Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 6th of December 2011 (Tue)   #1
vettori
Default advice re: what gear to hire
Hi all, just after some advice. I’m looking to hire a camera over the Christmas break and was looking at the 5D Mk II. I currently have the 400D and I mainly photograph my children. I have the cheapie EF 50mm 1.8 lens and my question is this – I can really only afford to hire the body and not a pro lens, but do you think the 5D would be completely wasted if I were to use it with such a cheap lens, or should I maybe look at hiring the 600D instead and also hire a pro lens with the money I’d save?
I’d appreciate your thoughts.
vettori is offline   Reply With Quote
Old 6th of December 2011 (Tue)   #2
Wide Boy
Wide Boy's Avatar
Default Re: advice re: what gear to hire
The lens is brilliant, look over in the lens sample section and you can see some of the superb results people are getting.
Why hire a 5Dii when you have a camera already, what is lacking in your present camera that you feel the new body would provide.
If you are unhappy with the quality of your pictures at the moment, the 5Dii alone may not improve them!
550D with a battery grip | Canon 70-200mm F4L | Canon 50mm 1.8mkII | Canon EF-S 18-55mm f/3.5-5.6 IS | YN 460II |
Nikon D7000 | 18-55 G VR | Tokina 11-16 2.8
Wide Boy is offline   Reply With Quote
Old 6th of December 2011 (Tue)   #3
mafoo
mafoo's Avatar
Canon makes 3 50mm lenses. A 1.8, 1.4, and 1.2. They made a 1.0 for a few years starting in 1989, but it was not very good.
Of those three lenses, at least one well respected review site has given the 1.8 higher marks then the other two for image quality. So while the 1.8 is not the most durable lens, it creates some great pictures.
What is it about the photos you're taking now, that leads you to want to rent/hire new equipment?
mafoo is online now   Reply With Quote
Old 6th of December 2011 (Tue)   #4
wayne.robbins
Vettori,
Unless you are printing quite large prints, that 400D should be more than enough. Even that 50mm f/1.8 lens should be more than good enough unless it is too long- in which case, I would suggest getting a kit lens like an image stabilized 18-55 or 18-135. The biggest problems I see with the 50mm is that they are highly recommended by those who know how to use them, and a lot that purchase them are not ready for a non-image stabilized lens, nor are they ready for a very thin DOF. If money is tight, and it sounds like it is, I would suggest putting your hard earned money towards a decent kit lens like the Canon 18-55 IS, and practice shooting with it instead of the 50mm. On your 50mm, what aperture are you using on it ? f/1.8 mostly, or are you stopping it down to something like f/2.8 ? After that, my next suggestion would be an external flash.
wayne.robbins is offline   Reply With Quote
Old 6th of December 2011 (Tue)   #5
vettori
Hi everyone and thanks for your responses - it's been interesting reading!
I'm basically looking for really sharp, fantastic resolution and perhaps i'm a bit confused in thinking that simply lots of megapixels will produce that? I have a pretty good "eye" but just basic equipment and i guess i was hoping to hire pro gear as it will work out considerably less than hiring a pro photographer! We're going away for a week and i love the thought of having it for that time frame to go bananas with.
I don't need video functions or for the camera to make me a cup of tea, just take great portraits of my children with high resolution. I also don't want to hire something that will slip a disc carrying it.
I love using the EF 50mm on the widest aperture as i love a blurred background when photographing children.
Keep the opinions coming, i appreciate it.
Old 6th of December 2011 (Tue)   #6
mafoo
mafoo's Avatar
(please, anyone who knows more then me, please correct me)
I am new to all this, but I am a techie, and love reading anything I can get my hands on, so here is some book smart advise (with little to know real work experience)
the 50mm 1.8 wide open is going to let a lot of light in. This means one of two things will happen with the other two parts of the equation (shutter speed and ISO)
You will have lower ISO, and a long shutter speed
You will have higher ISO and a fast shutter speed
If you plan to hold the camera, and want sharp images, you will need to up the shutter speed. This means the ISO will go up, and as it goes up, you get more noise.
If you have a good enough sensor, you can take high iso shots and they will still look good, but really at 1.8, your most likely going to want to steady the camera on a tripod (or something other then handheld).
Also wide open, you end up with an extremely shallow focal range. Gives you that great look, but is harder with moving objects.
If you want better looking photos, you can experiment with a tripod in the living room with the kids playing (if that's a piece of equipment you want to take on your trip), or just step down the camera to f2.8/3.5 or something, and sacrifice the DoF.
Old 6th of December 2011 (Tue)   #7
vettori
Thanks for the advice mafoo, that's good to know and from now on i'm going to try smaller apertures and see how i go.
I think i've decided on the 7D and i have another question - is there any difference in resolution between the 7D and the 550D, 600D or 60D? They all have 18MP and the only reason i ask is because i'm not interested in any 'extras", so to speak (such as video etc), just high resolution, and the other three models i have mentioned are cheaper to hire. I just don't want to pay for a function i'm not going to use.
Old 6th of December 2011 (Tue)   #8
mafoo
mafoo's Avatar
For all practical purposes, those cameras will provide the same results. The only real difference that might matter to you across those models, is better auto focus systems (7D, 60D), and faster frames per second (7D) if you plan to do action shots (like your kids jumping into a pool).
If your kids run around a lot, or you plan on having lots of action, then the 7D is your best bet. If the cost delta between that and the 60D is large, that's the second choice.
All of them however, are great cameras. Oh and if video is important, the 60D and 600D have articulating screens. Makes shooting home movies a little easier.
Old 7th of December 2011 (Wed)   #9
modchild
I use my 50 f1.8 on my 5D2 alot of the time when I'm indoors. For taking pics of the kids it's brilliant. The reach on a crop camera is a bit too far for most indoor pics but on the FF bodies it's perfect. If you hire the 5D2 for the xmas period I would look at getting a good flash instead of a "pro lens" as it doesn't have a built in one and although it's good in low light it's often better to use flash and keep the ISO low.
Gripped 5D MkIII, Gripped 7D, Gripped 650D, Canon 70-200 f2.8 IS L MkII, Canon 100 f2.8 L Macro,Canon 17-40 f4 L, Canon 85 f1.8, Canon 50 f1.4, Canon 40 f2.8, Canon 35 f2, Canon 24-105 f4 IS L, Sigma 24-70 f2.8 HSM, Sigma 150-500 OS, Sigma 120-400 OS , Canon 18-135 IS, 580EX II Flash, Nissin Di866 MkII Flash, Sigma EM 140 Macro Flash and other bits.
modchild is offline   Reply With Quote
Old 7th of December 2011 (Wed)   #10
NicuB
small correction : they make also the 50mm f/2.5
NicuB is offline   Reply With Quote
Old 7th of December 2011 (Wed)   #11
vettori
I'm totally confused and am now thinking of purchasing the 600D body instead of hiring anything. Wahhh this sux!
Old 7th of December 2011 (Wed)   #12
mafoo
mafoo's Avatar
Two things:
  • What's confusing you? Maybe I can help.
  • you make good decisions when you are confused.
After all my research, I have purchased the 5D Mk II, because I want the advantages that sensor offers me. However if I had not gone with that camera, I would have purchased the 600D.
It's a great camera, and in my opinion offers the best value (if you can find it for less then $100 more then the 550D).
Old 8th of December 2011 (Thu)   #13
vettori
Thank you mafoo for listening to my insolent whining. This weekend i'll be heading out to test drive both the 600D and 60D. I have a feeling the 7D will be wasted on me and i'd rather save some money and try to get a better standard lens (am happy with the cheapie 50mm though).
I've read that the 60D has a faster auto-focus system...do you have any thoughts on that? I'm happy with how quickly my 400D focuses and can only imagine the 600D would have improved in that department?
Old 11th of December 2011 (Sun)   #14
cpam.pix
I'd hire the dream lens and leave the other body in the store.
Why?
I usually get my biggest improvements by having the right lens for the job. When I get a new body, I miss shots because I have to figure out the settings or, "Wait! Let me try this" and my audience gets bored and won't perform in the same way again.
If you're going for the family gathering, once-in-a-lifetime shots this holiday, go with what you know.
[Now, if you go to family gatherings and are bored to tears and you need something to do, by all means, bring the hired camera and the manual...this will keep you engaged doing SOMETHING while the rest of family drama is in full force.]
1D-III with stuff to stick on it:
70-200L, 28-70L, 24-105L, 300L, 50, 2.0x TC
cpam.pix is online now   Reply With Quote
Old 11th of December 2011 (Sun)   #15
vettori
Thanks cpam.pix, i bought the 60D - love it! Will be hiring the 28-70L for the holiday period and no chance of boredom with 4 kids under 6!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Need advice on some gear. jimi thing Canon EOS Digital Cameras 24 28th of March 2011 (Mon) 09:04
New Gear.. Need advice! viper42391 Canon EOS Digital Cameras 6 10th of February 2011 (Thu) 15:26
Going to Florida & Carribbean, need advice and gear advice. TheHunter Urban Life & Travel Talk 7 2nd of August 2009 (Sun) 17:48
lens hire - SYDNEY AUSTRALIA. Does anyone know any places that hire lenses? verty Canon EF and EF-S Lenses 4 7th of August 2008 (Thu) 03:42
Advice on lens hire choice please Glenn W Canon EF and EF-S Lenses 4 6th of February 2008 (Wed) 16:53
