Thread started 23 Oct 2005 (Sunday) 04:05
Prev/next
ERROR 02
zwina
Oct 23, 2005 04:05 |  #1
Hi all,
I've a EOS 300D, and a CF card of 1GB.
I've this error message: ERROR 2 on the LCD screen and could not even open the menu and format the card.
Do you have any ideas?
thanks a lot
ssim
ssim's Avatar
Joined Apr 2003
southern Alberta, Canada
Oct 23, 2005 05:30 |  #2
Error 02 is related to the CF card. You could try putting it back in and then try reformatting again. It is possible tht your card has gone south on you. Check to see what the warranty time on the specific card that you have is.
Sheldon Simpson | My Galleryexternal link | My Gear updated: 20JUL12
Jon
Jon's Avatar
Joined Jun 2004
Bethesda, MD USA
Oct 23, 2005 09:28 |  #3
Have you tried reformatting the card (full, not quick, format) in your computer? This will require you to have a CF reader, but they're so handy you should have one anyway.
Jon
Cocker Spaniels
zwina
Oct 23, 2005 13:59 |  #4
thanks guys for your answers :)
ssim: How can i reformat if I can see anything in the camera screen ( have just the error message)
Jon: unfortunatly ny card reader do not recognize the card since the error message
colin ­ uk
Joined Jan 2003
North West UK
Oct 23, 2005 14:10 as a reply to zwina's post |  #5
Is it a Lexar card? Theres a few post about problems with Lexar cards http://photography-on-the.net ...?t=104563&highlight​=lexar
Using Canon EOS 40D
sti ­ jaguar
sti jaguar's Avatar
Chicago IL
Oct 23, 2005 14:52 |  #6
I've had a CF card read error before. Then I reformatted and the card was fine and so I continued to shoot a bunch of pics. Then the card had CF error again so i lost the pics that I just took. I reformatted again....took some pics and the card seemed fine. Then suddenly I got a CF card error again and lost all my pics.
I finally got the hint and bought a new card.
Jon
Jon's Avatar
Joined Jun 2004
Bethesda, MD USA
Oct 23, 2005 17:39 as a reply to zwina's post |  #7
Sounds like your only options are to replace it under warranty, or replace it out of warranty. If it's out of warranty, you needn't feel tied to that particular brand. FWIW, I like SanDisk Ultra IIs.
Jon
Cocker Spaniels
phil1664
phil1664's Avatar
Manchester, UK
Oct 24, 2005 04:59 |  #8
ZWINA,
I've had the ERROR 02 message and it was the card. I tried formatting it and got nowhere with it. I returned it to the shop where I bought it and they refunded the money, no questions, which was nice as I could buy a new card double the size for the same cash!
If it's still in warranty, shouldn't be a problem. If it's out, will have to see. If you live in the UK, there are laws which will help you get a replacement, if you're outside, not too sure
Good luck
www.minus9photography.​co.ukexternal link
Feedback always welcome!
TWRX
Joined Feb 2004
Oct 15, 2007 02:17 |  #9
I received the same error message after mistakenly formatting my CF card in the computer. Don't do this! Always, format in the camera. I've heard that it has to do with the way the file directory gets messed up by the computer and the camera can't associate the correct data block with the directory.
I corrected my problem by reformatting the camera in my MAC using Mac OS X and writing zeros to the entire CF card. The camera was then able to see the card as just a regular "unformatted" CF card rather than some ERROR 02.
Good luck to you!
Jon
Jon's Avatar
Joined Jun 2004
Bethesda, MD USA
Oct 18, 2007 11:53 |  #10
TWRX wrote in post #4125681external link
Good luck to you!
If you got a card error after formatting the card in your computer, the card was about to fail anyhow. Aren't you glad it didn't go in mid-shoot? The computer and camera put the exact same FAT16 or FAT32 tables and directory structure on the card. The computer's somewhat more rigorous about it however, which is why a card may fail there. IMO a card that fails once is about to fail again. It gets retired to a less-rigorous use. And all my cards get reformatted in the computer before being returned to use.
Jon
Cocker Spaniels
sullos
1 post
Sydney
Dec 18, 2008 02:38 |  #11
is there any way to determine (as shops are shut right now) that its not a camera fault?
Ivoryplum
"I don't have the balls"
Ivoryplum's Avatar
California
Dec 18, 2008 03:46 |  #12
sullos wrote in post #6901171external link
Sure, if you have another CF card (or borrow one from a friend) and check to see if its the cameras fault.
But as others have stated above, that error means it has to do with the CF card.
Canon 50D {Gripped} | 20D | 580EX II
70-200mm f/4L USM | EF-S 10-22mm f/3.5-4.5 | 50mm f/1.8 II | Sigma 28-300mm f/4-6.3 | Canon 28-90 f/4-5.6 | Manfrotto 190XPROB w/ 322RC2 Ball Head | Vertex 100AW
- Photography page - http://yestrdaysforgiv​n.deviantart.com/external link
- Need Photo Editing?
Can(-_-)n
Joined May 2011
Jun 30, 2012 21:05 |  #13
I'm using the Lexar 4gb CF card with my 10D, and even after formatting it twice I still have the same issue. from what I see here, and some of the reading I've done. Scandisk is the better option? I also notice the error-2 code doesn't come up as much when I shoot JPEG. Shooting RAW, the code came every other shot.
amfoto1
San Jose, California
Jun 30, 2012 21:51 |  #14
No, Sandisk cards are not really any better than Lexar, IMO. I have a bunch of each.
There were some problems years ago, with Lexar cards in Canon cameras... But if I recall correctly, it was older, smaller cards... not 4GB.
Inspect the memory card sockets, both in the camera and the end of the card itself. Look for any bent or broken pins.
If it's having more trouble recording RAW, those files are larger and more of a chore to write to the card.
Do you regularly format your memory card in your camera? Have you ever formatted it in your computer or used the card in a different brand of camera? Sometimes stray data or incorrect file structure can cause problems. That's why it's so important to regularly format it in camera.
There are memory card testing softwares. In fact, one of the better ones is in Lexars image recovery software. It can check the card and if there's a problem, might be able to fix it (after which it should always be formatted in the camera).
Try another card... that would tell you if it's the card or if it's the camera.
Alan Myers "Walk softly and carry a big lens."
5DII, 7DII(x2), 7D(x2) & other cameras. 10-22mm, Tokina 12-24/4, 20/2.8, TS 24/3.5L, 24-70/2.8L, 28/1.8, 28-135 IS (x2), TS 45/2.8, 50/1.4, Tamron 60/2.0, 70-200/4L IS, 70-200/2.8 IS, 85/1.8, Tamron 90/2.5 Macro, 100/2.8 USM, 100-400L II, 135/2L, 180/3.5L, 300/4L IS (x2), 300/2.8L IS, 500/4L IS, EF 1.4X II, EF 2X II. Flashes, studio strobes & various access. - FLICKR (external link) - EXPOSUREMANAGER (external link)
drew ­ baby
Joined Jun 2012
Durham U.K.
Feb 16, 2013 06:46 |  #15
Hi All,
ive just started getting the "error 2 " message on my screen, everything worked perfectly till i printed photo`s off the card at a supermarket photo lab, usually i upload shots to my p.c. then print off my own printer, but with the price of ink i thought i`d try this process.
CF Card is a Sandisk 16gb 60MB/S so you can imagine my dismay as its only months old, ive tried to format the card in camera and p.c. to no avail so i guess its time for a new card, but why the supermarket printer has killed the card i`ve no idea.
Canon 7D,Canon 450D, 18-55 mm Ef-s 18-135 mm Ef-s Tamron 70-300 Macro, Speedlite 468 Flash
52,090 views & 0 likes for this thread
ERROR 02
made in Finland
by Pekka Saarinen
Spent 0.00092 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is My Baby boy
1001 guests, 450 members online
