Thread started 27 Jun 2011 (Monday) 07:27
7D+100-400+2xlll Extender
jiimybelll
1 post
Jun 27, 2011 07:27 |  #1
Trouble with AF, 100-400 lens listed to work with the 2x,
any help would be greatly appreciated,
Jim
1Tanker
Jun 27, 2011 07:49 |  #2
What's your trouble.. won't auto-focus? The 100-400 won't AF on any camera with a 2x extender, and only on 1-series bodies with a 1.4x(unless you tape the contacts).
Kel
Gear
phreeky
Jun 27, 2011 08:05 |  #3
What he said ^^^
Except it should AF in liveview, if you really need it. But in my experience the results in liveview aren't consistent if you can't stop the wobble (i.e. on very steady support).
Silverfox1
Jun 27, 2011 11:32 as a reply to  @ phreeky's post |  #4
AF definitely wont work but MF will with & without support as depicted below.
5D MKII + 400L prime + Kenko 2x MC4 DGX at 800mm/f11.0 + monopod :
http://photography-on-the.net …p=12549321&post​count=1850
7D + 100-400L + Kenko 2x MC4 DGX at 800mm/f11.0 + handheld :
http://photography-on-the.net/forum/showthre​ad.php?t=983021
I primarily limit my personal use to the 1.4 TC and tape the pins on any fixed f5.6 lens but it can be fun to play around with the 2X extenders when ambient lighting conditions are favorable to achieve some success using MF.
Regards, ;)
Silverfox1 POTN Feedback / TC Extender Tests / Gear List
bpark42
Jun 27, 2011 11:56 |  #5
jiimybelll wrote in post #12664085 (external link)
Jim
First, I would stay away from using a 2x converter on the 100-400. The image quality will suffer significantly, especially on the 7D.
Anyhow, the 7D will not autofocus if the max f-stop of the attached lens is higher (smaller aperture) than f5.6. With a 2x TC on the 100-400 your f-stop is effectively f11 so you are out of luck. Even with a 1.4x you would be at f8 and still out of luck.
Your only option is to tape the pins to prevent the converter from reporting itself to the camera. If you do this the camera will attempt AF but it may not work very well since not enough light is getting to AF sensors.
Oh, and the fact that the converter is listed as "compatible" with the 100-400 simply means that it fits and can be used. It does not mean AF will work.
Jim ­ K
Jun 27, 2011 15:33 as a reply to  @ bpark42's post |  #6
I don't think that was Canon that said the 2x converter would work on the 100-400, at least without saying it won't autofocus.
Canon: 7D (2, 1 gripped), 50D gripped, 500 f/4L IS, 100-400 L IS, 70-200 f/4L IS, 28-135 IS, 10-22, 15-85 IS, 1.4x II, 580EX
5D3, 24-105 f/4L IS, 17-40 f/4L IS, TS-E 24 f/3.5L II. S100 p&s
Gitzo GT3530LS, Wimberley ver. II. Manfrottto: tripod 055XPROB legs, 448RC2 head; monopod 679B, 234RC tilt head
phreeky
Jun 27, 2011 18:07 |  #7
bpark42 wrote in post #12665334 (external link)
It's rarely the amount of light that is the problem, it's the aperture being too small and the way phase detection works that is the real problem.
cc10d
Joined Jan 2004
Jun 27, 2011 23:10 |  #8
I love my 100-400, but I do not use telextenders with it. Too much hassle for poor performance. I just crop the native lens and feel it works as good as or better than the poor performance with a converter, especially the 2x. Now the 400 f2.8L may take a 2x ok, but then one needs a tripod and a large first cost,, so I just get what I can without converters and realize it is still the best performing lens in its class. :)
cc
2,094 views & 0 likes for this thread
Latest registered member is jainlemos
771 guests, 428 members online
