Thread started 22 May 2011 (Sunday) 10:24
Longest possible USB cables for tether setup?
Canon_Lover
May 22, 2011 10:24 |  #1
I am trying to get a tethered setup going as long as possible.
The minimum is 25' for my setup. Anything longer would be nice.
Is there a maximum distance for the USB in which it can transmit? If I link multiple cables together, would it start getting a lack of signal? The longest cable I have found so far is 25' mini USB to USB .
Also, what about a netbook with battery life over 8-10 hours? Anyone have any recommendations for one which can also run Canon DPP for tethering? As I understand, DPP requires 768 resolution. Aren't there ways to fake the higher resolution?
I'm looking at the ASUS UL30Vt X1K - Core 2 Duo 1.3 GHz - 13.3″ notebook, as it has 768 and long 10+ hours battery. Is there anything smaller? Or is this as small as I can go with retaining resolution and batter life?
Thanks for any help you can provide!
CL
My 500PX (external link)
John ­ Schell
May 22, 2011 10:27 |  #2
I transmitted via a 25' cable to my MBP and then directly out to a external hard drive. Not a single problem.
Website (external link) || Instagram (external link)
MGW172
May 22, 2011 10:29 |  #3
15 feet is the recommended lenght unless you connect it to a powered hub or powered extender.
And I just bought a Asus similar to what you describe for my wife.....getting about 7-8 hours of use (web, office.....light stuff) on a charge.
7D | 20D | Canon 10-22 | Canon 15-85 | Canon 70-300 L | Canon 100-400 L
Canon_Lover
May 22, 2011 10:49 as a reply to  @ MGW172's post |  #4
Cool, thanks for the feedback guys, I found the info I needed.
I will probably buy several extra batteries for the notebook just in case.
I plan on doing some BBC planet earth style setups and need to retain the control of the tethering, but gain as much distance as possible.
I looked, but are there no wireless setups that allow camera exposure controls along with live viewing?
I'm getting a little too OT, but what about wireless controlled 2-3 axis camera gimbals? A buddy at work apparently makes the best ones for RC planes and helicopters, but they cost $2500. His are called Triax or something like that. Hope to not have to spend that much, as I don't need stabilization.
Canon_Lover
May 22, 2011 10:54 as a reply to  @ Canon_Lover's post |  #5
I found this extender which claims 150 feet.
I gains power from both ends. Would the camera provide the necessary power in this setup? OR do I need something different? I need to be able to use this out in the woods, so no AC power will be available.
http://www.vpi.us/usbc​5.html (external link)
B Extender, 1-port, 150'
Extend One Self-Powered or Bus-Powered USB Device up to 150 Feet.
* USB-C5-LC extends one USB device up to 150 feet.
* Compatible with USB PC, SUN and MAC computers.
* Compliant with USB 1.1 specifications.
* Local unit: One male USB Type A connector.
* Remote unit: one female USB Type A connector.
* Power
o Local unit: powered from attached computer.
o Remote unit: powered from USB computer attached to local unit.
* Package Includes:
o Local unit with 10 inch male USB Type A cable attached
o Remote unit
* Dimensions WxDxH (in.): 1.2x2.2x0.8
* Use CAT5/5e/6 UTP straight through cable for TIA/EIA-568B wiring terminated with standard RJ45 connectors (not included).
Sports_Dude
May 22, 2011 11:12 |  #6
Check monoprice. There are a couple of USB extenders towards the bottom of the page.
http://www.monoprice.c​om ….asp?c_id=102&c​p_id=10303 (external link)
Sports_Dude
7D Gripped | 17-55 f/2.8 IS | 70-200 f/2.8L IS | 100-400 f/4.5-5.6L IS II | 580EXII
Canon_Lover
May 22, 2011 11:53 |  #7
Sports_Dude wrote in post #12457181 (external link)
Damn, that's just the ticket!
Sweet! I think I've got a bunch of ethernet cable lying around somewhere. 150 feet would be super sweet. Although that distance will probably drop a lot once I use it in the cold weather.
This is going to be one heck of a sweet setup! The only missing link now, is finding a decently cheap 3 axis gimbal, or just sucking it up and buying the $2500 one which is super lightweight and autoservo stabilized.
J.Doe
Joined Mar 2011
May 22, 2011 16:13 |  #8
Canon_Lover wrote in post #12456989 (external link)
You might replace your netbook/laptop "classic" HDD with a SSD.The best ones (Mushkin,G-Skill) aren't cheap but they make a big difference,energy consuming-wise as well as working speed.
Also,you might want to shut off or limit some of the netbook's hardware (e.g. WiFi) if you really don't need them at a given moment...this shall prolong your battery life even more.
HTH!
Regards,
60D,MKIIn,Ds MKIII __EF 50 f/1.4,EF 100 f/2.8 macro,EF 135 f/2.0L,EF 16-35 f/2.8 L II,Tamron 28-75 f/2.8,EF 70-200 f/2.8L,Tamron 70-300 f/4-5.6 VC USD ,EF 2xII TC__Marumi clear glass,UV,ND & CPL__ Kata bags__Speedlite 580EX & Metz 58 AF-2 w/Eneloops__ Sandisk __Vanguard Alta Pro 263AT & TRACKER AP-364 w/SBH-300's
trekkiestud
May 22, 2011 22:39 |  #9
CL
Use this USB Super Booster Cat5 Extender and you can extend your tether 150'. I use it and it works as claimed. 150ft might be pushing it, I use mine with 100' cat 5 cord and have no problems whatsoever.
Also, for your Asus UL30Vt X1K make sure to get an extra extended battery,here's one and you won't have to worry about running out of power.
5D Mark III Giveaway on Facebook (external link)
Kamilbas
Joined Jun 2011
Jun 04, 2011 06:04 |  #10
you will not see any lack in speed unless you get an extension over 100m
You have to think outside the box to improve your photography.
Photography is your viewpoint and you're in charge of it.
365 (external link)
5,738 views & 0 likes for this thread
version 2.0 /
Latest registered member is benbodey
750 guests, 415 members online
