Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Wildlife Talk
Reply
Thread Tools Display Modes
Old 10th of January 2012 (Tue)   #1
ryannbaker
Default Underwater - IS important?
The wife and I are going to Hawaii in May. Since I am still labeling myself as a hobbyist rather than ameture or pro with my photography, I have no interest in taking my 7D 70-100 feet below the surface to try and get some (much better) photos. So we will be taking a p&s in a case. I'm looking at the Canon A3300 IS or the A2200 as the camera. My question is this: Is the IS in the A3300 really important underwater?
I personally have never used IS in a camera or a lens so I don't know if it's worth the extra for the IS or not. Any input is very much welcome.
ryanbaker
Crimson Media
ryannbaker is offline   Reply With Quote
Old 15th of January 2012 (Sun)   #2
rick_reno
Default Re: Underwater - IS important?
No, it's not important.
rick_reno is offline   Reply With Quote
Old 28th of January 2012 (Sat)   #3
ryannbaker
Thanks! I appreciate the feedback.
ryanbaker
Crimson Media
Old 7th of February 2012 (Tue)   #4
gnirtS
IS is generally worthless underwater. The density of the water column dampens your motion massively. Add that to the limited negative buoyancy of the housings (usually) and its not an issue. In addition most of your shots the target will be moving anyway.
No point in IS for underwater at all.
(although RAW or 2nd best, manual white balance constantly are 100% essential!)
gnirtS is offline   Reply With Quote
Old 27th of March 2012 (Tue)   #5
g8trgr8t
g8trgr8t's Avatar
flash is more important than camera. Have you considered renting a camera w/ strobe when you get there?
g8trgr8t is offline   Reply With Quote
Old 29th of April 2012 (Sun)   #6
Noel Johnson
Noel Johnson's Avatar
Hello,
I have a small Fuji P&S I use in a 40metre housing when I go diving. As previously said you need to think about more light than IS for shots underwater.
Red is the first colour to be absorbed by the water colum, so you'll lose that first - but this can be compensated for using a cheap torch, a strobe light or a red filter (I have one from magicfilters - you can cut it to shape and it is very cheap)
There are various plug ins for photoshop to add the red channel back in as well, which can be used to good effect.
When lighting the sublect it's a good idea to have the light source on a different axis to the lens, therefore if you have any reflections from particles in the water they will be defected back to the light not the lens. Alternately you can diffise the cameras on board flash.
Just as an example of compact camera images:
I hope this helps,
Noel
Team Bunny. Depth before dishonour.
http://www.flickr.com/photos/noeljphotography/
EOS500D, Canon 17-85 IS, Tamron SP 70-300 F4-5.6 Di VC USD, Tamron SP AF 90 F2.8 macro, Tamron 55BB 500mm mirror and a buch of other stuff I can't use.
Noel Johnson is offline   Reply With Quote
Old 7th of May 2012 (Mon)   #7
tonylong
....winded
tonylong's Avatar
I don't have any experience with underwater photography, so my best advice is to do a forum search for "underwater photography" -- there are a fair number of POTN members who do this!
Tony
Tony Long Photos on PBase
Wildlife project pics here, Biking Photog shoots here, "Suburbia" project here! Mount St. Helens, Mount Hood pics here
tonylong is offline   Reply With Quote
Old 7th of May 2012 (Mon)   #8
supachim
supachim's Avatar
IS underwater is definitely not important. The most important thing is lighting - much like above water photography. Having a good strobe or two will make a significant difference. Also, I agree with gnirtS - having RAW capabilities for white balance alterations in post processing is very nice to have. I'm not familiar if either of those P&Ss have that.
- Chim
Canon 5D Mark II; EF 16-35mm f/2.8L; EF 100mm f/2.8L IS Macro; EF 70-200mm f/4L IS
Sony NEX 5N; E 16mm f/2.8; E 30mm Macro f/3.5; E 18-55 f/3.5-5.6; Ultra Wide Converter x0.75; Fisheye Converter; Nauticam NA-NEX5N Underwater Housing
supachim is offline   Reply With Quote
Old 28th of May 2012 (Mon)   #9
Theojt
Your scuba skills will be equally important as your photographic skills. You should be relatively comfortable with your diving before taking on the additional task loading that underwater photography will require.
When diving, I often see others passing some of their best photographic opportunities - because they are too busy looking for something to photograph. Move very slowy, pick a place on a coral head and scan it for a few seconds, then move (slowly again) to the next spot. You need to also remain aware of your surroundings (and bottom time/depth/air), and most importantly - don't leave your dive buddy! I can't tell you how many times I've seen someone with a camera chasing some fish, eel, sea trutle, etc. completely abandon their basic safety training because they wanted a picture. Dive safety should always take precedence.
And if you get the opportunity, try shooting during a night dive - it's a completely different experience than during the day.
Have fun! Since it's almost the end of May as I post, will we see some of your pics soon?
Theojt is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
What is more important? D.A. The Business of Photography 7 31st of March 2009 (Tue) 10:51
Some type of underwater housing or disposable underwater camera danpass General Photography Talk 4 1st of November 2008 (Sat) 19:48
How important is f2.8 on 40D newtune3 Canon EF and EF-S Lenses 8 2nd of March 2008 (Sun) 08:06
Just how important is IS? Boosting1Bar Canon EOS Digital Cameras 14 15th of June 2004 (Tue) 14:04
Underwater lens for S30/40 underwater casing jamesbondjur Small Compact Digitals by Canon 1 19th of November 2002 (Tue) 14:34
