Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing > Computers
Reply
Thread Tools Display Modes
Old 13th of July 2011 (Wed)   #1
brettjrob
brettjrob's Avatar
Default Photoshop Scratch Disk: SSD vs. HDD
I am currently running a 96 GB SSD as my OS and app drive. I also have two fairly fast HDD's in my tower (WD Black). The way I see it, I have two options:
1. Set the scratch disk to my SSD, which is very fast but also where PS resides.
2. Set the scratch disk to my second HDD, while keeping all my image files on the first.
Does anyone know which is likely to give me better performance?
Canon EOS 6D | Canon EOS 450D
Canon EF 17-40mm f/4L | Canon EF 70-200mm f/4L | Rokinon 14mm f/2.8
Manfrotto 055XPROB + 488RC2 | Hoya PRO1 Digital CPL 77mm
Flickr | 500px | skyinmotion.com
Feedback
brettjrob is offline   Reply With Quote
Old 13th of July 2011 (Wed)   #2
YP5 Toronto
YP5 Toronto's Avatar
Default Re: Photoshop Scratch Disk: SSD vs. HDD
Everything on the SSD.
Canon 7D Gripped |Tokina 11-16 | Sigma 30mm F1.4 |Canon EF 24-70L | |Canon EF 70-200L F2.8IS MKI |Sigma 530DG | Giottos 9360 | Giottos MH-1301 | Giottos MH656 | Spyder2Pro | Kata 3IN1-20 | Kata Bumblebee UL-222
YP5 Toronto is offline   Reply With Quote
Old 15th of July 2011 (Fri)   #3
DisrupTer911
DisrupTer911's Avatar
Get another ssd for the scratch disk use.
myFlickr : myModelMayhem : my500 : myGear :
DisrupTer911 is offline   Reply With Quote
Old 15th of July 2011 (Fri)   #4
tim
Light Bringer
tim's Avatar
If you have enough RAM then scratch is used, but I think it probably pages history to disk in the background.
Remember once Photoshop's loaded the disk isn't really touched again, so your SSD will be idle.
I have an SSD for and programs, and another for scratch/swap/cache.
tim is offline   Reply With Quote
Old 16th of July 2011 (Sat)   #5
hihohito
How much memory is Photoshop using for scratchdisk? I have a ssd vertex3 120gb drive for windows and photoshop. Should I use a second ssd drive for scratch? Memory on board is 16 gig.
hihohito is offline   Reply With Quote
Old 16th of July 2011 (Sat)   #6
tim
Light Bringer
tim's Avatar
Try with the existing ssd hi ho.
Old 16th of July 2011 (Sat)   #7
hollis_f
hollis_f's Avatar
This.
It's recommended to have your scratch disk on a physical drive that is different from the drive where PS exists. But that recommendation dates back to the dark ages when it took forever (nearly 10 ms) for the hard drive to even find the right place to get some data. So the continual switching from one physical location to another, as the CPU demanded PS data from one bit of disk, then data from the Scratch Disk, could cause perceptible delays (close to 100's of ms).
But an SSD has access times a lot faster than any HDD. So those dreadful delays of a half a second, or so, are cut down to about one hundredth of a second. Of course, you could spend a couple of hundred quid and get a second SSD - just for the scratch disk. And get those delays down to around 1 thousandth of a second. And then you can spend more money on some super-duper benchmarking software to measure those differences and bask in your self-satisfied smugness.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawl of his free fish entitlement.
Gear Website
hollis_f is offline   Reply With Quote
Old 16th of July 2011 (Sat)   #8
Mayniyak
10ms was the dark ages?? Heh, tell that to my first computer (170ms).
Mayniyak is offline   Reply With Quote
Old 16th of July 2011 (Sat)   #9
Bobster
Bobster's Avatar
minimum scratch that PS uses is the same as you have allocated to the app -so if you give it 8GB, you need a minimum of 8GB of Scratch..
Robert Whetton Dorset Portrait & Events Photographer | Photoshop Guru
DIY Monitor Hood | Gear | Tweet | Google+ | Get your focus spot on
Bobster is offline   Reply With Quote
Old 18th of July 2011 (Mon)   #10
btmlinedan
btmlinedan's Avatar
think 64gb of SSD would be enough?
btmlinedan is offline   Reply With Quote
Old 18th of July 2011 (Mon)   #11
DisrupTer911
My understanding on PS scratchdisk is that It works like a virtual memory setup like windows however, in PS, every action you make to a photo is registered within memory.
So if you're working on a 25mb image file, and do 2GB worth of processing to it, then you need 2+GB of scratch space.
if you're working on a 100GB pano and do like 100GB of editing to it then you need 100GB of scratch space on top of 100GB of storage space for teh file itself.
Old 18th of July 2011 (Mon)   #12
btmlinedan
btmlinedan's Avatar
so you need just enough to hold PS, and however much you're working on at 1 time?
Old 18th of July 2011 (Mon)   #13
btmlinedan
btmlinedan's Avatar
also ; how do you set the scratch disk?
Old 18th of July 2011 (Mon)   #14
tim
Light Bringer
tim's Avatar
For cache? Yes.
It's in edit -> preferences -> performance (or similar)
Old 18th of July 2011 (Mon)   #15
btmlinedan
btmlinedan's Avatar
thanks tim (in both threads )
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Photoshop scratch disk Headcase650 RAW, Post Processing and Printing 5 21st of June 2008 (Sat) 12:17
Photoshop Scratch disk errors.. Increase RAM? medicdude RAW, Post Processing and Printing 10 21st of October 2007 (Sun) 01:08
Photoshop CS2 scratch disk partition size philmar RAW, Post Processing and Printing 15 20th of April 2007 (Fri) 07:18
Photoshop speed - swap file or scratch disk? cosworth RAW, Post Processing and Printing 5 1st of January 2007 (Mon) 23:03
Photoshop 7 - Firewire - Scratch Disk martcol RAW, Post Processing and Printing 0 13th of October 2003 (Mon) 04:19
