#1 |
Light Bringer
I'm shooting some wedding pictures on a beach at midday this weekend. Two*20D/range of lenses 12-200mm, 580EX/550EX on high speed sync as fill flash. My question is do I need to bother with a flash bracket for these shots? I suspect since there'll be so much light the pupils will be very small and the chance of red eye is minimal, compared with the hastle of using a bracket.
I'm not so worried about the quality of the light in this situation (ie direct flash), but opinions on this from anyone with experience is also welcome.
NZIPP Qualified Professional wedding photographer.
Camera and Lens Reviews ~ Wellington Wedding Photographer Wellington Wedding Photographer (site2) ~ Wellington Wedding Photographer (site3) Read all my FAQs (wedding, printing, lighting, books, etc) |
| sponsored links |
#2 |
If you flop the camera over into vertical/portrait orientation, aren't you going to have the same "shadow on the side" problem that you would have indoors? I agree that with a lot of daylight around, it won't be as much of a problem as indoors.
I always look at it this way: What would it hurt? ---Bob Gross--- |
#3 |
Light Bringer
I don't imagine there'll be anything behind them for shadows to fall on, but that's a good point. I'm more worried about red eye and how much it'd slow my workflow down when I correct it.
| sponsored links |
#4 |
Moderator
I don't think red eye would be a problem outdoors during midday unless you happen to be shooting while a solar eclipse was occurring above you. Better check the weather report just in case.
...Leo |
#5 |
The red-eye phenomenon happens when the pupils are large and dilated because of dim light levels. Personally, I have never seen red-eye from shots taken during the middle of the day, not even with P&S cameras which are notorious for this problem because of the flash being too close to the lens. Also your flash is elevated several inches higher from the lens than a typical P&S camera which also helps. So in my humble opinion, you shouldn't have a problem unless it gets very dark. For instance, if you shoot in a covered corridor around sunset.
FYI, this problem is usually worse with small children and animals. Good luck!
Website: www.kaplanmultimedia.com EOS 5D MIII - EOS 7D - 70-200 f2.8L IS - EF 1.4X - 24-105mm f/4L IS - Bowens Gemini 400 2-Light Kit - Canon EF 50mm f/1.4 USM - Rokinon 85mm f/1.4 Aspherical Lens - Tokina 11-16 f2.8mm - (2) Canon 580EX flashes |
#6 |
We're now shooting on a beach? Or is this something else you've got on as well.
![]() As Kaplan said, you won't get redeye outside in bright conditions. |
#7 |
Light Bringer
The "creative" pictures are on a beach, outside government house, on the wharf, and maybe aronud parliment, depending on the weather.
#8 | |
#9 | |
Light Bringer
| Thread Tools | |
| Display Modes | |
| Outdoors Fill Flash - Sto-fen or Bare Flash? | GovtLawyer | Small Flash and Studio Lighting | 49 | 2nd of April 2011 (Sat) 17:10 |
| Fill flash vs. flash as main light for bird photography | ergaticus | Small Flash and Studio Lighting | 7 | 1st of June 2007 (Fri) 14:01 |
| camera rotate bracket or flash flip bracket | clengster_77 | Small Flash and Studio Lighting | 40 | 15th of January 2007 (Mon) 20:07 |
| How to lock HSS on Sigma 500 Super Flash | blundar | Small Flash and Studio Lighting | 12 | 7th of August 2006 (Mon) 07:25 |
| New Flash Bracket required | Paul Gerrard | Weddings and Other Family Events | 4 | 15th of April 2006 (Sat) 22:28 |
