Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 9th of November 2005 (Wed)   #1
dobbs25
Default Using Internal Intervalometer
wondering if anyone knew how to use the Internal Intervalometer on the 20d. i can't find specific info in the users guide. could someone point me in the right direction.
thanks
t
dobbs25 is offline   Reply With Quote
Old 9th of November 2005 (Wed)   #2
Salleke
Default Re: Using Internal Intervalometer
thanks, t
The 20D has no build in intervalometer AFAIK. You can buy a TC 80 N remote and used as intervalometer.
Good luck.
Salleke is online now   Reply With Quote
Old 9th of November 2005 (Wed)   #3
transcend
transcend's Avatar
or tether it to a laptop and use any one of a number of software packages that do this.
http://www.fraserbritton.com
transcend is offline   Reply With Quote
Old 9th of November 2005 (Wed)   #4
dobbs25
i was told otherwise but i thought i would check to make sure i wasn't crazy. thanks for the insight.
Old 9th of November 2005 (Wed)   #5
dobbs25
what software would you recomend
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
S3IS Intervalometer. Scissorman Small Compact Digitals by Canon 1 4th of May 2007 (Fri) 09:13
S3 and Intervalometer wickiup Small Compact Digitals by Canon 8 23rd of April 2007 (Mon) 02:07
intervalometer namydal Small Compact Digitals by Canon 2 12th of April 2006 (Wed) 04:31
Intervalometer keitaro Small Compact Digitals by Canon 3 11th of April 2006 (Tue) 18:24
intervalometer t_hughes Canon G-series Digital Cameras 7 23rd of December 2003 (Tue) 10:18
