Thread started 01 Oct 2011 (Saturday) 05:16
Prev/next
Tested: 2x Elinchrom D-lite 4 it and Vagabond Mini Lithium compatibility
toxic
California
Oct 01, 2011 05:16 |  #1
I just did some quick testing with both of my D-lites hooked up to a VML (120VAC). Same power for both, from 2.0 to 6.0 (25-400 Ws). I only did each power setting a couple times, so your times might vary a tenth or two because of slight variations and human error.
Recycle time (seconds):
2.0: 0.9
3.0: 1.2
4.0: 1.6
5.0: 2.8
5.5: 3.7
5.9: 4.5
6.0 does not work, I get an E.4 (charge fault) error. This happens when going from any setting < 6.0 up to 6, or if the lights are turned on at 6.0, the error will come out after the first pop.
Also, the first pop after being turned on always takes a bit longer. The "ready" beep usually goes off twice.
TMR ­ Design
TMR Design's Avatar
Joined Feb 2006
Huntington Station, NY
Oct 01, 2011 07:55 |  #2
It's very important to understand that the Elinchrom E4 error is not just a glitch or indication that the strobe couldn't stabilize the voltage, but it's an indication that that the voltage drop was rather substantial, and that the inverter isn't working correctly and safely with the Elinchrom bi-voltage power supply.
This is a huge problem using inverters with bi-voltage power supplies and should not be shrugged off and 'just an error'.
PCB does not support third party strobes and this issue will not be addressed.
I realize that you can get bi-voltage strobes to work with the VML but it does not mean they are working correctly.
Honestly, I don't recommend that combination.
Robert
spacetime
spacetime's Avatar
Oct 01, 2011 12:24 |  #3
Will a single D-lite4 run at full power? I have the 230VAC VML and it will run two strobes at all settings but recycle times are poor and the double beeps and LCD blanking out amongst other issues make you wonder what if any damage is occurring.
110yd
Joined Jan 2005
Oct 01, 2011 12:57 |  #4
spacetime wrote in post #13191519external link
I would not put two strobes that were (Multi voltage 90-260VAC) on a VML. The inverter can not safely handle the PEAK current draw of two lights, and something is going to eventually burn out, either the lights or the inverter.
Hope this helps,
110yd
Csae
Csae's Avatar
Montreal, Canada
Oct 01, 2011 17:47 |  #5
It does, its not recommended so use it at your own risk.
Feel free to call me Case.
CasePhoto.caexternal link - FanPageexternal link
-Montreal based Photography.
c2thew
c2thew's Avatar
Not enough minerals.
Oct 01, 2011 23:47 |  #6
of course you can use a single d-lite 4 at full power. there shouldn't be ANY issues with one d-lite 4.
There is a youtube video that shows that 2 d-lite 4 IT's can be run off the vml which agree with the OP's post.
Flickrexternal link |Gear|The-Digital-Pictureexternal link|The $6 mic | MAGIC LANTERNexternal link | Welding Filter
Go Support Magic Lantern 2.3!!
TMR ­ Design
TMR Design's Avatar
Joined Feb 2006
Oct 02, 2011 04:42 as a reply to c2thew's post |  #7
Except for the fact that the E4 message comes up often. The fact that the OP is getting the delays in stabilization, power relay glitching and the E4 error indicates that it's not working well at all.
If people want to ignore the error, that's on them, but I would not endorse this practice and would not call it compatible.
Robert
eduardofrances
Oct 02, 2011 05:42 |  #8
Robert and 110yd x2 the fact that your D-lite is telling you there is an error isn't because there is a glitch on the auto-diagnosis system of the D-lite but rather to let you know that there's potentially an issue with the inverter not being able to work properly with the D-lite that can damage your D-lite, the VML or both.
If you are getting this kind of issues I would not recommend at all using the VML with your D-lites to avoid damaging your gear.
http://flickr.com/phot​os/eduardofrances/external link :D
c2thew
c2thew's Avatar
Oct 02, 2011 15:13 |  #9
PCB will warranty the VML so you can take the damaging to the VML out of the equation. There is internal circuitry that should prevent the VML from overloading. I also believe that there is circuitry in the elinchrom strobes that also prevent the strobe from getting damaged. However, since there aren't any protections against the elinchrom strobe, I would use at each own's discretion
http://www.youtube.com​/watch?v=_chkTSaG1HMexternal link
Csae
Csae's Avatar
Montreal, Canada
Oct 02, 2011 16:31 |  #10
I can use 1x Dlite4 (non-it) at full power and never get a E4.
I'd rather not use both as its been long-stated the the drop in current is massive enough to cause or potentially cause issues, but i've never had -any- indications of problems with only 1.
I should mention, that i have used two of my dLites on a non-pure but high grade sinewave inverter before at full power for hundreds of pops and keep that around in case the VML fails.
The DLites aren't the squishy things they are made out to be, these are well-made and solid lights, i have had them topple to the ground light-stand and all several times and they are Still kickin.
This is all at your own risk, so judge by yourself, some people are in fact using 1 Dlite with the VML without any issues, i am one of those.
4,658 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00118 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is Lisa28
777 guests, 310 members online
