FORUMS Photo Sharing & Visual Enjoyment Sports
Thread started 08 Sep 2011 (Thursday) 11:11
Prev/next
Canon 7D Sports Photo Settings
wurish
Joined Jul 2011
Sep 08, 2011 11:11 |  #1
I'm new to the 7D - and photography. I was shooting a family friends football game, and was struggling with what focus squares to use on the 7D?
Aside from that - any tips and pointers (settings, comp, etc) for a newbie 7D user shooting sports?
Thanks for your time - much appreciated! :lol:
yourdoinitwrong
yourdoinitwrong's Avatar
Indiana
Sep 08, 2011 12:47 |  #2
There could be a whole book written about this but for the focus points in sports I almost always use Single Point, and rarely Single Point Expansion. I would stay away from Auto Select and Zone. In those modes the camera will pick the closest object to you within the focus points and in football there are so many players and refs out there that it may not focus on your intended subject. Also, put the camera in AI Servo so it will continuously focus. For sports I use back button focus instead of the shutter half-press. That way you can keep the camera continuously focusing and it's much easier than trying to keep the shutter halfway down. There are a lot more experienced shooters that can offer more advice but that's my two cents to get you started in the right direction.
7D2 w/ BG-E16, 7D w/ BG-E7, EF-S 10-22mm f/3.5-4.5, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8
Full List
Nathan
So boring
Nathan's Avatar
Boston
Sep 08, 2011 12:48 |  #3
For sports, I've been successful with using expansion points
Taking photos with a fancy camera does not make me a photographer.
www.nathantpham.com (external link) | Boston POTN Flickr (external link) |
5D3 x2 | 16-35L II | 35 L | 50L | 85L II | 135L | 580 EX II x2
dwarrenr
dwarrenr's Avatar
Fairland, Indiana
Sep 08, 2011 12:55 |  #4
I've been using these settings on the 7D and it's worked out rather well.external link
D. Warren Robison
"All guys feel the need to compensate. Most compensate with sports cars. I compensate with a 400mm 2.8"
Flickrexternal link - Home Pageexternal link - MaxPreps Gallery -external linkRazziexternal link
Equipment List
Effectivepull
Sep 08, 2011 12:55 |  #5
I use single point. Occasionally I will use expansion. You might want to look into back button focus as well. I was hesitant when I first tried it and now I can't live without it.
scottwuphotography.comexternal link 500pxexternal link; Google+external link
Canon 7D, S95
Brian_R
Sep 08, 2011 13:17 |  #6
i second that. and i use single center spot focus point
Jelloneck
Jelloneck's Avatar
Joined Nov 2010
Raleigh, NC
Sep 08, 2011 13:21 |  #7
Effectivepull wrote in post #13070761external link
I think this was one of the best customizations I did to my 7D
Gear List/Feedback |Instagram (external link)|
djkevin314
djkevin314's Avatar
Glendale,AZ
Sep 09, 2011 01:14 |  #8
7D Sports Settings
.OK, I cannot take credit for the 7D setting
Picture Style - Standard (but sharpness upped to 4) You may even what to go higher. I use one click under max with my Mark III and Mark II N
C.Fn III: Autofocus Drive
1 - AI Servo tracking Sensitivity: Set to -1
2 - AI Servo 1st/2nd img priority - Set to 0 - AF priority/Tracking Priority
3 - AI Servo Tracking Method - Set to 0 - Main Focus point priority (that way the camera focuses on what you want, not what it wants)
4 - Lens Drive when AF impossible - Set to 0
5 - AF Microadjustment - Set to 0 (Most people have said this is ineffective. Even the manual says it needs to be done on location where you are shooting to do any good.)
6 - AF area select mode - I have single point w/expansion selected and single point. Been shooting mostly on single point w/expansion for sports.
7 - AF Manual pt. selection pattern - Set to 1 (Continuous)
8 - VF display illumination - set to 1 (Enable)
9 - Display all AF points - Set to 0
10 - Focus Display in AI Servo/MF - Set to 0
11 - AF-assist beam firing - set to 2 (Enable to external flash only)
12 - Orientation linked AF point - Set to 0
13 - Mirror lockup - Set to 0 (Disable)
C.FN IV: Operations/Others
Shutter button is set to Meter only
AF-ON button is turned OFF (too easy to hit accidentally)
AE lock button (*) is set for metering and AF Start
appsyscons
appsyscons's Avatar
Joined Apr 2011
Port Charlotte, FL
Sep 09, 2011 13:31 as a reply to djkevin314's post |  #9
I have been successful with sports, with the following
when shooting an individual, single point or expanded
when shooting a race car or race boat, if it occupies a large part of the frame, then zone
Gear: 7D gripped | EF-S 18-200mm f/3.5-5.6 IS | EF-S 10-18mm | , Nikon P530, Manfrotto legs, 496RC2 Ball Head /QR
My flickr account, 13,200+ pictures, by collection (external link)
Upgrade wish list: EF 100-400mm f/4.5-5.6L IS USM | EF 24-70mm f/2.8L USM | EF 70-200mm f/2.8L IS (I or II) USM | Canon EF 1.4X (II or III)
wurish
Joined Jul 2011
Sep 09, 2011 14:09 |  #10
What is the benefit to having the back button focus?
I must be missing something!
Thanks again for your time folks.
yourdoinitwrong
Indiana
Sep 09, 2011 14:22 |  #11
wurish wrote in post #13076596external link
For me it is easier to use the back button than try to keep the shutter half-pressed. Since AI Servo constantly focuses you can keep the back button down to track your subject and then just click the shutter for the shot. When you are moving the camera around a lot this prevents errant shots since you don't have to keep just the right amount of tension on the shutter to keep it halfway down. Give it a try and you will see the benefit. At first though it will take getting used to but stick with it for a while. It also comes in handy if you want to focus and recompose in One Shot. If you have the AF start assigned to the shutter then you will have to keep the shutter half-pressed while you recompose but if you use the back button then you simply achieve focus, let go of the button and move the camera without worrying about the focus moving. If it's assigned to the shutter and you accidentally move your finger then you will have to focus all over again because the next time you push the shutter the camera will focus on wherever it's now pointing.
Full List
wurish
Joined Jul 2011
Sep 09, 2011 14:28 |  #12
Great explanation ydiw - really appreciate that!
Fligi7
Sep 09, 2011 18:00 |  #13
Focus points depends on the sport for me and how much the objects are filling the frame. For the most part I use single point w/ expansion.
alfa147x
alfa147x's Avatar
Sep 09, 2011 20:45 |  #14
When in high school I shot nearly all of the football games. One tip I was given was to keep both eyes open. I almost was run over once :D
2011 Apple MacBook Pro 13'' Hackintosh Intel Q8300 SLGUR @ 3.5 GHz EP45-UD3LR 6 GB RAM
Canon 5DII, 7D, 30D, 20D, 24-105mm f/4 IS L , 16 - 35mm f/2.8L II, 100-400mm f/4.5-5.6L ISL , 50mm f/1.8 II Sigma 50mm f/1.4 EX DG HSM, 2x Calumet Genesis 200
| The Aperture Labexternal link |I know I suck at spelling and grammar
Sigma 50mm f/1.4 for Canon for sale
Photorebel
Sep 10, 2011 03:20 |  #15
I used those very settings Friday night (last night) and thought my pics improved. Not great, but better.
Thanks for posting that link, it is very helpful to me.
Jeff
-Jeff
5DIII, 60D, 50 f/1.2L, 85 f/1.8,100 f/2.8L, 24-105f/4L
480 EXII
23,510 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.0033 for 4 database queries.
PAGE COMPLETED IN 0.04s
Latest registered member is josejoseph1
868 guests, 459 members online
