Thread started 04 Jun 2011 (Saturday) 10:56
Unexplained Phenomenon.
Acquiesce
Jun 04, 2011 10:56 |  #1
Guys,
need your help. i have shot a few of the same shots and now noticed that there's a green dark shadow.
these test shot are at H1 ISO and all with the same settings.
I would probably guess its time to service the camera body or change the shutter mechanism. Your thoughts?
IMAGE: http://farm3.static.flickr.com/2298/5796444323_ed0b5e0632_z.jpg
IMAGE: http://farm3.static.flickr.com/2607/5796447663_a0ecf264c0_z.jpg
IMAGE: http://farm3.static.flickr.com/2754/5796450179_1a3a7fb0f7.jpg
jackies35
Jun 04, 2011 11:02 |  #2
What camera and lens? Check and change the shutter mechanism...most likely
Just a Christian passing by Event Photography.......
www.pictureme2.com (external link) & www.twitter.com/pictur​eme2 (external link)
Nikon D7000 18-105 mm f3.5/50 mm f/1.4
Rebel XT
/50mm f1.4/Sigma 17-70mm f2.8
yogestee
Jun 04, 2011 11:05 as a reply to  @ jackies35's post |  #3
No problems at all.. It's just the cycling of the lights.
A very common phenomenon.
Jurgen
50D~700D~EOS M~G11~S95~GoPro Hero4 Silver
Sdiver2489
Joined Sep 2009
Jun 04, 2011 11:10 |  #4
yogestee wrote in post #12534984 (external link)
^ this
Please visit my Flickr (external link) and leave a comment!
Gear:
Canon 5D III, Canon 24-70L F4 IS, Canon 70-300L F4-F5.6 IS, Canon 100mm F2.8L IS Macro, Canon 35mm F2.0 IS, Canon 430EX II-RT, Canon 600EX II-RT
Acquiesce
Jun 04, 2011 11:12 as a reply to  @ yogestee's post |  #5
@jackies35: 5dm2+24-70
yogestee: some of the photos taken has really ugly green banding as if the floor is lighted with a green gel. :(
cjd
Jun 04, 2011 11:15 |  #6
Assuming it's fluorescent lighting, that is what yogestee has said: cycling of the lights.
5D II, 30D, Sigma 50 f/1.4, Sigma 85 f/1.4, Rokinon 14 f/2.8, Sigma 24-70 f/2.8, Tamron 17-50 f/2.8, Sigma 70-200 f/2.8, Sigma 10-20 f/4-5.6, Sigma 2x, Kenko 1.4x, Kenko 36mm,20mm,12mm tubes
MARK1992
Jun 04, 2011 11:16 |  #7
Acquiesce wrote in post #12535009 (external link)
Florescent lighting. It isn't the floor that's green. It's just coincidentally that the green band is over the bit of floor in your picture. :p
Decrease shutter speed until it's lower than the cycling rate and it should disappear (I think).
dpds68
Jun 04, 2011 11:17 |  #8
Was your main light Florescent lights ? if so they cycle at a certain rate and you need a shutter speed to compensate for the lights or shoot RAW and fix in post .
At this time I cant remember the shutter speed that will help
David
Edit : or use your flash to overpower the Florescent lights .
Gripped Canon 7D,20D,XT / Tamron 17-50mm 2.8, Canon 85mm f1.8 , 70-200 2.8L,EF50mm1.8 II,Sigma 150-500mm OS, Sigma 105mm 2.8 Macro, Sigma 10-20mm 4-5.6
Vivitar285Hv x2,Canon430EX,Nissin Di866,CTR-301P Triggers,
http://www.flickr.com/​photos/dpds68/ (external link)
Acquiesce
Jun 04, 2011 11:27 as a reply to  @ dpds68's post |  #9
Thanks guys. i ran some further tests and found the following results
the shots are mostly on H1 ISO setting and that will 'attract' the recycling of lights effect, well it kinda made me realized that "thats why its called ISO sensitivity" :o
anyhow thanks for the pointers. really appreciated it! Cheers!
Sdiver2489
Joined Sep 2009
Jun 04, 2011 11:40 |  #10
Acquiesce wrote in post #12535064 (external link)
It'll only happen with fluorescent lights
Gear:
airfrogusmc
Gallery: 122 photos
Jun 04, 2011 11:43 as a reply to  @ Sdiver2489's post |  #11
I work in fluorescent lighting all the time and if you shoot at 1/15, 1/30/ 1/60 and 1/125 you will avoid the frequency cycles but no higher than 1/125 but at even shutter speeds of 1/8, 1/15, 1/30 and 1/125 you should be OK.
Woodworker
Jun 04, 2011 13:31 |  #12
jackies35 wrote in post #12534964 (external link)
What caused you to tell him that? As others have pointed out, it's caused by the recycling of flourescent lighting.
David
David
Hermeto
Jun 04, 2011 13:44 |  #13
Woodworker wrote in post #12535600 (external link)
Nikon! ;)
number ­ six
"After 40 years still not housebroken, I still piddle on the carpet"
Jun 04, 2011 15:17 |  #14
airfrogusmc wrote in post #12535153 (external link)
Yes. If you're in North America, that is, where the power line frequency is 60 Hertz.
Elsewhere it's probably 50 Hz, and the speeds would be 1/100, 1/50, 1/25.
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
I do not piddle on the carpet!
S.Horton
I'm having size issues, does this get worse with age?
Jun 04, 2011 15:26 |  #15
Sdiver2489 wrote in post #12535000 (external link)
^ this
^that
See this:
http://photography-on-the.net/forum/showthre​ad.php?t=308607
Sam - TF Says Ishmael
:cool:
2,761 views & 0 likes for this thread
version 2.0 /
Latest registered member is fishesman
698 guests, 413 members online
