#1 |
Heres a shot of a waterfall I took today. I'm just new to taking landscape shots, I'm a bit disappointed at the blown sky area in the middle area of the photo at the top..
Iso 100, F22, Sh 5.2sec Any offer suggestions on how to fix this in photoshop, I've tried the selective colour option, but it doesn't improve things that much... Thanks |
| sponsored links |
#2 |
If it were me, I'd probably just clone the vegetation over the white sky. Much easier and it will look better too.
#3 |
Try and go back later in the day or when it's bright but overcast.
| sponsored links |
#4 |
and/or use a split neutral density filter.
#5 |
I used a ND8 filter as I couldn't get the shutter speed slow enough, I also used spot metering... I should have shot in raw also but had my cam set to jpg only ...
#6 |
Otherwise nice image. Nice waterfall. Where is this? Wonder how a polarizer would work with that ND8?
Also, if you have lightroom my guess is you can mask that area and use a preset to get that sky blue. Search for free presets as well there are many out there that can fix that.
Canon 5D Mark II | Canon 7D Canon EF 70-200mm IS F2.8L | Canon EF100-400mm f4.5-5.6L | Canon EF 24-105mm f4L | Canon EF50mm f/1.4 Canon 85mm F/1.8 | Sigma 24-60mm f2.8 | Sigma 12-24mm F4.5 - 5.6 www.customsportphotos.com Last edited by billshack : 25th of May 2011 (Wed) at 09:10. |
#7 |
Thanks guys any tips would be great, This is shot just outside of Richmond in North Yorkshire, UK.
If I had to do the same shot again how would I prevent the sky being blown out, use different metering mode, or recompose the shot , or just underexpose some of the shots? |
#8 |
perhaps an even stronger ND or as i suggested you can try a polarizer to add contrast but not sure how a polarizer combined with an ND would work.
Oh.. i think you can buy a graduated ND filter. Maybe darker on the upper half.. or take two pics. One normal exposure or even under exposed and then take your 2nd shot with the ND and use photoshop to layer them. Then bring out the darker sky with a mask.
Canon 5D Mark II | Canon 7D Canon EF 70-200mm IS F2.8L | Canon EF100-400mm f4.5-5.6L | Canon EF 24-105mm f4L | Canon EF50mm f/1.4 Canon 85mm F/1.8 | Sigma 24-60mm f2.8 | Sigma 12-24mm F4.5 - 5.6 www.customsportphotos.com |
#9 | |
Thanks |
#10 |
Definitely shoot RAW as you gain a stop or two of dynamic range, which well help with the blown sky. Also go back when the sun is angled the side or behind you. And you should get a darker ND filter than a 3-stop, which will help to avoid using such narrow apertures (lot of softness from diffraction). I use a 6-stop and find it not dark enough sometimes.
Canon 5D Mk II (35/1.4L | 24-70/2.8L | 135/2L | Euro Nifty | 430EX II | Gitzo G1125 + 494RC2) flickr I bought a new camera. It's very advanced - you don't even need it. ~Steven Wright |
#11 |
The split/graduated ND will allow you to darken just the sky area. Very handy purchase if you plan on doing a lot of landscape work.
#13 | |
Robert Canon 40D | Canon EOS Elan 7 |
| Thread Tools | |
| Display Modes | |
| NY Waterfall need C&C | marjnap | Critique Corner | 10 | 18th of June 2008 (Wed) 22:38 |
| Which waterfall? | troyer16 | Nature & Landscapes | 3 | 19th of May 2008 (Mon) 18:35 |
| Waterfall | gears | Nature & Landscapes | 9 | 17th of January 2007 (Wed) 16:00 |
| Waterfall B&W cc please | SezzySue | Still Life, B/W & Experimental | 8 | 18th of February 2006 (Sat) 09:00 |
