#1 |
I have really only done landscapes and architecture - my experience doing portraits is very limited. Will I be okay with these lenses?
15-85 IS USM 50 1.8 prime 100mm 2.8 macro Will I need to rent a 35mm? Any other tips? What time of day is best? Start a couple of hours before sunset? I don't have any lighting equipment. |
| sponsored links |
#2 |
Your current line up will be more than sufficient for an e-session. Obviously avoid harsh midday sun at all costs since you don't have lights. This time of the year I'd shoot around 6-9PM for some of the best light.
#3 |
those lenses are fine; try the 100mm and the little 50. you might be amazed at what they can do.
| sponsored links |
#4 |
try 50mm 1.8 prime or100mm 2.8 macro for the great sharpness
#5 |
Use the 100 set at 2.8 as much as possible. Set them up and have them interact with each other while you grab the shots.
A couple hours before sundown is a great time to shoot. Make sure that your subjects are either in the shade or are between you and the sun as much as possible. The sun will make for a great hair light. Keep a dark background though so that everything isn't blown out.
Herrington Wedding Photography 5D3 | 5D2 | 40D | 70-200 2.8L ii | 16-35 2.8L ii | Tamron 24-70 2.8 | 135 2L | 85 1.2L | 50 1.2L | 24 1.4L | 600EX-RT (3) | 580EXii |
| Thread Tools | |
| Display Modes | |
| Engagement Photos | mjvincent | People | 5 | 13th of January 2009 (Tue) 15:11 |
| Engagement photos CC | TheBigOne | Critique Corner | 4 | 4th of January 2009 (Sun) 22:14 |
| Engagement Photos | calmik | People | 9 | 31st of May 2007 (Thu) 12:30 |
| My first engagement photos... | xmacvicar | People | 4 | 10th of November 2006 (Fri) 03:05 |
| Engagement photos | lightwrite | People | 11 | 13th of April 2006 (Thu) 09:15 |
