#1 |
Hey Y'all!!
as i said in another thread, i am renting a 70 - 200mm f2.8 L IS lens with 1.4x extender by canon this weekend to take to a huge airshow in san diego. it comes with a polarizer and a UV filter. my question is if you have any tips on shooting with it like which filter to use (if any), whether to use Av, Tv mode (or other), is the 9 point AF ok or do i change something there?... and anything else you might want to suggest to someone who is still learning and has never tried shooting moving aircraft. i have recently been playing around with the aperture priority mode shooting fall colors with the lens i own (canon 24 - 85 USM) i'll be sure to post what i get after the show!!! thanks and best regards, -blake |
| sponsored links |
#2 |
I tend to use centre point focus for single planes (multi-point for formations).
I use AV mode for jets above horizon (i.e. just sky in background) and set aperture to give around 500th/640th or so depending on lighting (aim to be around f/5.6-f/8.0 depending on light for DOF). Tv mode for props and jets take-off/landing/low-pass panning shots (usually 160th-200th or as low as 20th depending how brave you feel / panning technique). Flick between the 2 modes depending what's coming. Use IS mode 2, AI Servo mode & lowest ISO possible (I don't use a filter). Good luck, enjoy the show & post your best! (The above information is not necesarily the best, but it's what I use & hope it helps!) Click for larger.... ![]() 1/640th @ f/8.0 ![]() 1/160th @ f/14 ![]() 1/20th @ f/2.8 (ISO1600 - yes it was very dark
EOS 40D | BG-E2N | EOS 30D | BG-E2 | EF 50mm f/1.4 USM | EF-S 17-55mm f/2.8 IS USM | EF 70-200mm f/2.8L IS USM | EF 300mm f/4L IS USM | Extender EF 1.4x II | Tamrac Model 5575 Expedition 5
flickr sets |
#3 |
should have taken his own advice
I'll be out at the Miramar Air Show, as well, and will try some of those tips.
Thanks! Steve |
| sponsored links |
#4 |
I gave it my best shot at my 1st air show this summer. Learned a lot.
Used an XT, 70-200 f/4. It was hazy, so I wish I had a filter. Learned that 1/800 sec. is way too fast for propellers; it virtually stops propellers and just doesn't look as good as blurred propellers. See Dew's post above. ![]() Lesson learned on panning: Panning with the F-18 from left to right resulted in the other F-18, flying right to left, turning out blurry. Exposure was 1/1000 sec. I would like to try the same panning technique with an even faster shutter. ![]() Don't get me wrong, I am pleased with they way some turned out. ![]() BTW, Dew, I really like your shots. Hope this helps. -KK
___________ _____ DrebelXT, BG-E3, 24-70L, 70-200 f/4L, 580-EX, Bogen 3021BPRO, Kirk BH-3, Lowepro Nova 3 AW |
#5 |
Thanks Kurt! You got a nice angle on Fat Albert there!
flickr sets |
#6 | |
Moderator
Cocker Spaniel Mod Join Date: Jun 2004
Jon ---------- EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan Cocker Spaniels Maryland and Virginia activities DC Cherry Blossoms Image Posting Rules and Image Posting FAQ Report SPAM, Don't Answer It! (link) PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED. |
#7 |
![]() ![]() this is with a 70-200 on a 20D. You'll have tons of sunlight, so bump the f-stop down to around F10 or so and leave it in AV mode. You'll have more than enough shutter. Honestly though, even with the 1.4x converter, you might not be long enough to take some good shots. I use centre point focus on all my shots. Shoot in raw b/c you can adjust later. If you're renting a lens, try to see if you can get something in the 400mm range with IS |
#8 |
Hi
Some nice shots there. Only tried airshow shots once but I found that the camera tended to underexpose the shots. Check the pictures carefully after you shoot them and be prepared to play with the exposure compensation. All the best Keith |
#9 | |
EOS 20D w/ BG-E2 Canon EF-24mm f/2.8 Canon EF-50mm f/1.8 II Canon EF-85mm f/1.8 USM Sigma 24-70 EX DG Macro Sigma 50-500 EX DG HSM w/1.4x EX Sigma EF-500 DG Super w/BB Manfrotto Mono(681B) & Tripod(3021PRO) w/Gimbal Image Tank G2 OTG 40GB |
#10 |
Maybe the attached link can help you
http://photography-on-the.net/forum/...d.php?t=103268 As you are renting the lens, if would rent a longer lens Be there in time and find an nice spot (sun in back for long time.) Read the programm carefully I use to shoot in AV mode f8.0 till f16 Shutterspeed is important and to be save use Iso 200 (sunny) or 400. Make some photo's of the sky/clouds and check the histogram. You can use a filter but is is not necessary. As you have an IS lens put the Is mode on 2. Use the AF center point. Keep both eyes open and keep checking the sky/sound Keep reading the histogram Enjoy the show! |
#11 | ||
#12 | |
Great idea. I agree...that would be dramatic. Just wish I knew when I'd have the next opportunity to try it out. -KK
#13 |
I have been to many of the Miramar airshows and will be there tomorrow with my dad and son.
I have yet to decide if I am to bring the 10d with just the 50 or my Mk2 with the 70-200. I'll have a desert camo boonie hat and camel bak with a POTN strap if I bring the Mk2. Here are some Miramar 2004 shots: http://www.palomarpics.net/PhotoShop...2004/index.htm Kent
1DMKII, 10D, 300 2.8, 70-200 2.8 IS, 17-40 F4L, 50 1.8, and lots of other STUFF... PalomarPics.Net |
#14 | ||
flickr sets |
#15 |
I always use a monopod with my 100-400 at airshows, slow the shutter speed right down for props (as low as you dare!). These were taken at Duxford over the last 12 months. The "Reds" using my 10D, "Frankie" with my 20D.
"Hey, ipsa this....." 1DMkIIn, 10D+Grip, 20D+Grip, 17-40f4L, 70-200f4L, 70-200 f2.8L IS, 24-105f4L IS100-400L IS, 300f4L IS, 50 1.8MkII, 1.4EX II, 420EX, 580EX, G9 |
| Thread Tools | |
| Display Modes | |
| Airshow lens tips... | 3Turner | Transportation | 15 | 4th of November 2006 (Sat) 19:04 |
| Can I get some tips for shooting an airshow? | TMR Design | Small Compact Digitals by Canon | 5 | 24th of August 2006 (Thu) 17:20 |
| Tips for airshow pics appreciated... | emtp563 | The Business of Photography | 9 | 29th of June 2006 (Thu) 23:24 |
| Tips to shoot airshow | Amorous | Transportation | 16 | 17th of May 2006 (Wed) 15:04 |
| Tips on shooting @ the Airshow | Tyger | General Photography Talk | 2 | 2nd of September 2005 (Fri) 17:42 |
