Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography
Reply
Thread Tools Display Modes
Old 22nd of October 2011 (Sat)   #1
tefu
Default Fujica Lens to EOS
Do you guys know which adapter that I could buy for Fujica lenses to EOS body?
I've looked at ebay, they have nothing.
Can I use M42 adapter to EOS mount?
tefu is offline   Reply With Quote
Old 31st of October 2011 (Mon)   #2
SnapFire
Default Re: Fujica Lens to EOS
It depends on the lens mount. From what I've found Fujica Lenses were offered in (at least) M42 mount and Fujica X Bayonet mount. If your lens is a screw mount then you have a good chance of it being an M42. I don't think they ever made any Fujica T-mount lenses... Did they ever pair them with Leica's? Leica's screw mount was an M39. If it's a screw mount grab a ruler and measure the diameter of the mount. If it's 42mm then there's a good chance it's M42. T-mount was also 42mm but they used a different thread pitch making it non-compatible with the M42. Best of luck!
SnapFire
Canon 5D
Canon 50D
SnapFire is offline   Reply With Quote
Old 9th of May 2012 (Wed)   #3
riversrum
Hi, I am new to this forum, so not really sure where to post this question.
I have a D60 (not 60D) Canon body that has been converted for Astro use. I bought an M42 to EOS adaptor. I have a few old M42 lenses, but when coupled to the body with the camera set to Manual exposure and Manual focus all I get is an Error Code 01. Any help much appreciated.
riversrum is offline   Reply With Quote
Old 15th of May 2012 (Tue)   #4
tonylong
....winded
tonylong's Avatar
Well, the only advice I've seen about that sort of problem is to thoroughly clean the contacts on the body and the lens with a pencil eraser.
Tony
Tony Long Photos on PBase
Wildlife project pics here, Biking Photog shoots here, "Suburbia" project here! Mount St. Helens, Mount Hood pics here
tonylong is offline   Reply With Quote
Old 22nd of May 2012 (Tue)   #5
lienyingp
lienyingp is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Fujica St605 with Fujinon 55mm f/2.2 and Sunpak auto 124 Flash Darkwand The POTN Lounge 2 3rd of June 2011 (Fri) 13:27
Got a Fujica Sound ZXM500 phylet The POTN Lounge 1 23rd of January 2007 (Tue) 14:51
