#1 |
I've been told that it's possible to alter the frame rate of the 1D MkII. I use the fast (8.5fps) speed a lot but if possible, would like to re-programme the slower (3fps) speed to around 6fps.
Anyone any ideas? Cheers, Phil |
| sponsored links |
#2 |
Wait, all that time and all I get is "Cream of the Damn Crop" ?!!!!!!!!!!!!!!!!
You can't make the slow frame rate faster
But you can program the fast setting to 6FPS and enable a custom function to activate the slower rate,. and disable the CF to go back to the fast rate. With the new "N" version you can set either one much easier. |
#3 | |
70-200mm f/2.8IS Canon 1.4X II|sigma 12-24mm | EF85mm f/1.8|Ef 24-105mmL | 100mm macro| RS-80N3 | MinoltaAutometer|I9900|CS2|LR|CS3| Angle Finder Manf 190MF4 tripod, 680 mono, 322RC2 Joystick Head | 580EXII,580EX,430EX,ST-E2,CP-E3 www.pbase.com/marlonjp |
| sponsored links |
#4 |
Moderator
You can set the max and min shutter speed using Personal Function (PF) 04. But you need to connect the 1D to a PC via a firewire in order to set the Personal Functions. Once set, you can enable and disable the PF to select your custom frame rates (PF 04 enabled) or the default camera frame rates (PF 04 disabled).
...Leo |
#6 |
thanks guys for your help...i just got mine last week and i havent have the chance to play with it....
#7 |
cheers guys, I'll look into the CF activation and let you know how I get on
#8 | |
Moderator
...Leo |
#9 |
sorry. meant the PF!
| Thread Tools | |
| Display Modes | |
| 1D MkII, 1D MkII N, 1DsMkII - Firmware updates just released! | digitalmono | Canon EOS Digital Cameras | 56 | 24th of January 2010 (Sun) 15:27 |
| experiment~frame in a frame with large family. How did turn out? | House of Jubilee | People | 13 | 18th of December 2006 (Mon) 14:15 |
| Severe coloration in 5d from frame to frame? | chi | Canon EOS Digital Cameras | 15 | 17th of February 2006 (Fri) 03:46 |
| New EOS 1DS MkII "X" (9,5fps)and new N* with 18 MP full frame | digitalmono | The POTN Lounge | 9 | 7th of April 2005 (Thu) 09:36 |
| Sigma Lenses for EOS 1D and frame rates | JGordon | Canon EOS Digital Cameras | 1 | 24th of May 2002 (Fri) 18:35 |
