Reply
Thread Tools Display Modes
Old 9th of May 2003 (Fri)   #1
Rombauer
Default External flash for Canon G3
I've just purchased a Canon Powershot G3. The manufacturer recommends the use of Canon flashes, as an option for external flash use and briefly mentions the possible use of other flashes. Considering that the camera's hot shoe "physically" supports flashes of different brands, I just wonder if there is any risk of damage to the camera if I couple a Mecablitz 348BTS (made by German METZ) electronic flash to it. This flash is powered with 4.8 VDC.
Rombauer is offline   Reply With Quote
Old 9th of May 2003 (Fri)   #2
Dana
Default Re: External flash for Canon G3
There is a thread on this site that talks about flash compatibility...not sure what the best search terms are, but you should know that you can hurt your G3 w/the wrong type of flash on it.
Dana
Dana is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon EOS cameras with external flash hazmaz Small Flash and Studio Lighting 3 10th of January 2006 (Tue) 14:53
Canon S2 IS and External Flash jimraed Small Compact Digitals by Canon 4 18th of September 2005 (Sun) 16:12
S200 External Flash Sunpak Digital Flash Adaptor Soyboy Small Compact Digitals by Canon 0 27th of September 2004 (Mon) 18:36
CANON G2 - - EXTERNAL FLASH POSSIBILITIES??? robertderobert Canon G-series Digital Cameras 2 8th of December 2002 (Sun) 09:27
