Reply
Thread Tools Display Modes
Old 5th of July 2011 (Tue)   #1
nishywishy
nishywishy's Avatar
Default Tokina 100mm Macro vs. Canon 100mm Macro
I'm looking for a new lens, have a smallish budget. I want to shoot flowers/insects, and also portraits. How do those two stack up??
I've also looked at the Tamron 90mm and the Canon 85mm 1.8 had been recommended.
Hi! I'm a newbie! But I doubt it's a secret...
nishywishy is offline   Reply With Quote
Old 5th of July 2011 (Tue)   #2
KVN Photo
KVN Photo's Avatar
Default Re: Tokina 100mm Macro vs. Canon 100mm Macro
Buying a dedicated macro lens like 100 canon/tokina is the best for insects, while 85 f/1.8 with some close up filter has reasonable magnification but it will never produce the same result like macro lens. And 100mm is nice for a portrait as well, I don't think you'll have problem with that.
Tokina or canon, it's your call. Both are very good.
[size="1"]Flickr
X-Pro1 + 35 f/1.4, G12, 5D II, 500D, 24-70-200L, TS-E 24 f/3.5L II, 35, 50, 100L IS
KVN Photo is offline   Reply With Quote
Old 5th of July 2011 (Tue)   #3
nishywishy
nishywishy's Avatar
So, you are saying that the dedicated macro like the two I mention would work great for insects and flowers AS WELL AS portraits, right? Whereas the 85 f/1.8 would do great for portraits but not so much as a macro?
Can I ask you something else? Not totally on topic but sort of. I'm trying to add a lens to a basic kit (I'm a beginner) which consists of a nifty fifty, an 18-50 (came with the body), and a 55-250. I like these lenses but keep wanting to get something that will "catch" a wider angle (like the 18 on the kit lens but better!) Any suggestions? Maybe getting a dedicated macro lens isn't a good idea after all?
Thanks in advance!!!
Old 5th of July 2011 (Tue)   #4
phreeky
Between the Tokina and Canon I'd probably choose the Canon. Unless I'm mistaken they're similarly priced, and you'll get better AF performance with it.
As for macro lens versus something like a Canon 85mm F/1.8, the 85mm will certainly have faster AF and stopped down to about F/2.8 will probably be just as good IQ wise (maybe even a little better). But to use it for macro you'll either need a close-up filter that goes on the front (I've never used them) or an extension tube. The lens will have a limited focusing range when it's in use, and the manual focusing ring will have a LOT less throw so make focusing more difficult.
phreeky is offline   Reply With Quote
Old 6th of July 2011 (Wed)   #5
nishywishy
nishywishy's Avatar
Seems the Canon runs about about $150 more than the Tokina new and used. I'm a beginner so I actually may not even notice the differences you are referring to! I really want to try my hand at macro.
Yes, I've tried extensions on my 50mm and it's not much fun. By the time I got the focus, the lovely butterfly was far and away!
Old 6th of July 2011 (Wed)   #6
KVN Photo
KVN Photo's Avatar
Get 55-250 and 50 f/1.8 II will give you an extra reach and fun to use lens, and no need to upgrade your kit lens until you need to improve something (aperture, sharpness, CA control, weather sealing, etc.).
[size="1"]Flickr
Old 6th of July 2011 (Wed)   #7
phreeky
A good macro lens is definitely nicer to use than a non-macro lens with tubes, but don't underestimate how difficult it can still be. The plane of focus is still very very thin, the subject is still generally very close to the front element, and the only obvious advantages are the nicer focusing ring and the ability to focus from MFD to infinity without swapping the tubes in and out.
Old 6th of July 2011 (Wed)   #8
nishywishy
nishywishy's Avatar
Thanks! I already have the 55-250 and the old 50 f/1.8. I agree, it's enough. There is a ton to learn with just those two! I am wondering about getting an inexpensive flash (someone suggested Yongnuo YN-468) to get started on learning flash photography. I might go that route, just to mix it up. Which flash do you use?
Old 6th of July 2011 (Wed)   #9
rick_reno
I agree, extension tubes aren't fun, they're a PIA.
If all you want to do is try your hand at macro and not spend a bunch of money, look at the Canon 60mm 2.8. I have it, the 100mm and 100mm L macro lens and I can't tell any difference in IQ between the 60 and the 100 non L. It's a nice little lens.
rick_reno is offline   Reply With Quote
Old 7th of July 2011 (Thu)   #10
hillavoider
canon 100mm L macro is awesome, i love it, its really good for portaits as well, so good it makes having my 85L just an indulgence
hillavoider is offline   Reply With Quote
Old 7th of July 2011 (Thu)   #11
KenjiS
KenjiS's Avatar
Pretty much all macros are equal, They're all sharp, They're all good lenses, I dont think theres a single TRUE macro lens that is a bad lens out there
For my money, The Canon would be my choice because its the only one with USM, which means its more practical for more subjects than JUST macro...And I'm frequently thankful I have fast AF for macro too
Wanted: 5D Mark III, Sigma 35mm f/1.4, Sigma 120-300 f/2.8 OS
Deviantart
Flickr (This is where my good stuff is!)
KenjiS is offline   Reply With Quote
Old 7th of July 2011 (Thu)   #12
Sirrith
I was making this exact same decision 2 days ago at the camera store. I wanted to get a tokina lens because of their nothing short of amazing build quality (heck, their lenses have better build than my 70-200 f4), and their macro is significantly cheaper than the canon version, and I believe is the same, or even ever so slightly sharper. HOWEVER, when I tried the tokina at the store, its AF performance shocked me. It is without doubt the slowest lens I have ever used in terms of AF, and when it hunts (and it will, even my canon hunts sometimes though, so thats not tokina's fault, its just because its a macro lens), you might as well give up and use MF. The canon is more than twice as fast, and probably even faster in terms of AF. If AF is not important to you, then the tokina is the obvious choice, it has better build, similar IQ, comes with a hood, and is cheaper. However, if you want to use your lens as, say, a portrait lens, you'll want the canon simply because your subject will have time to leave, buy a burger, come back, eat it, and resume their pose in the time it takes for the toki to focus.
-Tom
Flickr | Zenfolio
Sirrith is offline   Reply With Quote
Old 7th of July 2011 (Thu)   #13
lightbender57
lightbender57's Avatar
I'd suggest you also consider the Sigma 105mm Macro.
I've been using one for years for my work, and find it equal to anything else out there. No IS, but IS only gets in the way for serious macro work anyway.
Lightbender57
_______________________________
[size="1"]Canon 5D Mk II, 60D, glass and flashes.
lightbender57 is offline   Reply With Quote
Old 7th of July 2011 (Thu)   #14
KenjiS
KenjiS's Avatar
^- I humbly disagree with the "IS gets in the way of serious macro work" thing...Really, I do..:/
Deviantart
Old 7th of July 2011 (Thu)   #15
watt100
even the macro lens without "USM" or HSM or SWM are good for subjects for more than JUST macro - they seem to have pretty fast "AF" even without USM !
Shocking!
XSi (450D) with Tamron 90mm 2.8 macro non-Di non-USM
(cropped 60%)
watt100 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
canon 100mm macro vs tokina 100mm macro ontopofm Canon EF and EF-S Lenses 5 6th of January 2010 (Wed) 15:04
Goin' macro: need advice (Tokina 100mm f2.8 - Tokina 35mm f2.8 - Canon 100m f2.8) mclaeys Canon EF and EF-S Lenses 7 9th of December 2009 (Wed) 15:58
Canon EF 100mm vs Sigma AF 105mm vs Tamron AF 90mm vs Tokina AF 100mm ALL MACRO sandro9mm Canon EF and EF-S Lenses 23 3rd of October 2009 (Sat) 09:47
Seeking Tokina 100mm Macro vs. Canon 100mm Macro comparison vjack Canon EF and EF-S Lenses 22 29th of April 2006 (Sat) 17:46
