Thread started 19 Jul 2011 (Tuesday) 07:05
SD Card "Write Protected"
Steve ­ Campbell
Joined Nov 2010
Jul 19, 2011 07:05 |  #1
I fired off a few shots with my 60D last night and then downlowded them onto my computer via a built in card reader. I then removed the card and put it back in my camera. I attempted to delete all images from the card but I recieved a message on the rear display saying the card was Write Protected. I could not format the card either. What's going on?
5D Mark III |5D Mark II | 7D | 70-200 2.8L IS II | 24-105 | 17-40 | 300 f2.8L IS |35 1.4L | 50 1.8 | | 24 3.5 TSE II |
Speedlite 430 EX II |
Fiddlefingers
Jul 19, 2011 07:28 |  #2
If the lock switch hasn't been moved to lock the card then it could well be that the card has been corrupted. One of the ways this can happen is removing the card before using the Safely Remove option in the task bar.
http://www.tomgilland.​co.uk (external link)
Steve ­ Campbell
Joined Nov 2010
Jul 19, 2011 07:50 as a reply to  @ Fiddlefingers's post |  #3
Is the card ruined? Anything I can do?
Fiddlefingers
Jul 19, 2011 08:01 |  #4
If it's corrupted then as far as I know that's the end of it. I don't use SD cards, but I believe corrupted cards aren't all that unusual. Maybe someone else can give more detailed information on what to check, or use Google to read about corrupted SD cards.
Citizen_Insane
Jul 19, 2011 08:48 |  #5
Try jiggling the switch back and forth a couple times and then try formatting it on your computer. Always make sure to use "remove hardware safely" on Win, drag to trash on Mac, or unmount on Linux before removing your card.
Gear
Steve ­ Campbell
Joined Nov 2010
Jul 19, 2011 09:59 as a reply to  @ Citizen_Insane's post |  #6
Where is that on Windows 7?
Mike
ugly when I'm sober
Gallery: 23 photos
Jul 19, 2011 10:03 |  #7
So did you try the suggestion of toggling the switch on the SD card?
www.mikegreenphotograp​hy.co.uk (external link)
Gear
UK South Easterners
flickr (external link) Blog (external link) 5∞px (external link)
Quis custodiet ipsos custodes? ::: A closed mouth gathers no foot.
Fligi7
Jul 19, 2011 10:46 |  #8
If the switch isn't the problem, you can go into Hard Disk Management on your computer, delete the partition on the card, create a new partition on the card, and try formatting again to see if that works.
DwainRowe
Joined Mar 2011
Jul 19, 2011 12:17 |  #9
Fligi7 wrote in post #12785716 (external link)
And then format it in your camera before using.
6D | EF 17-40 f/4 L | EF 70-200 f/4 L IS | EF 50mm f1.4 USM -|- Rebel T2i | EF-S 17-55 IS | Σ 10-20 f3.5 EX DC | Σ 70-300 4-5.6 DG Macro (Yes, I am cheap) | Speedlite 580EXII | YN622c
EOS M | EFM 22 f/2
amfoto1
Jul 19, 2011 13:05 |  #10
If you look at "Computer" on your menu you should see the memory card as a "drive" with data on it. Right click on it and choose "Eject". You might get a warning "Card is in use", but can still click "continue anyway" or something similar. You should see a pop-up that says "removeable media can be safely removed" or somthing similar.
Always do that when removing a card from the computer. (I always simply use drag and drop to transfer data from my cards, then I'm already in "Computer" to do the eject once all data is moved or copied.) It's the same as unplugging any USB device.
I agree with Dwain.... if you format the card in your computer, be sure to format it again in your camera before starting to shoot with it. In fact, it's a good habit to get in, always formatting in camera any time you put a card in... All data that was on the card prior will be lost, though. So be sure you have transfered all the images you want to keep.
If using Windows 7 64 bit and shooting RAW, you might not be able to see the images in Windows Explorer. There is an applet or codec you can buy for little money that will make the images viewable. I have it installed but can't recall the name. If using 32 bit operating system, Canon's codec should work...it's free, but there isn't a 64 bit version yet.
5DII, 7DII(x2), 7D(x2) & other cameras. 10-22mm, Tokina 12-24/4, 20/2.8, TS 24/3.5L, 24-70/2.8L, 28/1.8, 28-135 IS (x2), TS 45/2.8, 50/1.4, Tamron 60/2.0, 70-200/4L IS, 70-200/2.8 IS, 85/1.8, Tamron 90/2.5 Macro, 100/2.8 USM, 100-400L II, 135/2L, 180/3.5L, 300/4L IS (x2), 300/2.8L IS, 500/4L IS, EF 1.4X II, EF 2X II. Flashes, studio strobes & various access. - FLICKR (external link) - ZENFOLIO (external link)
Steve ­ Campbell
Joined Nov 2010
Jul 19, 2011 15:40 as a reply to  @ amfoto1's post |  #11
I just tried moving that little switch and the damn thing fell off! I think this card is a write off. Thanks for the help all the same.
Calicajun
Jul 19, 2011 15:51 |  #12
Steve Campbell wrote in post #12787414 (external link)
What brand of SD card were you using?
Remember, Stressed spelled backward is Desserts.:)
Suggestions welcome.
5DIII, EF 50 1.4, EF 40 f2.8, EF 24-105L IS , EF 70-200 f4L IS, 580EX ll
jbsumo
Jul 19, 2011 16:04 |  #13
Even if the switch has come away you can still use a small flat head screwdriver to push the white bit to the open position?
Used this trick a lot working in a photo lab- a lot of the cheaper brand cards tend to come apart in your hands!!!
LarryD
Gallery: 6 photos
Jul 19, 2011 16:39 as a reply to  @ jbsumo's post |  #14
It's likely that you have simply accidently moved the little plastic "lock" on the side of the card, as has been mentioned..
Also, you may have "write protected" your images in-camera... reset the camera.
You should try and format the SD card in-camera..
.... Got some cameras; got some glass ..... I just need one more of each.....:rolleyes:
Some Snap-Shots (external link)
http://500px.com/Larry​D (external link)
equach206
Joined Mar 2011
Jul 19, 2011 18:47 |  #15
If the switch itself broke off, you can try using a small folded piece of paper to move the switch in the slot itself.
5D | 50D | 60 f/2.8 Macro | 85 f/1.8 | 17-40 f/4L | 70-200 f/2.8L | 430EX
Flickr (external link) | Facebook (external link)
20,816 views & 0 likes for this thread
Latest registered member is DouglasAZ
698 guests, 375 members online
