#1 |
So, the other day I was playing around with the Picture Styles on my 1D3 and just for kicks I turned up the "Sharpness" by only 2 notches and wow...MASSIVE difference without any apparent loss of detail or "plastick-y" feeling to the pictures.
My question is...are there any drawbacks to turning up the in-camera sharpening just a touch? (I shoot JPEG, yeah, yeah, it's bad, but I hate PP'ing, so I don't do RAW...I might, in time, but sharpening RAW is not an option at this point). Also...if there isn't much difference between in-camera JPEG sharpening and using something like PS CS5 to do it, I'd rather the camera handle it... thanks, Tamas |
| sponsored links |
#2 |
If you shoot higher iso images you might notice noise being sharpened
Jason |
#3 | |
Fatal attraction.
And also watch out for haloes on high contrast edges, like tree branches against the sky.
Elie / אלי "If you presume to love something, you must love the process of it much more than you love the finished product." John Irving, 5/2012. "In theory there is no difference between practice and theory, but in practice there is." Yogi Berra Site |
| sponsored links |
#4 |
Ah thanks...I'm guessing there's no way to set up the camera so it only auto-sharpens up to a certain ISO, then backs it down as the ISO increases? (I've been through the menus a million times in the past year with this camera trying to learn every trick, but don't think I've bumped into something like that).
Also...right..the haloes I knew about when bumping contrast...for that reason I generally leave the contrast settings alone on the camera and do it in PP where I have a much better idea of whether I'm dealing with haloes or not. Would bumping only sharpness a notch or two be an issue for haloes? |
#5 |
Fatal attraction.
Most sharpening is nothing more than increasing contrast across edges.
Actually, there is a sort of decrease in sharpening as ISO increases if you have High ISO Noise Reduction enabled. Sharpening and NR do opposite things and to a certain extent cancel each other out. The camera's NR automatically gets stronger as ISO goes up and therefore cancels more sharpening.
#6 | |
I was just sooo happy with the results! haha... Or maybe see if I can remember to shoot, let's say slightly sharpened at ISOs below 3200 and shoot at 0 sharpening at 3200 and 6400? |
#7 | |
Since you almost always need to sharpen, and you find that a higher sharpen setting, in-camera, is best for your way of shooting, then by all means... that's what you should set..
.... Got some cameras; got some glass ..... I just need one more of each..... Some Snap-Shots http://500px.com/LarryD |
#8 | |
#9 | |
It's up to you to take your own images and determine if that is the best setting for you.... That's the reason that the camera has 10 levels as we all have our own work flow.. Where I notice the most impact is in setting the different picture styles, such as Landscape (which automatically chooses 3 sharpening)vs Neutral, but it is seldom in the area of sharpening, it is in the enhanced blues and greens that can have an impact on color rendition.. Shooting in raw and you can change any of these parameters, in jpeg you are stuck with what you choose.. The menu on the 1DIII is easy enough to change to neutral any time you feel that it is more beneficial to the scene..
#10 | |
Yeah, the Picture Styles dedicated button is one of the reasons I got the 1D3 (I used to use the PS a lot on my 30Ds...although ironically enough, I rarely use it on the 1D3). |
#11 |
User is banned from forums
If you shoot RAW and don't use DPP, those settings are worthless.
#12 |
I shoot raw (sometimes raw + jpg) and adjusting the sharpness affects the jpg preview that I use on the back of the camera and also in photo mechanic for culling. It doesn't affect the RAW image but it does make my life easier.
If you're uploading pics to an editor during a game you dn't have time to fuss with PP, but if you're just shooting for you, you can achieve the same effect by uploading all your raw images to say, Lightroom and applying the same sharpening and NR to all of them. That's basically what you're doing with picture styles and requires very little effort. I won't try to convince you to shoow RAW but if you set the settings wrong and get nasty halos... you're screwed. It just depends on your preferences really. |
#13 |
Thanks...I play with Picture Styles for now, but I know...oh believe me I know...that I really should shoot RAW. I'm going on a big month-long trip to Europe this summer, I guess I should get myself comfortable with RAW before then
#14 |
Darth Noink
That's what I thought. RAW files will not be affected no matter what Picture Style is used.
Phase One IQ260, Cambo, Rodenstock Digaron, Nikon D4 X 2, Nikon D800E, Nikon D800, Nikon D600, and Canon 1Ds MK III. Leica M (Type 240 preordered) |
#15 | |
....winded
DPP "reads" your in-camera Picture Style settings (Contrast, Sharpness, Saturation, as well as White Balance and Noise Reduction, etc) and applies them for its initial review and for "quick conversions". And then, it gives you complete freedom to change things around and adjust them. As to your original question, I would definitely work with the Picture Styles to change things around. For example, you could tweak the Landscape, Standard or Neutral/Faithful Picture Styles to be more to your liking. But, you can also create your own Picture Style in the Picture Style Editor, and load it using EOS Utilities. That way, you can have a Standard Picture Style with the default settings, or you could load one with the sharpening boost that you are talking about. As has been mentioned, over-sharpening a jpeg in-camera can lead to artifacts that are not-so-pleasant, and not-so-easy to remove!
Tony Two Canon cameras (5DC, 30D), three Canon lenses (24-105, 100-400, 100mm macro) Tony Long Photos on PBase Wildlife project pics here, Biking Photog shoots here, "Suburbia" project here! Mount St. Helens, Mount Hood pics here |
| Thread Tools | |
| Display Modes | |
| In-camera Sharpening = DPP Sharpening? | Alex_Venom | Canon EOS Digital Cameras | 15 | 6th of September 2011 (Tue) 16:18 |
| hdtv as monitor? any downsides? | The Outlaw | Computers | 16 | 5th of June 2011 (Sun) 01:10 |
| Downsides of AI Servo AF ? | rjalex | Canon EOS Digital Cameras | 34 | 15th of June 2010 (Tue) 10:39 |
| Gitzo 2540 vs 2540EX Any downsides to either? | DT10 | Accessories & Storage | 11 | 22nd of March 2008 (Sat) 06:56 |
| Downsides of IS | rjalex | Canon EF and EF-S Lenses | 21 | 4th of June 2007 (Mon) 23:39 |
