Okay, so I'm using a T2i and I recently got the Canon 50mm f/1.4 USM lens to use in some of the "portrait" style work that I do. At first I was loving the lens as it focused a lot better than the first one I ordered and had to return now I've found a new problem that has me seriously annoyed!
When using the center focus there is a tendency to slightly front focus which wasn't bad as it was still working pretty good for what I wanted it for. Now comes the problem, if you change from the center focal point to any of the other focal points the lens go nuts and front focus as much as a couple feet in front of your subject, subject is about 13 feet in front of my.
Has anyone else had this problem? I mean this is crazy, all my other lenses perform without issue at all but this is just an insane problem that I really don't want to have to deal with anymore. I will be sending it in to canon but still, this is just a strange issue! I tested the camera multiple times to see if maybe there was something else that was causing this problem and after about 15 photos with the same issue coming up I finally said it's got the be the lens as none of my other lenses have this strange behavior.
