Thread started 22 Oct 2011 (Saturday) 17:14
Prev/next
FF 17-55 equivalent?
Mr. ­ Bill
Mr. Bill's Avatar
Southwest USA
Oct 22, 2011 17:14 |  #1
If one has gone FF, what is the best replacement for EF-S 17-55?
I really would like to get something that has IS yet still have the wide angle + 2.8 or better.
I currently have a 17-40L and keep finding that it just doesn't cut it in low light situations, even if when bumping up the iso.
Link to my Picturesexternal link
Madweasel
Madweasel's Avatar
Fareham, UK
Oct 22, 2011 17:23 |  #2
The nearest thing would be the 24-70/2.8L, but it doesn't have IS.
Mark.
Snydremark
Myth-informed
Gallery: 40 photos
Issaquah, WA USA
Oct 22, 2011 17:24 |  #3
24-70, I would imagine is going to be the closest thing for you for low light in a zoom on FF. Unfortunately, no IS to be found on a short, fast zoom for full frame.
- Eric S.: My Birds/Wildlife (external link) (7D MkII, Canon 10-22 f/3.5-4.5, Canon 24-105L f/4 IS, Canon 70-200L f/2.8 IS MkII, Canon 100-400L f/4.5-5.6 IS)
Lone ­ Rider
Lone Rider's Avatar
Joined Jun 2010
Mount Isa, North West Qld
Oct 22, 2011 17:32 |  #4
No such animal in the Canon line up, unless you want to push it out to 3.5 - 5.6 on the 15-85?
Trevor
Canon 5D3 24-70L 70-300 DO IS 18-55 Sigma 10-20 430EXII BACKUP: 550D
borism
borism's Avatar
Florida, Weston
Oct 22, 2011 17:34 |  #5
Yes the 24-70 2.8 from canon or Sigma versions or the 28-75 from Tamron, but the Canon with USM and best build and optics is the closest thing to the 17-55 IS
For low light situation Fast Primes lens are still king even without IS, but the f2.8 and High ISO capabilities of todays FF cameras like 5D2 you should be able to tackle many situations
CANON 6D - SONY A6000
borism
borism's Avatar
Florida, Weston
Oct 22, 2011 17:35 |  #6
Lone Rider wrote in post #13290518external link
The 15-85 is not a FF lens, is a EFS lens and the Op refers to the FF equivalent to the 17-55 2.8
NivoMedia
Joined Mar 2011
Oct 22, 2011 17:35 |  #7
what about a 16-35?
I use a {3+2}D Mark [10-8] and a (23-16)D and a Nikon D(75+75)x2s and a Nikon D(38+2)x
Lone ­ Rider
Lone Rider's Avatar
Joined Jun 2010
Oct 22, 2011 17:37 |  #8
borism wrote in post #13290528external link
Apologies I missed that
Trevor
mjHession
mjHession's Avatar
Schoharie, NY
Oct 22, 2011 17:38 |  #9
NivoMedia wrote in post #13290530external link
what about a 16-35?
This would be a far shorter lens.
Primary Gear - 1D III; Σ 35mm f/1.4 A - 135mm f/2 L - 300mm f/2.8 L - Canon 1.4x II & 2x II
Full Gear List
Feedback
My Smugmugexternal link
District_History_Fan
Oct 22, 2011 17:44 |  #10
Madweasel wrote in post #13290498external link
The Brick also has excessive field curvature on the wide end... Bokeh and color are great though, as is sharpness if you can get one that is dialed in.
There really is no FF equiv of the EF-S17-55 f/2.8 IS.
www.ericmcferrin.smugm​ug.comexternal link
Mr. ­ Bill
Mr. Bill's Avatar
Southwest USA
Oct 22, 2011 17:50 |  #11
I should also mention that I have the 24-105L as well. Just took a look at the 16-35 and OUCH, that is not a cheap piece of glass. Guess I will just have to keep practicing my breathing technique when shooting in low light and hope for the best.
BrentBoshart
Atwood, Ontario
Oct 22, 2011 18:05 as a reply to Mr. Bill's post |  #12
I recently upgraded from a 30D to a 60D. My 17-55 f/2.8 IS was the reason I chose the 60D over the 5DII. I did not want to give this lens up.
Brent
A7RII | Zeiss Loxia 21 | Zeiss Sonnar 55 | Sony FE 90mm Macro G | Zeiss APO Sonnar 135
Oct 22, 2011 18:09 |  #13
BrentBoshart wrote in post #13290631external link
Yep, the 17-55 is one of the reasons I like the crops too.
FEChariot
FEChariot's Avatar
Joined Sep 2011
Oct 22, 2011 18:37 |  #14
Mr. Bill wrote in post #13290581external link
The 24-105/4 is the FF version of the 17-55. With FF your DOF at F4 is the same as a 2.5 on crop at the same framing. The 24-105 is both wider and longer on FF than the 17-55 on crop. And finally the 5D2 has at least one stop better ISO performance than any crop camera so you can push ISO to make up for the 1 stop loss in shutter speed.
If canon were to upgrade the 24-70/2.8 with IS, then they would need a 15-43/1.8 IS on crop to be the equivalent and that beast doesn't exist.
Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
JeffreyG
JeffreyG's Avatar
Gallery: 34 photos
Detroit, MI
Oct 22, 2011 19:14 |  #15
Mr. Bill wrote in post #13290472external link
Actually, the nearest equivalent lens to the EF-S 17-55 on a FF camera is the EF 24-105/4L.
Here is why a lot of people don't quite grasp this:
1) 24-105 on a FF sensor gives the same FOV range as a 15-65 would on 1.6X, so the 24-105L on FF is actually both wider and longer.
2) f/4 on a FF sensor gives the same DOF (at equal framing) as f/2.5 does on 1.6X. So the 24-105L is actually capable of very slightly shallower DOF (but they are nearly equal).
3) The FF sensor has better high ISO performance by at least one stop for equal technology, so the f/4 of the 24-105 is at worst equal for light gathering capability.
So there you are. Incidentally, the 24-70 is capable of much shallower DOF and light gathering on FF than the 17-55 on 1.6X, but it does lack IS. For moving subjects, the 24-70 on FF is hands down better.
I use a Canon 5DIII
5,083 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00145 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is RichardGates
1042 guests, 516 members online
