:02
