#1 |
I still see some intermittent brightness flickering (slight but noticeable) in my videos although I have disabled the following:
Auto lighting optimizer Peripheral correction Highlight tone priority High ISO noise reduction Long exposure noise reduction AWB I'm in manual mode. Is there anything else that I'm missing? Looking more closely at the flicker that I'm seeing, it seems to occur in the shadow areas when I pan the camera to a scene which has lower average brightness. Feels like the Automatic Lighting Optimizer is still working although it has been disabled. Maybe it is only disabled for jpeg but not movies? Thanks for the inputs |
| sponsored links |
#2 |
Are you using a variable aperture lens?
#3 |
Yes, it's the 24-105 f4 IS on manual focus and IS on.
| sponsored links |
#4 |
That lens is a constant aperture lens with it's largest opening being set at f4, but if you zoom in to a tighter framing, the f stop doesn't change like some cheaper lenses.
I would also turn off the IS and see if that doesn't help you out.
Chas Gordon 7D Gripped/40D Gripped/10-24/EF24-70 f2.8L/EF70-200 f4L/EF50 f1.8 Mk I/EF85 f1.8 http://www.flickr.com/photos/chaswg/ http://vimeo.com/user9461302/videos |
#5 |
It's happening in natural lighting as well. So it's nothing to do with the lighting. My firmware is current 2.0.9. Lens used is 24-105 f4 IS and does not matter if IS is on or off. I've tried prime lenses such as 50f1.2 and 85f1.2 and the problem is still there.
#6 |
Guys, I think I found the problem. It was the wmp media player. When I played the files using Quicktime, they were perfectly fine. I guess wmp does some kind of brightness adjustment.
#7 |
Excellent! That's an easy fix.
#8 | |
Quicktime files have gamma shift issues (midrange tones) once in a while and maybe WMP wasn't reading the files right, causing the issue. Regardless, good to hear its fixed. |
| Thread Tools | |
| Display Modes | |
| 30D intermittent CF ERROR | ikolpdog | Canon EOS Digital Cameras | 3 | 13th of December 2010 (Mon) 12:42 |
| LG televisions: Why wouldn't Canon's 1080p videos work if 720p videos do? | C2S | Digital Video | 14 | 22nd of February 2010 (Mon) 13:17 |
| 5d Intermittent red dot in images | Pollyanna | Canon EOS Digital Cameras | 12 | 25th of August 2009 (Tue) 11:01 |
| Intermittent Err_99 | Wrench | Canon EF and EF-S Lenses | 21 | 22nd of January 2006 (Sun) 12:10 |
| problems with picture brightness vs. LCD brightness | dilla | General Photography Talk | 2 | 24th of September 2004 (Fri) 19:44 |
