Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 20th of October 2005 (Thu)   #1
courtknee202
Default Equine Photography, 20D or XT?
Greetings all! I'm looking for some advice on which way to go in purchasing a new camera. I'm getting into equine photography on a bit of a larger scale, and would like to upgrade from a 300D and the crappy plastic lens that came with it! The 300D is basically our families camera so it's been knocked around a bit and just isn't performing as well as it used to, and the lens also has scratches on it and dust inside.
I shoot mostly outdoors with quick shutter speeds in full sunlight which is constantly changing so I have to often stop and adjust my ISO and aperture. I'm told the XT is better for people with small hands, which I have. Lightness is a key factor too as I can't always use a tripod. Speed in which the images write to the CF is key for me when taking burst shots. Which would suit me better? I've seen fantastic images from both but I do not have the means to go try one out and then decide. I'd only be buying the body of the camera and the lens seperate, both the 20d and the XT seem to be about the same price. Thanks in advance, I appreciate your replies!
courtknee202 is offline   Reply With Quote
Old 20th of October 2005 (Thu)   #2
tim
Light Bringer
tim's Avatar
Default Re: Equine Photography, 20D or XT?
If you have to change your settings often a 20D will be better, it has more buttons and is easier to control. Some L lenses have dust protection. The images from the cameras will be near identical if you use the same settings.
tim is offline   Reply With Quote
Old 20th of October 2005 (Thu)   #3
robertwgross
robertwgross's Avatar
The 20D will likely cost a bit more than the XT.
The XT would be good if you have small hands. The 20D would be good if you have large hands. The 20D is just slightly more civilized, but the sensors are similar.
---Bob Gross---
robertwgross is offline   Reply With Quote
Old 21st of October 2005 (Fri)   #4
lostdoggy
King Duffus
lostdoggy's Avatar
Don't forget the 20D is better at higher ISO then the XT and larger buffer.
lostdoggy is offline   Reply With Quote
Old 21st of October 2005 (Fri)   #5
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
20D for the better buffer and higher burst rate, especially if you shoot jumping, steeplechase, barrel racing, . . .
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Old 22nd of October 2005 (Sat)   #6
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Thread split to EF Lenses with title Lenses for horse events indoors.
Jon
Cocker Spaniels
DC Cherry Blossoms
Old 22nd of October 2005 (Sat)   #7
Jonn
Jonn's Avatar
Since when?
Jonn is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Equine Buddy COUG3R Wildlife 2 24th of June 2007 (Sun) 12:47
For all you Equine lovers Skip Souza Wildlife 4 7th of June 2007 (Thu) 16:55
Equine Portraits Tony The Pony Wildlife 0 21st of November 2006 (Tue) 22:06
Equine photography books? dawnrogers Wildlife 2 19th of October 2006 (Thu) 03:32
Equine Headshot Airedale1 Wildlife 6 29th of May 2005 (Sun) 09:14
