Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 1st of May 2003 (Thu)   #1
Marley
Default Tripod Suggestions
I'm looking at buying a new tripod and would appreciate any suggestions.
I was interested in the Bogen/Manfrotto but there are so many choices.
With or Without Head included?
3 Way Pan/ Tilt or Ball Head?
It's hard to differentiate while shopping online.
Marley is offline   Reply With Quote
Old 1st of May 2003 (Thu)   #2
justme_dc
Default Re: Tripod Suggestions
with the 10D I generally use the Bogen 3205 tripod with either Bogen 3265 Grip Action Ball Head or the Bogen 3029 Pan/Tilt Head. They are light, inexpensive and pretty much all your need for the 10D unless you have a pile of L series Telephoto lenses. I switch out the heads depending on what I am shooting. Ball head are quick to adjust but hard to be totally accurate with. The 3-way tilt head allows me to repeat angles over and over. Bottom line is that it is personal preference. You also might wanna check out the 3001 tripod, it has the double-positioning vertical and horizontal center column which you may or may not find useful. I don't have that one but if I were replacing the 3205 I have I might give it a look.
I hope this is helpful, Good luck to you.
justme_dc is offline   Reply With Quote
Old 2nd of May 2003 (Fri)   #3
Jon_Anhold
I use a Bogen 3021PRO tripod with a Bogen 3055 ball head w/quick-release.
(the 2nd url is to OneCall.. looks like Bogen may have discontinued this head)
I enjoy using them both.
Jon_Anhold is offline   Reply With Quote
Old 5th of May 2003 (Mon)   #4
Fried
Hi,
I use a Cullman tripod with the Manfrotto 410 Gear head.
I'm pleased with both, bit I intend to buy a Manfrotto Carbon tripod if budget permits.
Fried
Fried is offline   Reply With Quote
Old 5th of May 2003 (Mon)   #5
lziering
I use a Manfroto 440, which is graphite fiber. I also got the magnesium head. It is pretty good and very light.
lziering is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Tripod suggestions please cbr929rrerion Accessories & Storage 5 3rd of June 2007 (Sun) 14:59
Tripod Suggestions Daniel294 Accessories & Storage 18 28th of December 2006 (Thu) 03:54
Tripod suggestions help woollyback Accessories & Storage 3 10th of November 2006 (Fri) 06:19
Tripod suggestions gregjp48 Accessories & Storage 18 25th of July 2006 (Tue) 22:47
Tripod Suggestions Doom1701e Accessories & Storage 13 17th of November 2004 (Wed) 12:24
