Thread started 30 Nov 2011 (Wednesday) 13:06
Putting OS onto a new SSD drive on WIndows 7
mr2step
Nov 30, 2011 13:06 |  #1
Hi everybody. I am curious if anyone knows how difficult it is to move an OS to a SSD drive on windows 7. I have a new gateway but want to upgrade to a SSD at some point. The issue I am having is that I've been told ( by company IT guy) that since my computer came "pre packaged" with no install cd, that it MIGHT not boot up onto the SSD. I am a total computer NOOB but have been learning a lot over the last few weeks researching computers. My new setup consists of Intel i5 2300 Hz, 8 gigs RAM, 1tb HD, dual monitors. I have already installed LR3 and PSE10 on it but not run either app yet. My problem is, I want to know if I will be able to move over all the OS to another drive once I get one to optimize LR3 for speed. I'm presently stuck with one drive and don't want to do anything just yet in case I can move it over without hassle. Thanks
Do what you love, and you will never work a day in your life.
www.Brettmissick.com (external link)
http://www.facebook.co​m/brettmissickphotogra​phy (external link)
muskyhunter
Joined Nov 2010
Nov 30, 2011 13:31 |  #2
you'll need a clean install to work properly.
mr2step
Nov 30, 2011 14:08 |  #3
I guess my question is IF it will work with computer that came w/o boot cd. Yes I made a backup copy first thing but wasn't sure if it could read it off that.
CactusJuice
Nov 30, 2011 14:58 |  #4
Obviously a clean install is preferred, but yes migration will work. However, I would recommend only if you should be comfortable with comfortable with terms and tasks such as "backup", "defragmenting", "ghosting" and "partitions", for example. Migrating is time consuming. Plan to spend an entire afternoon from start to finsih. While not overly complicated, probably not for the faint of heart. There might be extra risk in your case if you're not able to obtain your original installation software.
Keep in mind with SSD you are usually going from big to small. That is, your SSD holds less data than is (possible) on your current hard drive. If that's the case then you first will want to get your current drive's used size down so it will fit on your SSD. This includes defragmenting. Think about it, you could have a 360 GB drive currently. Even if you're not usuing the entire 360 GB, there still might be data written way out there. So first shink and defrag. Then you can ghost and restore onto the SSD. I'm oversimplifying but that's the general process. Your SSD might come with software to help with this.
There are many articles online that go over the steps in detail.
http://lifehacker.com …hout-reinstalling-windows (external link)
tim
Light Bringer
Nov 30, 2011 15:42 |  #5
I suggest a clean install. Go into the BIOS and set the hard drives to AHCI (not IDE) first.
When install Win7 to an SSD sometimes it hangs for a half hour early on in the install process. Just let it go for up to an hour or two and it'll probably recover.
gotaudi
Nov 30, 2011 16:49 |  #6
I would also suggest a clean install, some have run into alignment issues with cloning software. Windows is also better when it installs itself in the correct mode such as IDE vs. AHCI. if you clone the a system from an IDE to AHCI you have to do some extra steps to get it to work in that particular mode.
BluewookieJim
Nov 30, 2011 19:33 |  #7
not saying this is right for everyone, but I put intel SSDs in both my desktop (win 7 pro) and my notebook (win 7 home premium) earlier this year. I did a clean install on the notebook, and used the migration software on the desktop. I havent had any problems with either.
My Gear and Stuff :: My Zenfolio Gallery (external link) :: My Flickr (external link) :: http://photos.kodanja.​net (external link)
sbattey
Joined Mar 2011
Dec 01, 2011 01:07 |  #8
Some SSDs come with software to do this for you. My father just bought one that came with norton ghost, it worked fine but I ran into boot record issues and had some trouble. For a computer "noob" I would suggest paying someone to do it. Getting a boot CD is only the start of the journey, you have to hope there are drivers for your hardware on the CD as well. Windows 7 is better with drivers than vista and XP were, but there can still be trouble.
Canon 7D | Canon 50mm f/1.4 | 430EX II
Blog (external link)
cccc
Gallery: 18 photos
Dec 01, 2011 02:15 as a reply to  @ sbattey's post |  #9
Clean install is the best way. Make sure the drive is large enough, I tried doing it on a 64GB "boot drive" that held all of my programs as well... terrible idea. It died on me.
Reinstalling everything and reimporting lightroom settings and libraries was the hardest thing for me...
If I could do it again, I would I'd have ponied up for a large SSD and a proper RAID setup for all the media.
PaulSoebekti
Joined Dec 2002
Dec 01, 2011 11:02 |  #10
Hi there.
It's possible, here's a link for more detailed steps.
http://www.sevenforums​.com …fer-operating-system.html (external link)
Paul
Methodical
Gallery: 158 photos
Dec 02, 2011 02:33 as a reply to  @ PaulSoebekti's post |  #11
I see both of you guys suggested the opposite settings for the same type install. Which is which for which situation (i.e. clean install or migration etc.)?
tim wrote in post #13475500 (external link)
gotaudi wrote in post #13475818 (external link)
My Treasure Chest
MethodicalImages (external link)
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
EvilXSI
Joined Nov 2011
Dec 07, 2011 21:25 as a reply to  @ Methodical's post |  #12
Use AHCI for either install. IDE does not support TRIM, which is important for the SSD's performance. Also, if for some reason you need to switch to IDE you can just change the BIOS setting. Going from IDE to AHCI, however, requires a registry edit.
Canon 450d, 18-55mm 3.5-5.6 EF-S, 50mm 1.8 Pentax Takumar, m42 to EOS mount adapter
Canon AE-1 circa 1979, 50mm 1.8 FD
Numenorean
Dec 07, 2011 21:36 |  #13
Clean install is preferred but you can get imaging software which will copy over to the SSD assuming there is enough space.
hollis_f
Dec 08, 2011 07:44 |  #14
I've used Acronis to clone to my SSDs twice now. Takes just over an hour, unattended, to copy the OS drive to the SSD in an eSATA docking station. A fresh install would take around three days (finding the various serial numbers and installing all the different software).
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
EvilXSI
Joined Nov 2011
Dec 08, 2011 09:40 |  #15
A fresh install shouldn't take more than a few hours. I just did a fresh install on a new SSD this week, windows 7 Ultimate, CS5 master collection and MS Office 2010 took three hours tops.
3,454 views & 0 likes for this thread
version 2.0 /
Latest registered member is mason.snipes
765 guests, 408 members online
