Thread started 23 Nov 2011 (Wednesday) 11:54
Uni White Balance with 5D mkii
sunking39
Nov 23, 2011 11:54 |  #1
How can i determine uni wb for the 5d mk ii?
Does the dark frame custom image method work? Or should i download an image made from a magenta chart?
What else is there to it?
How has your experience been like?
TY
tonylong
...winded
Gallery: 60 photos
Nov 23, 2011 12:03 |  #2
Guillermo Lujk (who shows up here occasionally) has developed this technique. Here's his discussion/tutorial:
http://www.guillermolu​ijk.com/tutorial/uniwb​/index_en.htm (external link)
You can read Web commentary discussion about this simply by Googling a term, like "guillermo uni white balance" (the following result is for MS IE, you might need to do your own:)):
https://www.google.com …d=ie7&rlz=1I7AD​RA_enUS364 (external link)
Tony
sunking39
Nov 23, 2011 12:49 |  #3
tonylong wrote in post #13441275 (external link)
Thank you Tony,
Actually, the way i first learned of uni wb was through Guillermo's article. I downloaded the file he posted, but he also says there are better, more precise techniques. He says that a totally over exposed image does not work. Also he makes no mention of the dark frame technique. So I wonder if the technique explained here : ( http://photography-on-the.net/forum/showthre​ad.php?t=485349 ) works or if my only choice is using the file provided in his page.
TY
tzalman
Fatal attraction.
Nov 23, 2011 16:25 |  #4
I use the black frame method - lens cap on, ISO 100, shutter speed 1/8000. The ISO and SS are probably unnecessary, but just for the hell of it. The method is fast and easy and the multipliers listed in the Maker Notes are RGGB > 1.024, 1.024, 1.024, 1.024.
Actually, I don't think precision needs to be an issue here. The goal is zero WB, but even if there is a little WB done, as long as it is only a little and doesn't affect the histogram significantly it's not a problem. After all, the Uni-WB is only an aid to exposure setting and as soon as you get the file into the RAW converter you will apply a WB that is more appropriate for the light.
Elie / אלי
sunking39
Nov 25, 2011 14:15 |  #5
tzalman wrote in post #13442429 (external link)
So this method is good enough?
I read several of your post when I did my initial research, thank you.
One more question, when I take the black frame do I take it with any specific picture style, contrast at -4, 0? or doesn't that matter?
Has UNIwhite balance improved the quality of your pics and is it annoying to deal with the green cast?
TY
tonylong
...winded
Gallery: 60 photos
Nov 27, 2011 14:19 |  #6
sunking39 wrote in post #13450191 (external link)
Well, it accomplishes what you want, so sure -- that way you don't need to always have an image on a card if you want to change between Custom WB and Auto or a preset.
Do you have a camera? A lot of your questions could be answered if you took out a camera and did your own tests!
TY
I'd say there are some occasions where using the UniWB can help you to accurately "nail" your exposure, although there are other approaches you can take when your scene is "color-challenged". So to me it's a matter of an "educated preference".
As to whether the green cast is "annoying", well, again, it's a matter of preference...if you have made an educated choice to use it, then what does it matter? We typically don't judge the image by what's on the camera LCD, and in the Raw processor it's a few seconds to set the WB...
Tony
MGiddings ­ Photography
Nov 28, 2011 06:45 |  #7
I have to say I have just tried this method from Guillermo Lujk using the 5d Mk2 file from his web page and it is indeed very accurate and very pleasing. This could say me huge amounts of time pending further testing.
http://www.mgiddings.c​om (external link)
2,513 views & 0 likes for this thread
Latest registered member is Ronaldwilliam
663 guests, 282 members online
