RobDickinson wrote in post #13611338
1) Manual mode and manual focus - Seems the dial switches to focus distance how do you change shutter speeds?
With so much DOF, and less-than-perfect focus verification (even with the focus area enlarged), I don't think I've ever bothered with MF on the S95 -- I reach for my DSLR when I need that much control over a photo....
Anyway, I think I found the solution for you:
"You can preset the manual focus value by half pressing
the shutter and then pressing the MF (left) button.
You can then adjust focus with the dial on the back.
You can press the exposure button (up) to switch the dial
back to the default function(s), leaving the focus locked."
(Source: http://forums.dpreview.com …0&message=38784096&page=1
2) Exposure lock or split focus from shutter button? Possible?
From the same thread referenced above: You can assign the Shortcut button to be "AE lock". Once AE is locked, half-pressing the shutter-release will only lock the AF.
(This means you have to lock exposure first, then set and lock AF by half-pressing the shutter-release. This sequence is the reverse of what I do with my DSLR, but at least it's one way to separate AF and AE on the S90/S95.)
If you wait a bit longer, I'm sure a certain long-term POTN member will chime in and mention this (the lack of a remote release, such as one using the USB port) as the #1 flaw of the S90/S95/S100....
4) Movie mode time laps - only with fake tilt shift option on!?
I hardly shoot movies, so hopefully someone else knows the answer.
5) no way to move the focus square?
You are really asking for a lot from a compact camera....
If you choose Face-detection AF and there are no faces recognizable (e.g. person wears a sunglass), it defaults to a multi-area focus mode previously known as AiAF. Depending on which area of the scene has the most contrast, it'll often pick a non-centre AF area.
However, I don't think there is a way to control which of these areas it uses, which is why my S95 is almost always set to Central-AF only. It takes very little time to "half-press-then-recompose"....
