Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Motorsports
Reply
Thread Tools Display Modes
Old 8th of September 2011 (Thu)   #1
DdavisMotocross
DdavisMotocross's Avatar
Default Filters and Motocross?
Good choice or bad choice?
Like, 58mm MULTI COATED CIRCULAR POLARIZER HIGH DEFINITION FILTER
Photography
DdavisMotocross is offline   Reply With Quote
Old 9th of September 2011 (Fri)   #2
JSkinner
JSkinner's Avatar
Default Re: Filters and Motocross?
I use a polarizer on my 10-22mm wide angle to get the deep blue sky look.
7d, 40d, 24-105L f4, 70-300mm f/4, 28-135mm f/3.5, 10-22mm, 580EXII
www.skinnernetphoto.com
JSkinner is offline   Reply With Quote
Old 10th of September 2011 (Sat)   #3
Chippy569
Chippy569's Avatar
^ just my opinion, but that's maybe a bit too dark in the sky.
CPL is nice if you're only facing one direction but any time you turn you might also need to turn the filter, which when focusing etc. etc. at the same time, gets to be rather quite the hassle.
Chippy569 is offline   Reply With Quote
Old 15th of September 2011 (Thu)   #4
kris142
I just run UV's for protection and leave the effects for Post Processing...
7D 70-200 f2.8L 50 f1.4
KrisBrownPhotography.com *under construction*
Flickr
kris142 is offline   Reply With Quote
Old 16th of September 2011 (Fri)   #5
kit lens
kit lens's Avatar
Sometimes I'll use a CP, but a graduated ND filter will work much better to get a correctly exposed sky.
My flickr
rick_reno is a postwhore
kit lens is offline   Reply With Quote
Old 16th of September 2011 (Fri)   #6
downhillnews
My 1Ds will renders skies like that very often and so does the III versions I have used also!
WWW.DOWNHILLNEWS.COM
1Ds MARK II, 40 D, 16-35 F2.8 II L, 70-200 F2.8 L IS, 35 F1.4 L, 50 F1.2 L, 580 EX II, and 2 580 EX flash's.
downhillnews is offline   Reply With Quote
Old 17th of September 2011 (Sat)   #7
cedew
^^^ I wonder if that's just full frame light fall off?
cedew is offline   Reply With Quote
Old 20th of September 2011 (Tue)   #8
Black Bart
Too dark for my taste it looks fake.
Sky never looks that dark blue.
Black Bart is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Motocross from Budds Creek (Motocross of Nations) Click_09 Motorsports 22 30th of December 2009 (Wed) 15:41
Filters, Filters, Filters...Advice Needed Nistelrooydude Accessories & Storage 12 23rd of August 2008 (Sat) 01:36
Polarising filters - filters aint filters? Drk Orange Accessories & Storage 9 25th of April 2005 (Mon) 17:25
