Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 5th of May 2003 (Mon)   #1
PacAce
Moderator
PacAce's Avatar
Default Modelling flash with 10D & 420EX??
Has anyone fired a modelling flash with the 10D and the 420EX by pressing the DOF button?
The 420EX manual says that a modelling flash can be fired with the D30 and the D60. And the 10D manual makes reference to firing a modelling flash using the 550EX.
Since there is no specific reference to being able to do this with the 420EX attached to the 10D, I'm not sure if it's possible or not. All I know is that when I try it nothing happens when I press the DOF button.
Thanks.
...Leo
PacAce is offline   Reply With Quote
Old 6th of May 2003 (Tue)   #2
bluebomberx
bluebomberx's Avatar
Default Re: Modelling flash with 10D & 420EX??
It works with my Sigma EF 500 DG Super. I don't know why it wouldn't work with the 420EX. Are you in the basic or creative modes? It may only work in the creative modes (P, Tv, Av, M, and DEP).
-Richie
flickr
bluebomberx is offline   Reply With Quote
Old 6th of May 2003 (Tue)   #3
PacAce
Moderator
PacAce's Avatar
Default Re: Re: Modelling flash with 10D & 420EX??
-Richie
I tried in P, Av and M modes and it didn't work in any of these settings. I'm going to give it one more try after resetting all my custom settings just to make sure it wasn't due to something I set. If it still doesn't work, I'll give Canon a call to determine which unit might be at fault, the 10D or the 420EX.
Thanks.
...Leo
Old 6th of May 2003 (Tue)   #4
Murf
switch your flash to slave mode, and then push the DOF preview. kinda strange without a master....but it works??
good luck!
Murf is offline   Reply With Quote
Old 7th of May 2003 (Wed)   #5
Morden
All this time, I thought that my 420EX was incapable of firing a modelling flash!
Thanks for proving me wrong!
Morden is offline   Reply With Quote
Old 7th of May 2003 (Wed)   #6
PacAce
Moderator
PacAce's Avatar
good luck!
Yup, it worked, exactly as it said in the manual. Thanks, MURF.
I guess what threw me off was that at the bottom of page 30 (for modeling flash), it says "For depth-of-field preview with the camera, first set the 420EX's wireless select to , then press the depth-of-field preview button." And that's exactly what I did, which obviously doesn't work.
...Leo
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
420EX and flash bracket for 10D jimwong Small Flash and Studio Lighting 7 9th of August 2004 (Mon) 08:59
10D Flash vs. 420EX dsze Small Flash and Studio Lighting 4 18th of July 2004 (Sun) 02:49
Underexposure using a 420EX flash on the 10D hhelmbold Small Flash and Studio Lighting 50 30th of April 2004 (Fri) 14:48
Flash compensation with 10D, 420EX & Omnibounce ??? J.A.F. Doorhof Small Flash and Studio Lighting 4 26th of December 2003 (Fri) 15:00
