Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 29th of October 2005 (Sat)   #1
mknabster
mknabster's Avatar
Default Can this be fixed?
I took this at my Halloween party last night w/ my friends w/ my G6 w/ the wide-angle lense, and the lense blocked out the flash. I had forgotten that it would do that. I know that i have to get rid of the red-eye, but is there any way in Elements that I can brighten the large dark spot in this picture?
- Matt
MK Studios
mknabster is offline   Reply With Quote
Old 30th of October 2005 (Sun)   #2
floydianslip6
floydianslip6's Avatar
Default Re: Can this be fixed?
not simple, here's the best I could do with it in like 5 minutes. Not sure exactly how perfect you want it, this should do for just admiring.
floydianslip6 is offline   Reply With Quote
Old 30th of October 2005 (Sun)   #3
floydianslip6
All the leveling creates a LOT of noise in the photo and I don't have a noise reduction filter.
Old 30th of October 2005 (Sun)   #4
Radtech1
Everlasting Gobstopper
Radtech1's Avatar
Now that you that this can be done, the next step would b to blend the two versions.
Rad
"I long to accomplish a great and noble task, but it is my chief duty to accomplish small tasks as if they were great and noble." – Helen Keller
Radtech1 is offline   Reply With Quote
Old 30th of October 2005 (Sun)   #5
Tlee05
"Suck these toes"
Tlee05's Avatar
i am wondering how did u get the center spot so dark :S?
Tlee05 is offline   Reply With Quote
Old 30th of October 2005 (Sun)   #6
RadAL
RadAL's Avatar
after messing around in photoshop, heres what i came up with.
RadAL is offline   Reply With Quote
Old 30th of October 2005 (Sun)   #7
mknabster
mknabster's Avatar
The wide-angle lense was on it, some that's how it came to be so dark. What did you guys use to fix that up? Like, which tools in photoshop, because i wanted to do some editing myself.
- Matt
MK Studios
Old 30th of October 2005 (Sun)   #8
floydianslip6
Basically what you want to do is first add an omni light source.
FILTER>RENDER>LIGHT SOURCES
Center the light source somewhere near the edge of the photo. Then relevel it by going to edit>adjust>levels .
Only thing is that creates a lot of noise in the picture. So a noise reduction filter would help to return it to normal.
Old 30th of October 2005 (Sun)   #9
floydianslip6
The other issue that you face when fixing up this picture is that all three of the people in the middle are wearing black. Having them right next to each other in a dark spot of the shot makes fixing that piece hard. So when setting up a shot next time try to move people around that way the people are better defined.
Old 30th of October 2005 (Sun)   #10
mknabster
mknabster's Avatar
Thanks floydianslip6, you have been a big help!
- Matt
MK Studios
Old 30th of October 2005 (Sun)   #11
floydianslip6
no problem. I have some time tonight so I'll work on getting that image better for yah. Check back around 7 or so. While I'm still pretty new at photography I've been working with photoshop since I was a little kid, so with some more time I'm sure I could make it almost perfect.
Old 30th of October 2005 (Sun)   #12
floydianslip6
Ok, spent a little bit more time and was able to make it a bit nicer. Since I still don't have a noise reduction filter, so it's still a bit noisy, though not anywhere near as much. Here's how this was done.
4 light sources, one spot between the girl and the guy to cut down on the black blob look, one big omni off the page to light the table one small omni on the right side to get rid of the black ring where the shadow used to be, one omni at the top of the table in the center of the people on the right, and another right on the girl.
This made the image levels a lot more stable and easier to adjust. I also adjusted the image curve.
Old 30th of October 2005 (Sun)   #13
floydianslip6
if someone with a noise reduction filter could give this a once over we'd be in business!
Old 30th of October 2005 (Sun)   #14
MattyB
MattyB's Avatar
Before:
After:
mainly used shadows and highlights, levels, clone, contrast, etc etc.
Matt Bennell
Camera: Canon EOS 300D DSLR Black
Extras: 18-55mm, 50mm 1.8, Tripod, Imagination
Field: You name it, I've shot it.. Or about to shoot it today
Recently Updated Folio/Gallery -> http://mbp.fotopic.net/
MattyB is offline   Reply With Quote
Old 30th of October 2005 (Sun)   #15
tiziano
tiziano's Avatar
The first one is yours after noisereduction, the second is my attempt.
Tiziano
Gear list
tiziano is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
can this be fixed? luannf1980 Weddings and Other Family Events 10 7th of April 2007 (Sat) 23:40
I fixed me....... Cleo199 People 7 10th of January 2007 (Wed) 11:06
Can this be fixed? casp3r Transportation 6 7th of January 2007 (Sun) 07:08
I am out , until it's fixed kallousa Macro 7 27th of April 2006 (Thu) 17:39
fixed akimdream Forum Talk 1 12th of August 2004 (Thu) 16:56
