Thread started 15 Aug 2011 (Monday) 09:26
Prev/next
50D sticky shutter - alcohol fix
tomj
Aug 15, 2011 09:26 |  #1
I have an intermittent problem with my 50d shutter not firing, or firing after a long delay, when the button is pushed. The problem is getting worse.
A widely discussed fix for this, on this forum and others, involves pouring alcohol into the battery compartment. By all accounts, this almost always solves the problem with no harm to the camera. The only problem I've found is one person who allowed alcohol to get into the top lcd display, causing it to be fuzzy, but everything remained fully functional.
My question to those familiar with this is, has anyone had or heard of a downside to this? Despite the overwhelming success that's been reported, I'm having trouble getting past my instinct to not pour liquid into my camera.
Flickrexternal link
alt4852
alt4852's Avatar
Alexandria, VA
Aug 15, 2011 09:29 |  #2
i don't think pouring liquid into your camera is ever a good idea. although alcohol may work to break down some gunk, i'd at the very least just saturate a q-tip or cotton ball and apply it with slight pressure. it'll probably help to control the quantity of alcohol you're using, and work the increase the accuracy of where you're applying it. good luck!
5D3 | Z21 | 35L | 50L | 85L | 135L
crn3371
crn3371's Avatar
SoCal, USA
Aug 15, 2011 09:31 |  #3
Did it with my 30D and it worked like a champ. Read the threads here in the forum, watch the YouTube videos. I think if done properly it's fairly risk free.
gjl711
They have pills for that now you know.
gjl711's Avatar
Deep in the heart of Texas
Aug 15, 2011 09:45 |  #4
There are two downsides I can see. First, accidents happen. If you are not careful alcohol can enter the top screen as you mentioned or if you are less carefull, it can enter other areas.
Second, alcohol does dry out foam, which seems to be the material used under the button, so eventually, I'm speculating, the button will fail.
However, my feeling is that the button has already failed and the only non DYI fix is to send it in and get the button replaced. If you are careful and don't get antsy and start playing with the body before all the alcohol has evaporated, the fix is a vary viable one can delay an eventual repair possible for the remaining life of the camera.
So go for it. Do it carefully making sure you give plenty of time for any liquid to evaporate and you'll be fine.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
brit84
brit84's Avatar
BC, Canada
Aug 15, 2011 13:02 |  #5
The button on my 5dc grip started being stick, needed to be held down at which time it would focus and take the picture in one go. I took the grip off and put it back on, and it worked fine.
5DIII/grip |5DII/grip | 40D/grip | 17-40L| 24-70L 2.8 II|70-200L IS f2.8 II | 580EXII x2 | Lensbaby composer | Benro 358 w/ Q3 | 2 Einsteins/Vagabond mini.
Facebook (external link)
Website (external link)
kcbrown
kcbrown's Avatar
Silicon Valley
Aug 15, 2011 15:13 |  #6
I thought the "alcohol fix" was to drink sufficient quantities of alcohol until you no longer notice the shutter button problem...
:lol:
"There are some things that money can't buy, but they aren't Ls and aren't worth having" -- Shooter-boy
Canon: 2 x 7D, Sigma 17-50 f/2.8 OS, 55-250 IS, Sigma 8-16, 24-105L, Sigma 50/1.4, other assorted primes, and a 430EX.
Nikon: D750, D600, 24-85 VR, 50 f/1.8G, 85 f/1.8G, Tamron 24-70 VC, Tamron 70-300 VC.
alt4852
alt4852's Avatar
Alexandria, VA
Aug 15, 2011 15:29 |  #7
kcbrown wrote in post #12940230external link
:lol:
"..caamrah?! whhat caaaammmrah?"
Dooms_day
Dooms_day's Avatar
Maryland, USA
Aug 17, 2011 11:25 |  #8
I recommend acetone as the alcohol you're using. Works like a charm and evaporates fast.
Canon EOS-1D mk ii + 70-200 4.0 USM L + Sigma 28-70mm 2.8-4 + Nifty 50
500pxexternal link - Google+external link
gjl711
gjl711's Avatar
Aug 17, 2011 11:26 |  #9
Got to be careful with acetone. It dissolves many plastics.
::Gear::
amfoto1
San Jose, California
Aug 17, 2011 11:58 |  #10
OMG! Acetone would likely destroy the camera!
Go to an electronics store and get Electronic Contacts cleaner. Radio Shack, for example, has it in spray cans. Read the side of it... it's mostly isopropyl alcohol, sometimes called isopropynol. This is the same as rubbing alcohol sold in pharmacies and grocery stores. Radio Shack also sells electronic contact cleaner with lubricant (some sort of very light, anti-corrosion oil, I think). I've used that on automotive switches with a lot of success, but haven't tried it on a camera.
Just to clarify.... because it's very important... Heading and orignal post say "sticking shutter".... What we are talking about is "sticking shutter release button", not the shutter itself. (You do not want to be pouring anything into the actual shutter of the camera!)
So, with that clarified, a sticking shutter release button is a fairly common problem and is due to finger oils, dust etc. getting into the button mechanism. It needs a cleaning.
Properly done, the camera should be disassembled for this cleaning. However, some have had success taking a shortcut...
Turn the camera upside down and remove the batteries. Keep it upside down, tilt slightly so that fluids will be restricted to the end of the camera where the battery and shutter button are located. You can then spray or drip a little of the alcohol onto what's normally the top of the battery compartment, so that it gets into the camera and "flood cleans" the shutter release button mechanism. If you put a paper towel under the camera, you should see some alcohol, and perhaps some of the dirt/oil, drip out of the button... Apply several times until what drips out is clear. Use as little fluid as possible. Let camera dry for an hour or so, still upside down. Alcohol evaporates rapidly, but what's inside the camera might take longer. You can probably accelerate drying a little using a hair dryer set to "no heat"... just gently blowing some air in the battery compartment. Once dry, reinstall batteries and test the camera.
This is risky... the alcohol might get into places you don't want it and might effect circuits or other parts negatively. It could wash away necessary lubrication in other areas, for example. Or it might cause rubber parts to harden, or intrude into the LCD.
There's a lot of possibilities, things that can go wrong doing this. So do it at your own risk. But some folks have had good success freeing up the shutter release button. So, it might work for you.
Alan Myers "Walk softly and carry a big lens."
5DII, 7DII(x2), 7D(x2) & other cameras. 10-22mm, Tokina 12-24/4, 20/2.8, TS 24/3.5L, 24-70/2.8L, 28/1.8, 28-135 IS (x2), TS 45/2.8, 50/1.4, Tamron 60/2.0, 70-200/4L IS, 70-200/2.8 IS, 85/1.8, Tamron 90/2.5 Macro, 100/2.8 USM, 100-400L II, 135/2L, 180/3.5L, 300/4L IS (x2), 300/2.8L IS, 500/4L IS, EF 1.4X II, EF 2X II. Flashes, studio strobes & various access. - FLICKR (external link) - EXPOSUREMANAGER (external link)
gjl711
gjl711's Avatar
Aug 17, 2011 13:08 |  #11
BTW, this is a vid of the fix.
http://www.youtube.com​/watch?v=tB_gSqyidI0external link
::Gear::
Lucyb625
Aug 17, 2011 18:02 as a reply to gjl711's post |  #12
I have a 40d. I tried the alcohol fix but it was obvious in a day or two that the problem still existed and in fact was rapidly getting worse. 7 days and $202 later I havemy 40d back from Canon after they replaced the shutter mechanism. My symptoms included holding the shutter button down and 1-5 seconds (or more) later the shutter would "click". I could only find 93% alcohol and in highsight I would not do it again unless I had a higher concentration of alcohol.
This is one persons opinion and experience so don't let my experience deter you from trying the alcohol fix. Noting ventured nothing gained.
KW ­ Ghost ­ Ship
KW Ghost Ship's Avatar
Pittsburgh (Jefferson Hills), PA
Mar 17, 2013 22:11 as a reply to Lucyb625's post |  #13
Not to rehash an old post, but maybe somebody is still doing research into the alcohol thing. I would strongly suggest against it....because I did it and even though it "fixed" the shutter button on my 40D...it causes other problems. I'm pretty handy with tools and was going to take apart the camera and clean/replace the shutter button when I saw the "miracle" 1 minute fix. After researching I decided to try it....I should have researched more. First off...even if you take out both batteries, that camera still has a lot of power stored up inside the flash capacitor...so the cam is not truly unpowered. I was VERY careful and held the cam at an angle and still somehow alcohol crept it's way into the upper lcd. It turned it all blotchy and dark, especially when you turn on the backlight. Second, it fried the accelerometers that tell the cam whether you're rotated or not, so now there is no auto rotate feature. I'm guessing those components are located somewhere on a pcb up top or around the actual shutter button.
In short, ya my shutter button got un-stuck and works again, but I have a crappy top lcd and no auto rotate now.
If those features aren't important to you, then by all means...the alcohol "works", but if you want to keep your camera nice and functional I'd suggest either tearing in and doing a proper cleaning or send it out for repair. You'll be happier in the end.
And just another note: if anyone does tear into the camera for a diy repair, make sure you properly discharge the flash capacitor first!!
BGG
Gear: All Canon - some old stuff.
d.tek
Mar 18, 2013 08:36 |  #14
I've done it with my 50D. I used as pure of isopropyl as I could find. I think it was 99%.
I balanced the camera on the shutter button to pop-up flash angle and removed both the main battery and the time/date battery which is in a little slide out tray. I put a teaspoon full of the isopropyl in the most southern corner of the battery compartment which basically channeled the isopropyl directly to the shutter button. Then I picked the camera up in the same orientation and tapped on the shutter button. My finger caught the isopropyl as is drained through the gaps in the shutter button. After about 30 taps or so, I put the camera down and let it dry out for hours and then gave it a try. Two treatments was sufficient for me. However, I will say that eventually the problem resurfaced. I rinsed and repeated the same process and won another handful of uses without issue.
That being said, it's probably not the most ideal way, but it certainly was cheaper. However, it has the potential of being much more expensive than just having the button replaced.
I should mention that I've done it about 3 times successfully. I haven't noticed any other issues with it.
Instagram (external link)
KW ­ Ghost ­ Ship
Mar 18, 2013 08:48 as a reply to d.tek's post |  #15
D.Tek, just curious...did you have any issues like I did, with alcohol getting in the top lcd and ruined auto-rotate feature??
I was VERY careful and kept the cam at an angle the whole time, and still that alcohol got where it wasn't supposed to somehow.. :(
BGG
12,534 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00219 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is Valokuva
1014 guests, 487 members online
