Thread started 02 Jun 2011 (Thursday) 18:20
Prev/next
Canon Rebel EOS XS - Aperture question
SolEterna
Joined Jun 2011
Canada
Jun 02, 2011 18:20 |  #1
Hi All,
I have just bought myself a new lens and started to learn more and more about my camera. I'm loving it and it's fast becoming my hobby. I almost cannot wait to get outdoors to get an opportunity to take photos.
I have recently started using the M mode on my Rebel XS as I have been taking evening photo's and over-exposing them with some good results here and there. My issue is that sometimes in manual mode I can set my aperture to 3.5 and then I take the photo, however, my camera then seems to move the setting back to around 5.6.
I then try to change the aperture setting back to 3.5 and it will not do it. For some reason I cannot seem to take advantage of the 3.5 aperture setting.
I am using the Tamron 18-270mm VC Model B003 F/3.5-6.3 Di II VC LD Aspherical [IF] MACRO lens. While this lens is great and possibly more than I need for my little entry level Rebel EOS XS, I wanted a lens that gave me a relatively wide angle and zoom capabilities without compromising on the aperture options. My camera is also capable of handling the aperture settings, but it keeps defaulting to 5.6 and will then not allow me to change it.
Please can anyone offer me some advice on this?
If you need any further information on this, please let me know.
P.S. As mentioned, I'm trying to over-expose my images at night. Using shutter speeds between 15" - 30" and trying to use the maximum possible aperture on my lens. My pictures are being taken late at night when there is very little natural light.
“In life, unlike chess, the game continues after checkmate” - Isaac Asimov (Lenses: Canon EF 50mm 1.8, Tamron AF18-270mm F/3.5-6.3 Di II VC PZD, Canon EF-S 18-55mm f/3.5-5.6 IS)
GreenBox
Joined Apr 2011
Jacksonville FL
Jun 02, 2011 18:25 |  #2
its your lens.
your tamron has a f3.5-6.3 which means that as you zoom the maximum aperture will change.
so the only way you can change it is to get a quicker lens.
Canon T2i gripped
18-55mm kit
50mm F1.8
pro-optics 8mm
SolEterna
Joined Jun 2011
Canada
Jun 02, 2011 18:29 |  #3
Okay, so when you say quicker, what exactly are you talking about??
Does this mean that when I am at a large zoom the aperture will not allow me to go to 3.5??
Also, is there any way to compensate for this??
chrisandaivi
Virginia Beach
Jun 02, 2011 18:29 |  #4
^ he's right It's not you, it's your lens It's not a constant aperture lens. For example it's not a constant F4 or a F2.8. Those kind of lenses eventhough you zoom the aperture will not change, It will be constant F4.
Gear: 5D Mark II, Canon 85mm 1.2 L ,Canon 17-40mm F4L
Canon 24-70mm F2.8L, Canon 70-200mm F4L
580 exII x2
Rf602 triggers
Etc, Etc, ETC
PLLphotography
with the TF
PLLphotography's Avatar
VA
Jun 02, 2011 18:31 |  #5
you can't with your current lens.
faster lens means a lens with a wider aperture (f/2.8, 2.0, 1.8, 1.4, etc.).
the only way you can have a constant aperture on your current lens is if you set it to 6.3, then you can zoom throughout your entire focal length, and your aperture won't change :-)
Phillip - pllphotography.com (external link) | Instagram (external link) | Donate to POTN | Fuji X Gear
GreenBox
Joined Apr 2011
Jacksonville FL
Jun 02, 2011 18:32 |  #6
SolEterna wrote in post #12525017external link
quicker meaning a constant aperture value like what chrisandaivi said.
when you're at full zoom, you're aperture will be at 6.3, no matter what you do. that's the limitation of your lens
the only way to compensate would to get a better lens.
Canon T2i gripped
18-55mm kit
50mm F1.8
pro-optics 8mm
SolEterna
Joined Jun 2011
Canada
Jun 02, 2011 18:35 |  #7
Okay, thanks everyone. So perhaps a 50mm prime lens would be a better option??
I will try using the 6.3 aperture and see if I get a good effect or not. Either way, the pictures are still coming out relatively well overall. Your comments make complete sense though. Thanks again everyone.
Great forum and the feedback is quick and poignant.
PLLphotography
with the TF
VA
Jun 02, 2011 18:36 |  #8
look for lenses that don't have a "range" of f-stop values...
such as Tamron 28-75mm f/2.8, or Tamron 17-50mm f/2.8
your lens - Tamron 18-270mm VC Model B003 F/3.5-6.3 Di II VC LD Aspherical [IF] MACRO, has a variable aperture.
PLLphotography
with the TF
VA
Jun 02, 2011 18:37 |  #9
you have to keep in mind, your aperture, ISO, and shutter speed all play a part in your photos.
setting your aperture to 6.3 will greatly decrease the amount of light getting to your lens, which will reduce your shutter speed considerably. the only way to compensate for that is to bump up your ISO, which will introduce noise into your photo.
if you want a prime, check out the 50mm f/1.8. it's cheap and has a maximum f/1.8 aperture. it's no zoom obviously, but it's a great lens to learn with.
WayneCornish
Joined May 2011
UK
Jun 02, 2011 18:39 as a reply to GreenBox's post |  #10
Everyone else beat me to it but here are the focal length/apature values for your lens:
18-29mm f/3.5
30-45mm f/4
46-58mm f/4.5
59-90mm f/5
91-237mm f/5.6
238-270mm f/6.3
Currently Using - Fujifilm X-E1 | XF 18-55 f/2.8-4 R OIS || Bodies Owned - Canon 1DS II | 5D MKII | 7D | 50D's | 40D's | 450D | 350D | Lenses Owned - Canon 17-40 f/4L | 24-70 f/2.8L | 24-105 f/4L IS | 70-200 f/2.8L IS MKII | 70-200 f/4L IS | Sigma 85 f/1.4 | Many other lenses and film bodies/lenses.
SolEterna
Joined Jun 2011
Canada
Jun 02, 2011 19:00 |  #11
So, to sum it up then, I can either shoot with my current lens between 18-29mm which will give me the best possible aperture on my lens, OR, I can get a lens with a fixed aperture?
Would a fixed aperture lens not "limit," the opportunities to take photos?? Sorry about all the questions, but I really am a newbie at this and want to learn. You have all been a great help so far.
PLLphotography
with the TF
VA
Jun 02, 2011 19:04 |  #12
that's what the forum is for, questions and answers :-)
yes, if you wanted the absolute widest aperture of your current lens, you are restricted to the above-mentioned focal lengths.
fixed aperture lenses will not limit you in the sense of you picking an aperture and it changing on you. once you set it, it's set until you change it.
aperture affects depth of field, the amount of light that comes into your lens, which affects shutter speed, etc. the wider your aperture, the more light, the higher the shutter speed, which may help reduce camera shake (lens blur), and allow you to take photos in lower light.
the cheapest lens you can get with a fixed aperture is the "nifty fifty", 50mm f/1.8. you can usually find them used for around $100 here on the forum.
PLLphotography
with the TF
VA
Jun 02, 2011 19:06 |  #13
take a look at these free online videos.
aperture values
http://www.adorama.com ...es-Adorama-Photography-TVexternal link
depth of field
http://www.adorama.com .../Depth-of-Field-AdoramaTVexternal link
nifty fifty
http://www.adorama.com ...th-the-Nifty-50-AdoramaTVexternal link
SolEterna
Joined Jun 2011
Canada
Jun 02, 2011 19:09 |  #14
Thanks PWard,
As I am new to all of this, I want to learn everything I can :-) There is so much to learn and so many different options and features.
I guess the bottom line is to play around with the features until you get used to specific settings on your camera in certain situations, etc.
Thanks again
PLLphotography
with the TF
VA
Jun 02, 2011 19:11 |  #15
read the camera manual....re-read it. practice, practice, practice. it's digital, no film expenses to worry about :-)
the links I gave you have a LOT more videos on the left-hand side if you look. Adorama is a pretty great source of info.
and of course, search for your answers through this forum. search feature is great.
6,527 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00226 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is Andrew1031
933 guests, 428 members online
