Thread started 25 Oct 2011 (Tuesday) 08:29
Prev/next
1D Mark IV - Selecting AF point
Scott_online
Oct 25, 2011 08:29 |  #1
I'm having a bit of a job using the 8-way multi-controller (i.e. the joystick) to select AF points when pressing in one of the 45deg directions. Sometimes it works; sometimes it doesn't.
When I'm zoomed in on an image during playback, I can move around the image at 45deg so I think the controller hardware is OK. It just seems to be when selecting AF points.
Has anyone else experienced this?
Sgt.Ed
Sgt.Ed's Avatar
Eau Claire, WI
Oct 25, 2011 10:24 |  #2
Scott
For me I nearly always center the AF point before moving around. I'll push the AF selection button, push the joystick straight in and then move the AF point. It may not be the fastest but it works for me.
Ed
Ed
GEAR40D, 1D MKIV, 24-70 f2.8L, 70-200 f2.8L, 500 f4.0L, Canon 1.4 teleconverter, 580 EXII Speedlite, Gitzo GT 3530LS, Wimberly WH-200, 190X PROB Manfrotto tripod and a bunch of other stuff
MYFlickrexternal link
Scott_online
Oct 25, 2011 11:06 |  #3
Sgt.Ed wrote in post #13303607external link
Scott
Ed
When you're moving the AF point from the centre, are you able to consistently move it in a 45deg direction? For example, if I'm trying to move from the centre point to the upper left point, I'd like to take the shortest route rather than having to go two clicks up and three clicks left. My other bodies let me do this although they have fewer AF points to choose from.
I phoned Canon technical support about it earlier today. The rep. I spoke to tried it on a body there and said he found it quite tricky also so I suspect it's a software quirk rather than a hardware fault.
RichSoansPhotos
London, UK
Oct 25, 2011 11:42 |  #4
banned
I'm about to rent out this camera, how do you let the AF points track the subject?
Sgt.Ed
Sgt.Ed's Avatar
Eau Claire, WI
Oct 25, 2011 13:26 as a reply to RichSoansPhotos's post |  #5
Scott
I'm using my right thumb to work the joystick and I have some problems going up to the right. Often I'll end up with the AF point moving right which requires two additional moves to get into the upper right corner.
I don't find it to be an issue with the type of shooting I normally do.
Ed
Ed
Sgt.Ed
Sgt.Ed's Avatar
Eau Claire, WI
Oct 25, 2011 13:33 |  #6
400dabuser wrote in post #13304001external link
You can set the custom function C.FnIII-8 to:
0: Disable
1: left/right AF point
2: Surrounding AF points
3: All 45 points
You'll also be able to set the sensitivity for tracking under C.FNIII-2.
Ed
Ed
Scott_online
Oct 25, 2011 13:51 |  #7
Sgt.Ed wrote in post #13304568external link
Scott
Ed
Thanks.
In my case I mainly have problems going up and to the left. I've tried reducing the number of selectable AF points (C.Fn III-10) to see if that helps but it doesn't. The controller seems to work fine in other situations so it's probably a minor bug in the AF point selection code.
I move the AF point around a lot so it's a bit of an inconvenience for me. In fact, one of the main reasons I got the MkIV was the greater spread of AF points.
RichSoansPhotos
London, UK
Oct 25, 2011 15:46 |  #8
banned
Sgt.Ed wrote in post #13304598external link
0: Disable
3: All 45 points
Ed
Cheers for that
1,171 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00141 for 4 database queries.
PAGE COMPLETED IN 0.01s
Latest registered member is pineaple
871 guests, 462 members online
