#1 |
I'm looking at purchasing a B+W 10 stop ND. B&H has 2 listed in 77mm, one single coated, one multi-coated, with a cost difference of about $60.
Is there any actual practical difference between these that I will actually SEE? I purchased one here, not sure which noe it was, stacked it with a HOYA ND400 and was getting excellent results on my 5D Mk II.......until I took them off, laid them down and walked off. Expensive mistake. Anyway, will I see a difference with the MC?
Lightbender57 _______________________________ [size="1"]Canon 5D Mk II, 60D, glass and flashes. |
| sponsored links |
#2 |
A "coating" is designed to reduce glare and flare. A single coated filter has one layer of, usually, Magnesium Fluoride, which reflects most of the visible spectrum light and is quite effective..
A multi-coated filter uses different thickness of coatings to cover more of the light spectrum and is more efficient since the image can be affected by non-visible light too.. So, there is not a great difference between a single coated filter and a multi-coated one, but a great deal of difference from glass that is not coated at all... Still, though, if there is no light entering at an angle that needs to be canceled (reflected); then the coating has little affect at all..
.... Got some cameras; got some glass ..... I just need one more of each..... Some Snap-Shots http://500px.com/LarryD |
| Thread Tools | |
| Display Modes | |
| WTB: 72mm Hoya PRO1 Digital UV(0) Filter DMC or other high quality filter | kkSlider | Classifieds: Buy | 0 | 6th of October 2010 (Wed) 10:12 |
| multicoating important on filters? | lenjack | Canon EOS Digital Cameras | 4 | 6th of August 2006 (Sun) 23:41 |
| Anyplace that sells filter rings? (filter w/o actual filter in it) | JonathanSQ | Accessories & Storage | 1 | 18th of August 2005 (Thu) 17:29 |
