Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 30th of October 2005 (Sun)   #1
Rocket850
Rocket850's Avatar
Default Light meter vs Camera meter
I see a lot of you use the Sekonic L358 light meter. How much better is this going to be than my 20d's metering system? I just got the 20d a few weeks ago and have been practicing using the different modes. Is the Sekonic L358 mainly used for indoor photography?
Jay w.
Rocket850 is offline   Reply With Quote
Old 30th of October 2005 (Sun)   #2
SkipD
SkipD's Avatar
Default Re: Light meter vs Camera meter
A meter built in to the camera works reasonably well for "average" conditions. A handheld meter, particularly one as versatile as the L-358, lets you use the meter in ways is either difficult or impossible to use the camera's meter.
The biggest and most obvious difference is the ability to use the handheld meter as an incident meter - measuring the light falling on the subject as opposed to the light reflected from the subject. The meter in any camera is only a reflected light meter. The L-358 can also measure light from flash sources - something that meters in only a very few cameras (I never heard of any until only recently) can do.
You will occasionally run into a situation when you want to photograph a high-contrast (very bright to very dark) subject. Most built-in meters don't handle that sort of thing well unless you really know how to make it work for you. With a handheld meter, you can (usually) easily measure the extremes and make a decision about the resulting readings that the meter gives you. If you know, for example that your camera only has a 5-stop latitude (the difference between the brightest and darkest subject components that it can record well) - typical for today's digital cameras - then you can see on the meter what the range of the subject brightness is and, if the range is beyond the camera or film's latitude, you can choose which end of the spectrum to favor.
If you are trying to photograph a snow scene, for example, the built-in meter (or any reflected meter, for that matter) will give you a reading that tends to make the snow look like it's grey. Using the handheld meter in an incident-reading mode will give you a reading based on the amount of light hitting the subject, and you can use that reading directly resulting in a photo that looks like snow and not coal dust on snow. The same is true - but in reverse - for subjects that are largely dark.
With an attachment, the L-358 can also be a 1° spot meter. I don't know of any meters built into cameras that can do that with anything but very long lenses.
Skip Douglas
A few cameras and over 45 years behind them .....
SkipD is offline   Reply With Quote
Old 30th of October 2005 (Sun)   #3
Raymate
Great reply... thank you, I wanted to know that too
Canon: EOS 5DmkII • 50D • 40D • 350D • 100 f2.8L IS Macro • 70-200 f4L • 24-105 f4L IS • 17-40 f4L • 50 f1.4 • 60 f2.8 Macro • 85 f1.8 • 430EX • 580EX II • ST-E2
Sigma: 10-20 f4-5.6 EX DC HSM • 30 f1.4 EX DC HSM • 17-50 f2.8 EX • 24-70 f2.8 EX DG MACRO
Apple: CS3, Aperture & iPhoto. Various Manfrotto, Portaflash, Battery Grips, SanDisk & Lowepro
alamy: my stock photography
Raymate is offline   Reply With Quote
Old 30th of October 2005 (Sun)   #4
Rocket850
Rocket850's Avatar
Great answer Skip, thanks! Do you think a light meter will help with the "white sky" syndrome? I'm getting better at avoiding this problem but if a light meter will help it may be worth getting.
Jay w.
Old 30th of October 2005 (Sun)   #5
SkipD
SkipD's Avatar
Jay, that scenario is similar to the generic "high contrast" situation like I alluded to before.
Careful use of a meter is critical to success in these situations. I don't think I would let the camera just decide for me automatically, as that leads to poor results more often than not.
Unfortunately, an incident light reading wouldn't work as well to determine how bright the sky is - because it is as much a light source as it is part of the subject. It's kind of difficult to measure the light falling on the sky without a really tall ladder . Thus, I would use a reflected light meter measurement (probably the in-camera meter because it's there, but seeing results on my L-358 is easier) to determine the difference between the sky and the darkest portion of the scene on the ground that I cared about. I would then calculate the difference.
If the difference between high and low readings is 5 stops or less, I would set the camera for mid-point between the readings. If it's more than 5 stops, then it's decision-making time. The questions I would ask myself are: What is more important to you - the sky or the shadow areas on the ground? Is there a way that I can deal with this situation such as a graduated neutral density filter or taking two shots and combining them in Photoshop?
Does this help the thought processes?
Skip Douglas
Old 30th of October 2005 (Sun)   #6
tim
Light Bringer
tim's Avatar
Jay w.
The most practical solution, like Skip says, is doing two exposures and blending them in Photoshop. It's a pain in the arse, but there aren't many other options, apart from annoying filters. Another solution is to do the photos at dusk or dawn when the sky's less bright.
tim is offline   Reply With Quote
Old 30th of October 2005 (Sun)   #7
PacAce
Moderator
PacAce's Avatar
How about the 1DmkII with a lens greater then 65mm? Or you can get close with a 50mm lens (approx. 1.4 degrees spot).
...Leo
PacAce is offline   Reply With Quote
Old 30th of October 2005 (Sun)   #8
SkipD
SkipD's Avatar
Cool. I now have another reason to upgrade from my 20D. Just don't tell Cindy, please.....
Skip Douglas
Old 30th of October 2005 (Sun)   #9
PacAce
Moderator
PacAce's Avatar
Of course I won't (the more blackmail matter I have in my back pocket, the better, he-he-he ).
...Leo
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
How does the camera meter for light? Where is the metering system? timmytimmytimmy Canon EOS Digital Cameras 12 27th of November 2006 (Mon) 20:00
How to use light meter with on-camera flash? Kim22 Small Flash and Studio Lighting 4 29th of June 2006 (Thu) 16:10
Why use a light meter when you have one in camera? DocFrankenstein Accessories & Storage 38 4th of November 2004 (Thu) 09:39
Light Meter vs Camera Meter Top-Cat Canon EOS Digital Cameras 3 1st of August 2004 (Sun) 16:23
