#1 |
Hello,
I'm looking to play around with Macro photography on the cheap. Which option would be best suited for the most magnification and highest quality shots between a reversed 50mm or a modded 35-80mm? Thanks!
Canon 550D | 18-55mm f/3.5-5.6 | 55-250mm f/4-5.6 | 50mm f/1.8 | Tamron 200-500mm ●● flickr |
| sponsored links |
#2 |
I havent used either of those but these cheap tubes gave me pretty decent resulsts: http://www.amazon.com/Bolo-Extension...3862007&sr=8-5
Here's a picture of a flower I took with it. Last edited by yobuttin : 26th of April 2011 (Tue) at 19:19. |
#3 |
I find that the reverse 50mm doesnt magnify much, I think reversing gets interesting around 28-35mm
Havent tried the 38-80 trick but regardless the magnification this one will be easier to use due the bright viewfinder |
| sponsored links |
#4 |
If you use 50mm reverse, it gives you 1:1 magnification. When 28mm is used, 50:28= Almost 2:1 magnification
Calculate yourself... But I think prime lenses always give better results.
5D Mark II 135 F 2 L USM 17-40 F 4 L USM 18-55 IS for macro |
#5 |
I like to use a reverse ring on my 18-55.
That'll get you a great amount of magnification. |
#6 |
Wider focal lenghts reversed, like the 18mm will work great, but it will be better with a manual lens for having the control of aperture on the lens barrel itself
#7 |
I went down the modified 35-80mm road and i love it, it has 0.8:1 to 1.8:1 magnification and can get some really nice results
![]() Soap Bubbles by Mark_Watkins, on Flickr ![]() Vine Weevil by Mark_Watkins, on Flickr
Canon 30d | 1000d | Mark |
| Thread Tools | |
| Display Modes | |
| WTB: canon 50mm f/1.4, 80mm f/1.8 | craiglee | Classifieds: Buy | 0 | 14th of May 2007 (Mon) 12:00 |
| reverse mounting a 50mm FD to a 30D? | BiikeMike | Macro | 8 | 5th of March 2007 (Mon) 08:58 |
| Flowers - 50mm lens in reverse | lesleysmeshly | Macro | 2 | 16th of February 2006 (Thu) 05:27 |
| how to reverse a 50mm | the_boy | Macro | 10 | 18th of January 2006 (Wed) 19:06 |
| 50mm f1.8 'Reverse Position'? | Zeke | Canon EF and EF-S Lenses | 4 | 2nd of September 2005 (Fri) 08:56 |
