Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 25th of October 2005 (Tue)   #1
shortie
shortie's Avatar
Default 20D high speed sync
Hi Guys "n" Gals
Been searching but cannot find the answer - but I am probably looking in the wrong place
Just ordered a 580 so before I arrives I thought I had better look into how to use it
Is there a way to get high speed sync with a 20D - I know I can up the flash sync to 1/250, but what I am after is to have a shutter speed of say 1/1000 and get a flash to fill some of the shadows
any pointers welcome
Shortie
shortie is offline   Reply With Quote
Old 25th of October 2005 (Tue)   #2
peterdoomen
peterdoomen's Avatar
Location: Lier, Flanders (northern, flemish speaking part of Belgium)
Default Re: 20D high speed sync
Hi Shortie,
There should be a high speed sync button on the flash (at least there is one on my 420EX). The 20D will adapt itself automatically and will allow you to set shutter speeds faster than 1/250.
PeteR.
Canon EOS 20D | Canon 70-200 f2.8L IS + Hoya UV Filter | Canon Extender 1.4x | Canon 50 f/1.8 | Canon 85 f/1.2L mk II | Tamron 17-35 f/2.8-f/4| Tamron 28-75 f/2.8 | Tokina 100 f/2.8 macro | Kenko extension tubes | Canon Speedlite 420 EX & Sto-fen Omnibounce| 80GB Flashtrax | Manfrotto Tripod 190 pro B & Joystick 322RC2 | Lowepro Micro Trekker 200
PDFs: Make money with ShutterStock - Make your own Tabletop Studio - Glass Buying Guide
My ShutterStock Gallery
peterdoomen is offline   Reply With Quote
Old 25th of October 2005 (Tue)   #3
Snapman
Yes, I can do it with my 550EX, so I'm sure it'll be possible on your 580EX. As somebody else has said, the control will be on your flash and not your camera
With your 20D, you'll be able to sync all the way up to 8000th sec., although the guide number becomes lower as the shutter speed increases.
Snapman is offline   Reply With Quote
Old 25th of October 2005 (Tue)   #4
shortie
shortie's Avatar
thanks all
that would make sense as I could not find any thing in the 20D manual
off to find a 580ex manual to down load
does this also mean I can use the flash in continous mode but just a lower guide number
thanks again
Shortie
Old 25th of October 2005 (Tue)   #5
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
If by "use the flash in continuous mode but just a lower guide number" you mean use it manually with lower output, HSS and manual don't work the same way. You will be able to select power levels on the 580 for manual flash use; you won't be able to set the 580 for E-TTL II at a lower output. The manual includes constraints on continuous flash use at different power level settings.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Old 25th of October 2005 (Tue)   #6
Snapman
BTW Shortie, There was a thread a couple of weeks' ago regarding HSS which taught me something and might interest you. That is, you can leave HSS switched on all the time because it automatically switches off when you use a shutter speed - in the case of a 20D - of 250th or lower.
Old 26th of October 2005 (Wed)   #7
shortie
shortie's Avatar
thanks guys
Nice option Snapman the 580 arrived today so will have a play tonight
Shortie
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
how do you set high speed sync on camera 20d 20dshooter Canon EOS Digital Cameras 3 16th of October 2006 (Mon) 19:15
high speed sync via pc? savone Small Flash and Studio Lighting 7 14th of September 2006 (Thu) 23:37
High speed sync mknabster Small Flash and Studio Lighting 3 10th of April 2006 (Mon) 08:50
High Speed Sync guitarman Small Flash and Studio Lighting 17 4th of January 2006 (Wed) 03:30
High-Speed Sync How?? steven Canon EOS Digital Cameras 6 9th of July 2004 (Fri) 20:42
